Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Water runs into dishwasher when machine is off and if door is open. Model PDW7800
  • 166 Answers
If the only way to stop the water from coming in is to turn the main valve going to the dishwasher off then you have a bad water valve. replace it.
Posted on Aug 06, 2010
Dishwasher runs through cycle but no water.
make sure water is on ,if water is on and still no water in d/w then check water control valve
Nov 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
It won't begin the cycle. The counter works but
Door not latcning or faulity door switch. fauilty timer or motor. dosent fill float switch faulity or stuck open or clogged inlet valve.
Nov 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
Acts like water is turned off to machine. turns on to run cycle but no water comes out. valve is on
Turn the water valve off, and remove the hose. Where it screwed on, there should be a filter screen. This is more then likely to be clogged up. Clean this and try again after you put the hose back on.With the dishwasher in the fill position, and still pulled out, you should be able to hear the water fill valve coil open up.If you still have no water after cleaning, more then likely your fill valve is clogged or the coil has failed and needs to be replaced. 120volts,ac.Please let me know as I am here to help you. Good Luck, Shastlaker7
Nov 06, 2009 | GE 24 in. Profile PDW7800 Built-in...
No water flow to dishwasher disconect the plug at flowing switch 120V no power at water valve plug
check to ensure you have proper volatage at the connection box behind the toe kick
the you will need to open the door to check the door switch for both voltage and continuity
Oct 21, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher wan't fill with water
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
Jul 05, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher will not fill up with water
did you chek the level micro switch thats in serie with the intlet valve
Jun 18, 2009 | GE 24 in. Profile PDW7800 Built-in...
Machine runs full cycle without water!
The most common reason for this problem is the inlet valve (Solinoid valve) has failed and does not open when the DW timer tells it to before each wash and rinse cycle.
That valve is just inside the place where the hot water supply hose connects to the dishwasher.
There can be other causes but this is by far the most common reason.
Good Luck!
Apr 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwaser Fills But Does Not Run
You may have a problem with the spray arm being blocked or the water valve may not be letting a sufficient amount of water through to get the spray arms activated. If the dishwasher is still in warranty schedule service before it runs out. GE customer service number is 800-626-2000 model and serial numbers and purchase dates are helpful. Ask specifically if any kits are available to fix these problems and if GE is willing to make any concession toward this repair. Good Luck.
Dec 30, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
49 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
