Question about Refrigerators
NEED SPECIFICATION - Refrigerators
  • 525 Answers
For what make and model?
Posted on Aug 06, 2010
I bought new 2gb ddr2 with 800 mhz and its not working on my motherboard d102ggc2 can u plz help me with the solution
i guess you did not check the compatibility of the RAMs to your MB limitations....
the only solution is to return the RAMs and get the RAMs that is supported by your MB.....
the MB (D102GGC2) can hold only a max of 533 mhz and max of 1GB each in each slot of RAM....
so if you are trying to install one 2GB card of 800 mhz IT WIILL NOT WORK....
get TWO RAM cards of 1GB each (total 2GB) of RAM.... each of 400 mhz....
hope this helps...
Reg
Suresh
to check what your MB supports, look for the details below...
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-029352.htm
Intel® Desktop Board D102GGC2 Technical product specification circuit388.gif Product Specification
This product specification applies only to standard D102GGC2 boards with BIOS identifier GC11020M.86A. Changes to this specification will be published in the D102GGC2 Desktop Board Specification Update before being incorporated into a revision of this document.
pdf.gif D102GGC2 Technical Product Specification [PDF]
File Name: D102GGC2_TechProdSpec.pdf
Date: April 2006
This document is an update to the specifications contained in the D102GGC2 Technical Product Specification. It is intended for hardware system manufacturers and software developers of applications, operating systems, or tools. It contains specification changes, errata, specification clarifications, and documentation changes.
pdf.gif D102GGC2 Desktop Board Specification Update [PDF]
File Name: D102GGC2_SpecUpdate03.pdf
Date: November 2006
Apr 27, 2011 | Intel D102GGC2 Motherboard
Explain what a person specification is
specification:
A specification is an explicit set of requirements to be satisfied by a material, product, or service.[1] Should a material, product or service fail to meet one or more of the applicable specifications, it may be referred to as being out of specification;[2] the abbreviation OOS may also be used.[3]
A technical specification may be developed privately, for example by a corporation, regulatory body, or military organization, or it may be developed by standards organizations which often have more diverse input and usually develop voluntary standards (Voluntary standards may become mandatory if adopted by a government or business contract).
Sometimes the term specification is used in connection with a data sheet (or spec sheet). A data sheet is usually used for technical communication to describe technical characteristics of an item or product. It can be published by a manufacturer to help people choose products or to help use the products. A data sheet is not a technical specification as described in this article.
sourced from wikipedia
Apr 22, 2011 | Computers & Internet
How do i know i sound driver of my computer?
If you have the manual, it's should be written there. If you don't have the manual, search for the computer's or motherboard's specification. In the google search box, type in the system's name with "specification" eg. Hp Mini 210 specification, and look for the specification. You'll be able to find out the sound card and the sound drive codec of that particular system or motherboard.
The best way to get the specs is from the manufacturer's website. If you need further help, let me know.
Good Luck.
Thanks for using FixYa.
Apr 07, 2011 | Computers & Internet
I need mercury 865 motherboard sound driver for windows 7
Drivers Version Specification Size Note Download
A3.69 Audio Driver_Realtek 23.7 MB
dl_bu_dl.gif V3.6 LAN Driver VIA 823X 4.07 MB
dl_bu_dl.gif V1.0 VGA Driver 14.1 MB
dl_bu_dl.gif V4.55 VIA IDE DRIVER 1.41 MB
dl_bu_dl.gif V4.12 VIA SATA RAID Driver 6.93 MB
dl_bu_dl.gif V1.0 VIA USB Driver 3.03 MB
BIOS Version Specification Size Note Download
V1.0 050818S-BIOS 510 KB
Manuals Version Specification Size Note Download
V1.0 User Manual 356 KB
Dec 12, 2010 | Mercury P4VM800M7 Motherboard
I need the sensonic 5132's specification pls.
Do a model search on the internet.
Nov 18, 2009 | Logitech Webcam
WHAT KIND OF WIRES DO WE NEED TO HOKUP A LEXMARK X3350 ALL IN ONE PRINTER.
Standard Ports USB Compatible with USB 2.0 Specification (Type B)
Optional Network Ports Lexmark N4000e Fast Ethernet (Print Only)
Lexmark N4050e 802.11g Wireless Print Server (Print Only)
According to:
http://www.lexmark.com/lexmark/product/home/277/0,6970,204816596_653399443_473191701_en,00.html?tabId=1
Sep 10, 2009 | Lexmark X3350 All-In-One InkJet Printer
My humidifier is set at 40% but the humidistat reading never
Have you measured the amount of water dripping into the drain? The specification is 1 quart in 2 and half minutes. If it is much less, get your solenoid checked. I had the same problem and got it replaced and it works as per specification now. You also need to see how many minutes in an hour your furnace is actually running. The humidifier runs only when the furnace is, so the more it runs the better. The specification is 35% with the furnace running at 70%.
Jan 29, 2009 | Aprilaire 700 Humidifier
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
