Question about Garden
This is for the painters. Is there a spray paint that can make my radiators look as close to chrome as possible? I mean a nice looking finish not an obviously plastic one. UK products preferred because I'm UK based but if it's in the US I can get it imported so if that's what you know then still reply.
  • 15,935 Answers
No - radiators are designed to EMIT heat - and by painting them - it traps the heat inside.
Home, auto, small engine... whatever the application do not paint radiators.
If you MUST - or if it is decorative - any automotive supply will have a chrome spraypaint - and is the closest you will get to the real thing.
Thanks!!
Posted on Aug 06, 2010
  • usedonlytosi Aug 07, 2010
    lotta radiators come painted white.
I used red primer oil based I want to paint metallic burnt orange on my car is it ok and how well will it work
won't work-- two different types of paint on an oily surface
what will happen is when you apply the top coat it will go all wrinkly and peel off
Aug 31, 2016 | Cars & Trucks
I have an old white refrigerator that works fine, just looks awful. What can I do to the face to make it look nice. I have wooden oak kitchen cabinets and a tile floor.
Paint it with white enamel.
Enamel Paint finishes in high gloss if you want that sort of finish.
Always paint in a dust free invironment with plenty of ventiallation.
With the expensive cost of many home appliances, sometimes replacing an old refrigerator is out of the question, especially if it still works well.
This can be a problem if you've recently painted your kitchen or if you're just sick of looking at an old, outdated fridge.
Instead of learning to live with your boring or unattractive refrigerator, you can give it a bright new look with a few coats of paint.
Mix a few tablespoons of vinegar into a bucket of warm soapy water.
Use this mixture to clean the refrigerator.
Scrub away any grease, dirt or other grime with your soapy water and a stiff bristled scrub brush. Wipe the refrigerator dry with a towel when it is clean.
Use painter's tape to cover parts of the refrigerator you do not want to paint such as the handle or the grate at the bottom of the refrigerator.
Apply a coat of appliance paint to your refrigerator with a paint roller to prime the surface.
You can also purchase appliance paint in a spray can and use it to spray paint your refrigerator.
Sand the paint with an extra fine grit sanding sponge when it is completely dry.
Try to make the surface as smooth as possible and then wipe away any dust created with a clean towel.
Paint the refrigerator with an enamel paint tinted to the desired color and a paint roller.
You can use oil-based or latex-based enamel depending on your preferences.
Oil paints usually have a stronger odor than latex paints but they may last longer.
Apply a second coat of paint when the first coat is completely dry.
Sand the final coat of paint when it is dry with a wet extra fine sanding sponge.
Spray the refrigerator with water while you work to keep it damp and keep sanding until the paint is smooth and shiny.
Remove all of the painter's tape from your painted refrigerator.
Sep 08, 2013 | GE Refrigerators
What size tip to use to paint interior using a graco 170 spray
The size tip you use depends on what you are spraying, how thin/thick it is and if you something like Flotrol to make it flow on the work better. Tip sizes are given as a decimal number and here's how to read them.
Example: .517 (the one most people, including you, need)
- The 5 means you'll get a ten inch swath of paint with the tip 12 inches from the work surface. 5's are for general painting, 2's and 3's are usually used for trim work.
- The 17 is the diameter of the orifice (.017) the paint passes through to get properly atomized. The larger the orifice, the thicker the medium you can effectively spray. .013's are used for very thin things like stain. .015's & .017's are for latex paints, .019's are for enamils, and .021 - .027 are reserved for thicker things like elastomerics.
Most likely if you are using an interior, latex paint, you'll need the .517 tip. Be sure to strain your paint so you'll get an even fan of paint and the best results. Even brand new paint has sand impurities in it that will effect the tips performance or plug up the filters.
Jan 21, 2013 | Air Tools & Compressors
What kind of paint and brush should I use to paint my wooden bar stools?
You should first put a layer of primer using wood primerfrom a spray can. This will prevent thepaint from being absorbed into the wood. After 24 hours, you should use acrylic black (or whichever color youwant) paint in a spray can. The reason Irecommend spray paint is because it's easy and gives you tan even, blemish freecolor. Wait 24 hours (so that bubbleswon't form) and do another layer. If itdoesn't look thick enough to you, wait another 24 hours and do a final layer. There is no need for a clear finish.
May 29, 2012 | Furniture
I had my front bumper painted and now my ac only blows warm air and the ac compressor will not kick on.
The A/C condenser is mounted right behind the bumper so, unless the painter covered the condenser or removed the bumper before spraying it, he painted the condenser as well. This is bad because the condenser must have air flow through it in order for the A/C to work properly. Try to have a look at the condenser, it looks like a smaller radiator mounted in front of the radiator and behind the grill / bumper. If it is painted, go back to the paint shop and demand it to be replaced. Also, have the radiator checked to be sure it isn't painted because that'll run into engine overheating issues.
May 15, 2011 | 2004 Lincoln Navigator
Porter cable spray painter PSH1 it says what you can spray with it and I want to spray water base paint can I do it with this painter it is new and I didn't relize it was onl for laciur paint thank you...
Be sure to filter the paint you are trying to use so that you aren't dealing with large lumps of paint. You will need to experiment with hose pressure to get proper spray quality, and set the mixture control for a fairly fine mist as the paint is likely to be more fluid. Fan control is set so that you don't get an unpainted space in the middle of the paint swath. Make sure to wash the gun thoroughly after painting. If you are doing a lot of painting, expect some nozzle wear over time as the water base paint is somewhat gritty. Don't forget to trigger 'off' before the end of each stroke and trigger 'on' after starting the return stroke to keep running at a minimum. Good luck!
Jun 19, 2010 | Porter Cable Cable PSH1 HVLP Gravity Feed...
I want to know how to camouflage a jeep the best
Knowing how to paint a Jeep in camo patterns means you can hide your Jeep in the woods, marshy areas or in open fields without it being easily seen. Using Mossy Oak's Shadow Grass pattern, paint your Jeep with natural-looking shadows and grass blades. The 3-D look of this pattern allows you to easily hide your Jeep from water fowl, doves, deer and big game.
Things You'll Need:
  • Sandpaper (120 and 800 grit)
  • Wax and grease remover
  • Lint-free towel
  • Camo stencil
  • Masking tape
  • Masking paper
  • Respirator mask
  • Automotive primer
  • Automotive paint (black, gray, light tan and brown)
  • Automotive clear coat
  1. Sand the surface of the Jeep with 120-grit sandpaper until the surface is dull. You can use a dual-action sander for this step to speed the process. This removes the top clear coat and prepares the surface for primer. Primer won't stick to a shiny surface.
  2. Mask off areas of the Jeep that won't be painted, such as the windows, tires and passenger area of the Jeep. Wipe the surface with wax and grease remover and a lint-free towel.
  3. Spray primer on the Jeep in three thin coats. Allow each coat to dry completely. Once the primer is dry, use 800-grit sandpaper to sand the top layer of primer until smooth. This leaves a smooth surface for the paint. Wipe again with wax and grease remover and a lint-free towel.
  4. Paint a thin base coat of gray on the Jeep. Cover all of the primered areas on the Jeep so that no primer can be seen. Allow the paint to dry.
  5. Go over the Jeep with brown paint, spraying small areas of brown paint in no particular pattern. The finished effect should look like the Jeep is equally painted gray and tan. Hold the first stencil against the Jeep and use black paint to fill it in. Move the stencil over and paint again. Start at the front of the Jeep and work towards the rear.
  6. Move on to the next stencil and use light tan paint to spray the grass pattern. The grass should start at the bottom of the Jeep and reach up towards the top. For longer grass, don't spray the tops of the grass but instead move the pattern up, spray the stems longer and then spray the tops, making the grass stems long. Repeat this around the Jeep and across the hood. Go back over the grass stems with black paint, lightly spraying a few of the stems to give them a shadow look.
  7. Finish by spraying three coats of clear coat paint onto the painted areas of the Jeep. This protects the paint from UV rays and keep the camo pattern looking good.
Tips & Warnings
  • Paint is best applied using a paint spray gun and air compressor, but canned spray paint will work.
  • Never sand or spray primer or paint without using a painter's respirator mask.
Resources: Customice Camo Stencils
I really hope help you with this (remember rated this help) Good luck.
Oct 21, 2009 | 1984 Jeep CJ7
Ugly chromefenders
Paint will not adhere very well to chrome.You will need to get the chrome stripped as it is a plating finish on the steel. Any plating business should be able to strip them for you. Once stripped then use any good quality primer or powder coating
Apr 25, 2009 | 1981 Yamaha XJ 650
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
