Question about Galaxy Radios DX-44V 40-Channels Base CB Radio
This is something new to me, what do I set all the buttons and knobs to talk on channel 19,hi-lo band,10khz on or off ,pa-fm-am,e/a-f/b-g/c-h/d, e-tone thanks for any help anyone can give me.
  • 64 Answers
Radio On Volume comfortable Listening level Squelch Open (Hearing Noise) Mic Gain Up unless told by receiving station to reduce it. 10 Khz Off pa-fm-am set to Am e-Tone to off I believe this model has CB on Band C which is switch down on Low and C position you will know when you hear truckers on 19 which band is CB
Posted on Sep 12, 2010
What are the buts & nubs go to make the cb work which ones trun or push ?
Assuming you're talking about the Galaxy DX88HL, and assuming the mad has been done to reach the 11 meter band, you press the band button in, that put's you to the E-H banks, select the E/A bank which is high bank E. with the frequency counter on, it should read 26.965 for channel 1. If it reads 26.975, then your +10KHz switch is on, turn it off. you'll then be properly set for 26.965 (ch.1) - 27.405 (ch.40). You also have 5 "hidden" frequencies, these are at ch. 3, 7, 11, 15 and 19. To get to the "hidden" frequencies, go to any of the channels listed and turn on your 10KHz switch. Those frequencies are not attainable on radios that do not have a +10KHz switch or a clarifier capable of sliding that far over. To do repairs and for a full list of schematics, diagrams and so forth, I suggest this site, it has the most coverage of the Galaxy DX88HL as well as other galaxies that I've been able to find. http://www.cbtricks.com/radios/galaxy/dx88hl/index.htm .
May 25, 2011 | Galaxy Radios DX- 88HL Base CB Radio
Please explain a 10 meter am/fm radio
Okay.
You do set this up like a regular CB. The meters refers to how long the waves are. CB is 11 meters. So its very close. The antenna woud be tuneds slightly shorter. Use the SWR meter in the radio to calibrate just like you would a normal cb.
Now for the ABCDEF knob. each letter is 40 channels in the band. So A would be 1 - 40 channels, then B would be the next 1 - 40 channel frequencies. You use the frequency counter in the radio(providing that model has one) to tell what channel you are on.
Here is some info one the frequencies in the band.
Now for AM and FM. this is the type of modulation you are using for transmit and receive.
CB transmits on AM or SSB. Amplitude modulation or Single side band. Most CB radios only have AM. But some also have SSB. None will have FM.
FM is frequency modulation.
10 meter radios can have AM FM SSB and DSB depending on the model and options it comes with.
So your radio has 6 ranges for freqency. each is 40 or 50 channesl. Not sure what model you have. If it has 40 then you have 240 channel freqencies.
with AM and FM, you double that, because you can talk on AM or FM on all the channels. If you are on AM and some one transmits on FM unless they are really close, you will not hear them at all, but if you do with will just be garbbled noise.
Also Am and FM both work a little different with range etc.
Now, you may be able to talk on the CB channels as well. Cb starts at 26.965 MHz and ends at 27.405 MHz. The channels are all .010 MHz appart.
Hope this helps
Dec 09, 2009 | Radio Communications
FREQUENCIES
Typically, but not always, you can hold down a specific key on the front faceplate and hold it down while turning on the power. This will usually ONLY restore the AM channels from 9Khz spacing to USA 10KHz channel spacing, but I don't think it will restore the FM band; I could be wrong - do a google search.. Usually the FM band is Japan is different than ours, and there are some expensive adapters to upconvert/downconvert US FM stations, but not worth the money to add, in my opinion you should just buy a new tuner like the Sony HD radio tuner!
Apr 06, 2009 | Audio Players & Recorders
Need to know the normal use settings for the Connex 3300 HP. Changed trucks and wife cleaned the radio; I believe the settings all got messed up. Thank you very much.
turn the rf gain all the way uphave your pa fm am knob on am your band knob on your desired band hi rf power band hi or low depending on wich ever u want to uss
Mar 22, 2009 | Connex 3300 240-Channels Base CB Radio
I have a Ranger 6900F Jumbo
left to right,Volume,on/off(center) Squelch (outside)2nd knob is mic gain (center) this controls how much adio output you produce.. and rf gain,(outside) This adjust how sensitive the radio recieves.3rd knob is pa/fm/am This sets the radio up for using a public address horn if hooked up, or to transmit and recieve on am (most common) or fm.
The next knob controls what bands o channels you operate on .6 bands of channels with 40 channels each.The next knob controls the amount of echo and reverb you use when you talk.The center controls the echo and the outside controls the speed,or reverb effect.The next knob controls the talk back(so you hear what you sound like on the center control, and the outside controls how much power you put out.The next knob, the biggest one is your channel selector.The push buttons are top l to r are:1 is the dimmer switch for your lights,the middel top is noise blanker and automatic noise limiter. This blanks out a lot of static and outside electrical noise.the last top switch is a roger beep switch to turn it on and off. When it is on you will produce a quick beep when you unkey the mike. This was originally used to let the other people on the bands know you stopped talking.The bottom left shuts off the frequency counter(the numbered display ie27.185,the middle sets the meter to be used as an swr meter or a regular s/rf meter.the last on the bottom will boost the frequencet up100 kilohertz.if you go to the following url you can get more info:http://www.rangerusa.com/.
Hope this helps
Feb 07, 2009 | Galaxy Radios DX-95T Base CB Radio
Setting 3300 to basic cb oper.
On the 3300hp use band switch at position A band switch to hi
Dec 29, 2007 | Connex 3300 240-Channels Base CB Radio
Galaxy Radios DX-44V 40-Channels Base CB Radio Logo
449 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Marvin
Marvin
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
