Question about Husqvarna Garden
Check oil light came on while mowing..changed oil, filter,,light still on..engine sounds fine when running...
  • 100 Answers
Probably has faulty sensor...
Posted on Aug 14, 2010
Kohler engine oil leak
Could have blown a seal however before checking for that I would check the drain plug and filter seating if you changed the filter. Make sure the drain plug is not cross threaded. You can run a little low but should never over fill. Hope this will help. Most of the time if over filled you will get some smoke as well.
Apr 25, 2014 | Garden
Husqvarna Lawn Tractor LGT 2654 (from Lowes) B&S Intek V-Twin 725cc 26 gross hp 110 hrs. I had a couple of problems with the 2654 in the past but they were electrical. Now the engine seems to...
A common loss of power problem with B&S V twins is a set of crumpled valve push rods. Means you are running on one cylinder which is generally OK unless you also want to mow. Easy to check, pull one plug wire at a time off. If it continues to run on one cylinder but not the other, that is your dead cylinder. As the intake is not opening, there will not be a wet plug. Costs nothing to check and could be your problem.
Sep 21, 2010 | Garden
I have a John Deere GT235 that loses power when you engage the blades. When mowing it almost wants to die but if I stop and wait for a little bit the engine speeds up and runs right. But it does that the...
if it has a 2 cylinder engine i would try running it on just one cylinder at a time. simply remove one plug wire and start the engine. then put that wire back on pull the other wire off and start the engine. if it runs on one cylinder, but not the other, then i would guess you have bent the valve push rods which is what it sounds like to me. there is a small valve cover which comes off. the rods are easy to replace, but skill is required in adjusting them.
Aug 30, 2010 | Garden
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Toro LX500 CH 6 oil light went on and will not go off
Hey Jamie..im pretty sure that light means its time to change the oil..and when you do change the oil..reset the counter..i hope this has helped
Jul 04, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Garden Logo
48 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
