Question about Magellan Crossover GPS
Have for the first time connected MagellanCrossoverGPS to PC (Win7) with USB cable, but PC does not recognise the device. Have original discs but no driver (PC does not find in on any disc). Where do I get the driver and how to install it?
  • jurij_rezek Aug 06, 2010
    Can not update because my PC Operating system is Windows 7. The solution reporsts - no MagellanCrossover found???
    Can not update because my PC Operating system is Windows 7 !!. The solution reports - no MagellanCrossover found???
    Genius:
  • 1,456 Answers
Hi there
You can connect your GPS to your PC by just insertingI the Magellan DataSend software installation CD into your computer's optical disc drive,the DataSend software installation CD comes with the drivers.but if you don't have the CD,visit the manufacturers website for links to download the drivers for your GPS system's model
Once you have downloaded the drivers you should save them in a folder on your system or better still you can burn them onto an empty disc so it can serve as the DataSend software installation CD.
Posted on Aug 06, 2010
  • 1 more comment
  • jurij_rezek Aug 07, 2010
    Hm, I do not have the DataSend CD, was not part of my kit, and I do not find any links to download the driver. Manufacturers website gives me no information ??
    Guru:
  • 382 Answers
You need to update your firmware, if you have already tried to install your device, you must remove all software and get rid of any registry entries it may have made. Follow this link and and follow directions. will get you up and running in no time
    Does not work because my PC Operating system is Windows 7. The solution reports - no MagellanCrossover found???
Sanei tablet 3it is not running on laptop pc hp
To connect up a tablet with a laptop you need to connect them with a USB cable.
On plugging in the cable with the tablet powered up, you should see two things.
1. A question on the tablet as to whether you want to use memory disc mode or diagnostic(ADB) mode. Choose Memory disc mode.
2. You should see on the PC laptop it recognise that an external device is connected, it may recognise it as a phone or a memory drive.
If neither of these things is happening it is probably the cable at fault.
The tablet should then start providing the pc laptop with the drivers it requires to be recognised. If this does not happen, then the fault is with the tablet and you have to consult your supplier.
You should end up with at least one memory drive which you can browse through with the PC's file manager. The data will be on the tablet.
Nov 30, 2013 | Tablets & eReaders
First boot device option not showing in boot menu
There are several things that could cause the problem. There could be no power to the device or no data cable connected (loose cables), the boot record could be corrupted or the device has failed.
If you recently opened the case (desktop), make sure that the 4 pin power cable is fully seated in the device and that the IDE cable is correctly connected to device and the motherboard (at the master cable connection). (Take the device out of the case and check that the jumper is set to Master or Cable Select. This can vary depending on the manufacturer. If you are unsure, please post a comment with the device information.) If you have a laptop, the IDE and power cables are unified at the device (44 pin). The cables can also come loose or damaged. Try replacing the cable or using a different power connection from your power supply.
Try accessing the BIOS and see if the device is listed. (Depending on the motherboard, this can be accessed by pressing ESC, F1, F2 or F10 repeatedly as the computer starts. If you miss the timing, try again.) If the BIOS doesn't list the device, the computer can't see it.
Which device is currently not showing up? If it is your hard disc, get a system recovery, install or upgrade disc for your OS. With a Windows OS, get one that matches the service pack and version (Home or Pro) that is currently installed. Boot to CD (press F12 repeatedly as the computer starts) and select the Repair option. Attempt to repair the Master Boot Record with the BootRec command in the command prompt. Type "bootrec /fixmbr " without the quotes followed by enter. (Other bootrec commands may also be needed. A complete reinstall of the OS might be required if the bootrec repair doesn't work.) Note: bootrec is used with Vista and Win7. XP just uses the fixmbr command directly.
If these steps don't help, you may need to replace the device. If it's your hard disc, you may need to use your system recovery optical disc set and backup to restore your computer. You might be able to salvage the data from the original hard disc by placing the drive in the freezer (protect it from the freezer moisture). However, some of the OS information or the original recovery partition on the disc may not transfer so you need to be prepared to reinstall your OS if you do not have the recovery disc set.
I hope this helps.
(Yes, I've dealt with a corrupted MBR with Win7. Assuming you made a System Repair disc, it's not too bad. If you have an older Windows OS that didn't ship with a Windows CD, find someone with the install CDs.)
May 29, 2012 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Samsung E2210L Connecting to PC wont recognise
Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Restart the computer, and then reinstall the USB controllers. Plug in the removable USB storage device, and then test to make
Apr 10, 2010 | Cell Phones
Cannot download photos to my pc
For the camera to be 'recognised' by Windows, you need an USB port with a correct driver installed (should be automatically in Win XP SP2 and later, Vista, Win7, ...)
Then you need a 'good' (tested) USB cable to connect to the PC.
The OS should detect a new USB device after connection of the camera AT the MOMENT the camera is switched ON ...
Nov 12, 2009 | Canon IXUS 960 IS Digital Camera
I installed from original CD and my computer running Vista does not find maxtor ll external HD. Is it compatable with Vista? why does it not find the drive?
Start "Device Manager".
Make sure that the USB devices are "ready" and "enabled".
Then, connect the external USB device.
Can you try the Maxtor external device in some *OTHER* notebook?
If it does not work, then the Maxtor device has a problem.
Nov 08, 2009 | Maxtor OneTouch II external hard drive...
Usb device not recognised
HI,
Is this the first time you connect your printer on that computer? This can be the USB port does not support a 2.0, or your data cable/printer cable is damage.
Hope this helps
Aug 29, 2009 | HP LaserJet 1020 Printer
FujiFinpix A607. Getting device not recognised when USBconnecting
make sure the software is unstalled via control panel, ad and remove programs, make sure there no mention of finepix now load the software first, then plus in the camera check the usb cable as well
Jun 14, 2009 | Fuji FinePix A607 Digital Camera
Apple ipod Noano 3rd generation 4gb
It could be that the interface on the IPod is bad or the IPod cable is bad. I would try another cable to see if that fixes the problem.
Jun 08, 2008 | Apple iPod nano 3rd Generation
Magellan Crossover GPS Logo
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
