I am trying to connect an xp machine to a server 2008 server via remote desktop and I get an error saying the rmote session was disconnected because there was an internal error in the remote computer licensing protocol. This is a new PC that the settings and everything were transferred from an older PC.
    President:
  • 2,185 Answers
To resolve this problem, follow these steps:
  1. On the computer that cannot open the Remote Desktop session, click Start, click Run, type cmd, and then click OK.
  2. At the command prompt, type the following command, and then press ENTER: NET START TERMSERVICE
  3. Click Start, click Run, type regedit, and then click OK.
  4. In Registry Editor, locate and then click the following key:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSLicensing
  5. Delete all the keys that are located under the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MSLicensing key.
  6. On the File menu, click Exit.
  7. Restart the computer.
Posted on Aug 06, 2010
  • Brian Meloy
    Brian Meloy Aug 09, 2010
    I did the above but still get the message.
How do i connect this terminal to windows 2003 server please give me the settings
Open Remote Desktop Connection loadTOCNode(2, 'summary'); To open Remote Desktop Connection, click Start, point to All Programs, point to Accessories, point to Communications, and then click Remote Desktop Connection.
Create a Terminal Services Connection loadTOCNode(2, 'summary'); To create a Terminal Services connection, follow these steps:
  1. Open Remote Desktop Connection.
  2. In the Computer box, type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
    Note: To connect to the console session of the remote computer, type computername or IP address /console.
  3. Click Connect.
  4. In the Log On to Windows dialog box, type your user name, password, and domain (if necessary), and then click OK.
Save Connection Settings loadTOCNode(2, 'summary'); You can save a connection as a Remote Desktop protocol (.rdp) file. An .rdp file contains all the information for a connection to a terminal server, including the Options settings that were configured when the file was saved. You can customize any number of .rdp files, including files for connecting to the same server with different settings. For example, you can save a file that connects to MyServer in full screen mode and another file that connects to the same computer in 800×600 screen size.
To save your connection settings, follow these steps:
  1. Open Remote Desktop Connection, and then click Options.
  2. Specify the connection settings that you want for this connection.
  3. On the General tab, click Save As.
  4. In the File name box, type a file name for the saved connection file, and then click Save.
Note: To edit an .rdp file to change the connections settings it contains, click Start, click My Documents, right-click the file and then click Edit.
Open a Saved Connection loadTOCNode(2, 'summary'); To open a saved connection, follow these steps:
  1. Open Remote Desktop Connection, and then click Open.
  2. Double-click the .rdp file for the connection that you want to open.
Copy Files Between the Local Computer and the Remote Computer loadTOCNode(2, 'summary');
  2. Type the computer name or the IP address of a terminal server or a computer that has Remote Desktop enabled.
  3. Click the Local Resources tab, select the Disk Drives check box, and then click Connect.
  4. Click Start on the task bar of the remote computer, and then click My Computer, or double-click the My Computer icon on the desktop of the remote computer.
    Note: The drives on the remote server appear with the drives on your local computer. Your local drives appear as driveletter on tsclient, where tsclient is the name assigned to your (local) computer.
  5. Locate the file that you want to copy, right-click the file, and then click Copy.
  6. Locate the folder where you want to paste the file, and then click Paste.
Log Off and End the Session loadTOCNode(2, 'summary'); To log off and end a session, follow these steps:
  1. In the Remote Desktop Connection window, click Start, and then click Shut Down.
  2. In the Shut Down Windows dialog box, click Log Off username, and then click OK.
Thankyou
Amit Bhardwaj
Skype Id:- amit.bhardwaj4
May 05, 2010 | VXL Instruments Itona CE Windows CE VIA...
I am keep getting error of '' can not find server or DNS error''.. But i am fully connected to wireless interenet through NETGEAR.
This error means there is no communication with DNS server which can be because of corrupt dns cache. This fairly common in xp but is easy to fix. Now since you are saying you are connected wireless this might be nic card message. Try to disable LAN driver from network connections in xp or network and sharing center in vista and windows 7 and see does it still give you the error. If there is no error you can leave it disabled but if still there you should only be able to connect to internet via IP address but not name like google.com. Try to open command prompt and run command ipconfig /flushdns. In vista you have to run CMD.exe as adminisrator by doing right click other wise it wont do it. Hope this helps.
Feb 28, 2010 | Computers & Internet
I am using a Xerox WorkCentre M15i connected to a server via a USB cable. I am trying to configure the scanner so that each user can perform a scan from the workstations without accessing the server...
There is a device called a Pocket Pro that attaches to the machine and you can then hook it via a RJ45 connection. I believe Troy makes that device. I have used it several times with success. Its basically a print server device.
Feb 02, 2010 | Xerox WorkCentre M15i Laser Printer
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
So you verified ICMP traffic isn't blocked and it appears the servers allow the netBios traffic to pass.
On the client machine, check to make sure the windows print and file sharing is installed and the machine isn't blocking netBios traffic.
Make sure TCP ports 137,139, and 445 are open on the xp machine and any devices in between.
It's acting like the TCP data is being blocked by the client machine.
HTH,
-Aaron
Sep 28, 2009 | Microsoft Windows XP Professional
This is an excerpt from a MS Technet page for error 53:
Resolutions: 1) if it is domain environment, check your WINS; 2) if it is peer-to-peer workgroup, enable NetBIOS over TCP/IP; 3) make sure the machine is running; 4) make sure file and Printer Share enabled on remote computer; 5) make sure client for ms networks is enabled on local computer; 6) make sure you type the correct name. 7) Make sure no firewall running or any security setting.
Pay close attention to #s 4 and 5 - I suspect XP pro might not be open enough.
Sep 28, 2009 | D-Link NetDefend DFL-700 Firewall
Cannot detect other printer in remote desktop connection
Hello my friend, regarding on your problem kindly check your system particularly your windows 2008 server OS. Kind reinstall the printer drivers then then shared it. Then after you share the printers kindly check the ip address of your windows server 2008 OS then go to the workstation Computer then click start button found in your task bar manager then click run. Then kindly type the "\\IP of your windows server 2008" where your printer drivers installed then enter. As soon as you can log in the Windows server 2008 menu environment then if you can find or see the printer icon then click the printers icon then right click then click connect. Let the system automatically installed the printer driver to your workstation computer. then as soon as your system finished installed the printer drivers then try to run and print if you can now print using network LAN.
Hope this solution able to solve your problem. If you need more assistance kindly rely to this post.
Thank you.
geo_jonas
Jul 17, 2009 | Office Equipment & Supplies
MS9520 serial connected to the terminal - does not send keys to the terminal server
Ok this is an old questions, but I had a similar problem recently. I found that I had to install Softwedge on the Remote computer.
I was trying to use the scanner over remote desktop. Remote dektop needs to have serial communication enabled. The computer that you are connecting to via RDP needs to have softwedge installed.
Nov 07, 2008 | Metrologic Instruments 9520 Voyager
Connection to server failed account ntlworld server pop.ntlworld.com protocol pop3 port 110 secure (ssl) no socket error 10061 error 0x800CCCOE. This message appears when I use my laptop which uses vista...
Verify the setting via Manage accounts on your XP machine (the one the email client works on) in whatever email client you use on it and verify and edit if need be the setting in your Windows Live Mail on your Vista home Laptop.
Jul 15, 2008 | Computers & Internet
How to limit remote access to a Termional Server
The best way to do this that I've found is to restrict the access via your firewall. Typically, Terminal server is listening on port 3389. So you would create rules in your firewall that will block any traffic to this port from IP addresses or subnets that you don't trust. While you're at it, you should shut down all other ports to everyone if you're not using them.
Mar 27, 2008 | Dell PowerEdge 1550 Server
Computers & Internet Logo
21 people viewed this question
Alun Cox
David Payne
David Payne
