Need to remove back to change battery - Computers & Internet
  • sirjohneleth Aug 06, 2010
    is there no access to the battery from the front? What board do you have? b
  • Marvin
    Marvin Aug 06, 2010
    of what make and model computer, do u mean the CMOS battery
  • 977 Answers
If it's a PC, just open the left case side... You'll easily reach the CMOS battery!
Posted on Aug 06, 2010
Armitron watches need to know how to change battery
  • Remove back
  • Find battery location. Note mounting and polarity for later reference
  • Identify battery type
  • Obtain replacement battery
  • Remove old battery
  • Install new battery exactly as noted in second step
  • Check operation
  • Install back
  • Set various functions
Aug 30, 2016 | Armitron Watches
Battery change
  • Open back
  • Note battery polarity and remove
  • Close back
  • Set correct time
Jul 12, 2016 | Watches
How do I change the battery in a 2000 E240 Mercedes
Remove the back seat switch off all electric in the car
remove battery clamp start with minus and there in is 13mm. Screw in the middle down
Jul 16, 2014 | Vehicle Parts & Accessories
How do I change the battery on my zebco 33 live bait reel
take it to your local tackle shop, it needs taking apart and resealing
Apr 09, 2014 | Sport & Outdoor - Others
Change battery
The batteries need replaced. You will find the correct batteries at shaveroutlet.com at the link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-battery-pack-for-most-norelco-more-p-278.html
To open the shaver you will need to remove the back cover by removing the two screws. You may need to slide the trimmer up to reveal second screw. Inside, you will need to remove the metal clip that is in the way.
Use the tutorial video at the link below for information on changing the batteries
http://www.youtube.com/watch?v=2oAnLpvdYqQ
Oct 06, 2013 | Philips Philishave HQ7850 Electric Shaver
Change the battery
You need to remove the back of the watch to get to the battery. If the watch is a water proof watch then the back is screwed on. After removing the back take care not to damage the gasket.
If you cannot remove the back of the watch then take it to a watch repairer, they can replace the battery and it won't be expensive.
Mar 09, 2013 | Watches
How do I change the battery on fossil motorcycle clock?
You will need a very small (watch or glasses) Philips head screwdriver, and a SR626SW (or know as a 377) watch battery.
Remove screw 1 to remove the motorcycle back cover.
Remove the other 2 screws to take off the clock backing.
Remove the white plastic ring by pulling directly up.
Remove the battery.
Put the new battery in.
Press the white plastic ring back on.
Reassemble the clock backing with the two screws.
Reassemble the back of the motorcycle with screw 1.
May 24, 2012 | Watches
Change batteries
1. Remove slide cover. Place calculator face down.
2. Using a small Phillips screwdriver, remove screws
from back case.
3. Remove back case.
4. Remove discharged batteries.
Caution: Avoid contact with other calculator
components while changing batteries.
5. Install new batteries positive side up, as shown on
diagram inside case.
6. Replace back case, and then replace screws.
7. Press OFF ON ON.
Caution: Dispose of old batteries properly. Do not
incinerate batteries or leave where a child can find
them.
Your calculator cannot hold data in memory when
batteries are removed or become discharged.
Feb 02, 2011 | Texas Instruments TI-30XA Calculator
I need to change the battery on the tI30-xa calculator. I need to know the size and how to change it.
Remove slide cover. Place calculator face down. Using a small Phillips screwdriver, remove screws from back case. Remove back case. Remove discharged batteries. Caution: Avoid contact with other calculator
components while changing batteries. Install new batteries positive side up, as shown on diagram inside case. Replace back case, and then replace screws.
May 19, 2010 | Texas Instruments TI-30XA Calculator
Removing VW polo 2005 battery?
Removing a battery from a Beetle is a bit complex and tricky. I just changed the battery in a 2003 2.0 Beetle. However, the process is very similar in a TDI Beetle. You will need more than your standard generic tool set in order to complete this task. Your tool list needs to consist of a pair of pliers (prefer locking type), a # 20 TORX head screwdriver (You will also need this if you ever plan on changing the Beetle's internal dash pollen filter for the A/C. ), a 10 mm and 13 mm sockets, a long extension and a wobble or universal to allow flexibility in tight spaces, an allen socket for removing the power steering reservoir, and a small adjustable wrench or a 10mm to remove the battery cables. If you are changing the battery you might as well buy a new Air filter since you will need to remove the air box in order to replace the battery. If you do change the air filter you will need a phillips head screwdriver.
1. Pop the hood.
2. Remove the two 10 mm bolts that hold down the air filter box.
3. Undo the clamp that holds the large tubing to the air box using your pliers. Move the tubing away from the box.
4. Unclip hose attached to the back of the air box near the large hose (under it).
5. remove the small breather hose from the air box.
6. Pull air box up and out.
7. Remove snap on cover from top of battery.
8. Remove small snap on wiring cover from back of the battery covering.
9. Unbolt power steering reservoir (next to battery case).
10. Disconnect the battery cables. Positive side first.
11. Remove the 13 mm bolt at the base of the battery along with the hold down clamp.
12. Pull the top wiring away from the battery case and then slide the battery towards the engine.
13. Remove the plastic battery case.
14. Remove the battery
Oct 07, 2009 | 1997 Volkswagen Jetta
Computers & Internet Logo
11 people viewed this question
Alun Cox
David Payne
David Payne
