Question about Sony Playstation 3 (PS3) Console
When i press the psp button the console willot come on unless i press the poewer button manually, and i can't configure the controller to work wirelessly
    President:
  • 1,139 Answers
You have to make sure that you turn the PS3 OFF with the controller to make it able to turn the PS3 back on again.
Hope this helps
Posted on Aug 06, 2010
Hi, i have a PSP3004, firmwire carcked, everything was fine, unless once i removed the battery and reconnected after 15 mins. now i can't view my 8gb memory card on the PC (once connected...
You have to configure your USB connection to PC. What shows up as the drive in your PC when you connect your PSP to it is one of the 4 FLASH folders. Do the following;
1. In your PSP main screen, press your "SELECT" button and XMB Menu will show up. 2. Scroll down to the "USB DEVICE" option. 3. Loot at the value in the right, it should either "Flash 0", "Flash 1", "Flash 2", or "Flash 3". 4. Press Arrow Right until the value changes to "Memory Stick Value".
Exit and connect to your PC again and you'll see your 8GB MS this time...
Jun 09, 2011 | Sony PlayStation Portable (PSP) Slim...
When I switch on my PSP, it directly goes onto load the UMD game and when I try to quit using HOME button, the buttons and consoles dont work. Then I need to use the hold button after which though the...
Hi. Since you're in UMD Autoload mode, you need to configure that in the PSP Settings. To do this, turn off your PSP and remove your UMD. Now, turn it back on and it won't autoload your UMD since it wasn't there anymore.
Now, go to "Settings" and scroll down to "System Settings" and press X. Scroll down again the selection until you see "UMD Auto-Start" and press X. At the right side will appear the options "ON" and "OFF". Select "OFF" and press O button several times to go back to main screen.
Insert your UMD. Now, try playing games from Memory Stick. You may have to turn off your PSP and turn it on again to finally play homebrew...
I hope this helps...
Jun 07, 2011 | Sony PlayStation Portable (PSP) Console
How to fix my psp 2004 problem the game could not be started (80020321) pls help,
This error is appearing because there is a setting in the hidden configuration menu that is set to require a UMD game disc to be in the PSP when it attempts to load.
Turn off the PSP, then hold the R button down while turning on the system. You will be in the Recovery mode/Configuration menu. Choose configuration, then go to the 5th option, and press X once. This will switch it to "NO UMD". Then press X on "Back", then "Exit". Once you restart you should be able to load the ISOs, CSOs etc. without getting the 80020321 error.
Hope this helps you!
Mar 03, 2011 | Sony PlayStation Portable (PSP) Slim...
How yo download psp games
First, you have to find the game you want, and download it to your computer.
  1. 1 Once the PSP games are downloaded, connect the PSP to your computer by using the USB cable that comes with the PSP console. Change your PSP console into PSP mode by pressing the "Home" button. Next scroll left to the "Setting" column and scroll down until "USB Connection". Press "X" button to enter PSP into USB mode.
  2. 2 To download the PSP games into your console, the games must be copied and downloaded onto the correct folder in order for the games to work. And the correct path is PSP > GAME in order for the any PSP games to work correctly. If the "PSP" and "GAME" folder does not exist on your PSP memory stick, you need to manually create the folder with folder name in ALL CAPS.
  3. 3 Once you have finished downloading or transferring the games onto the PSP memory stick, you can disconnect your PSP from the computer. From the PSP console main menu, scroll over to the "GAME" column on your Sony PSP and continue to scroll down on the memory stick. Press "X" and a list of game files will be displayed. Scroll downward and you will be able to see the games you have just installed.
  4. 4 Press "X" again to confirm your selection and play the PSP games. I had tried to practice the steps above many times in my PSP and it worked all the time. Hopefully it will also work for your console too.
Hopefully, this works for you!
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
I tried to connect to internet from my psp2, but always connection erroe occured. Please advise how to set up wifi connection. Thanks
Hello
To connect your PSP to the Internet, you must manually configure the WiFi settings for your device. The PSP will not automatically search for and connect to available wireless
Turn on your PSP by moving the power button on the right-hand side of the console in an upward motion. Under the console's main screen, go to the "Settings" icon. This is the first icon listed and is farthest to the left. From the drop-down menu, choose the "Network Settings" option at the end of the list.
Select "Infrastructure Mode" and press the "X" button. Select the "New Connection" option to add a wireless connection to your PSP. Choose the "Scan" option to instruct your PSP to search for accessible wireless connections in your area.
Select a wireless connection from the connections your PSP is able to access. Confirm the name of the network and press the right arrow button. Confirm the security encryption settings for the connection. In most cases, the PSP will determine the network's encryption automatically. Enter the wireless connection's password if the network is secured.
Name your new wireless connection so that you will be able to identify it in the future and save your settings. Run a test connection to ensure you are able to connect to the Internet through the wireless network.
Press your PSP's "Home" button at the bottom left-hand side of the console. Move your cursor to the right to find the "Network" icon. Select the "Internet Browser" option from the drop-down menu. Press the up directional arrow and press "X" to enter a web address into the browser. Once you enter a web address, your PSP will automatically connect to the Internet using the WiFi connection you set up previously.
Nov 14, 2010 | Sony PlayStation Portable (PSP) Slim...
How do you perform a network update on the system
To configure a network access point, press Home then move to Network Update, then you get to the configuration screen that asks for the WLAN Settings (the default is to enter an SSID), choose "Scan" and let the PSP identify all the wireless networks it can see. Choose whichever one is your network.
Choose all the default configuration settings and you should promptly be asked to press the X button to save your new access profile. Do so, then select it again and, if your connection works you'll see "Checking Server...", then, if there's an update available, the PSP shows:
Network Update has found a later version.
To download, insert a Memory Stick with at least 14MB of free space and press the X button. Press the X button and you'll see "Downloading..." and a warning not to turn the unit off or remove the Memory Stick while downloading, then the download starts.
When the download succeeds, you'll now see:
Download completed.
The update is now available on your
Memory Stick.
To install now, press the x button.
To install later, go to [Game]..
Let me know if there is anything else.
Reagrds.
Aug 15, 2010 | Sony PlayStation Portable (PSP) Console
PSP Game error - the game could not be started - 80020148. PSP firmware is 4.01 M33-2
  1. go to ur M33 Recovery Menu.(it can be access by totally turning of your psp-holding the power button up...and then turn it on again but hold the R button.. It should appear as it turns on..)
  2. go to the configuration and press Xbutton..
  3. browse and go to UMD Mode and
  4. check if it set to <currently: M33 Driver -NO UMD>if not, just press x until it appears...
after that exit in that menu...games should play after that setting..i have encountered 8 psp's with that kind of problem...
trust me you dont want to go to a service center unless you can have a solutions on the internet...coz it will cost you 500-700php
Apr 29, 2010 | Sony PlayStation Portable (PSP) Slim...
The games at my psp runs very slow but for other features its fine, but before i try to repair the error code 80020321, please advice
This error is appearing because there is a setting in the hidden configuration menu that is set to require a UMD game disc to be in the PSP when it attempts to load. Turn off the PSP, then hold the R button down while turning on the system. You will be in the Recovery mode/Configuration menu. Choose configuration, then go to the 5th option, and press X once. This will switch it to "NO UMD". Then press X on "Back", then "Exit". Once you restart you should be able to load the ISOs, CSOs etc. without getting the 80020321 error.
the answer from: http://wiki.answers.com/Q/How_do_you_fix_the_PSP_error_80020321
Mar 25, 2010 | Sony PlayStation Portable (PSP) Console
Weres the aoss button
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I think there is no AOSS button on your PSP. AOSS is a wireless solution made by www.buffalotech.com. Most new wireless routers/access points has this capability. AOSS is on the wireless router/access point and not on the PSP.
AOSS will automagically determines and configures the connection of a PSP to a wireless access point by pressing the AOSS button on the wireless access point.
Apr 09, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp protable
Have you tried looking at the options on the start of the game? Usually there is an option there that says "control" or "control configuration" or somethin' like that...i believe most of the games have that at the options or settings at the start of the game or when in-game (meaning when you are already playing the game) press either select or start button, then there are options there...or if there aren't, try downloading a walkthrough of the game fromthe internet...most walkthroughs should have maps for the controls of the game you wish to play...
Jul 26, 2008 | Sony PlayStation Portable (PSP) Console
Sony Playstation 3 (PS3) Console Logo
24 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
