Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon PIXMA MP140
Not functioning shows e 2 and does not feed the paper shows an error service occured. blinking led light
  • 6 more comments
  • no puedo configurar la impresora multifuncional canon pixma mp 130 por perdida del cd de instalaci├▓n
  • pufycuchilla Aug 17, 2008
    service error 5100
  • simplecutec Aug 18, 2008
    canon pixma mp 145 is e2 blinking same as the power button
  • crazyp Sep 12, 2008
    Bought one recently Pixma 140. printed for 2 days loaded from cd provided. Printers dissapeared from laptop cd cannot reload
  • Anonymous Jan 14, 2009
    service error 5100 cancel printing off then on againt ,if this doesnt clear error, see the printer manual for more detail...what is problem..
  • jebonm68 Apr 22, 2009
    I have an E 5 flashing on my Canon MP 140 Printer. Can you help? I also need a manual.
  • Anonymous Apr 23, 2009
    Unjammed the paper, and now the error lights just continue flashing with no results....
  • Anonymous Mar 20, 2014
    my canon ip1980 can't print, it has blinking led light alternately and displays service error code 5201
No puedo instalar mi impresora canon pixma mp 130 por perdida del cd de instalaciòn, como me pueden ayudar gracias.
Posted on Apr 27, 2008
Our alarm and green power lights are blinking and LED is showing E 2 3. Any ideas?
This error E2,3 or Error 6000 from your computer; means that there is a paper feed error. it can be caused by a faulty paper feed motor, or a dirty timing disk film. to solve this problem check the paper load section, look inside is there any foreing body that block the paper feed roller.
Dec 09, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
CANON ERROR E27
Canon MP140 Error Code injet printer reset procedure:
Canon waste ink tank problem.
1. Change the waste ink absorber
2. Reset waste ink tank counter
Go to the service menu;
1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.
NEXT
2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.
NEXT
3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode.
NEXT
4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.
NEXT
Each time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.
NEXT
Hit 4 times for waste ink counter reset.
The number of the Reset button pressing LED
0 time ... Green Power off
1 time ... Orange Service pattern print
2 times ... Green EEPROM print
3 times ... Orange EEPROM reset (EEPROM reset)
4 times ... Green Waste ink counter reset
On the end press POWER button to exit .
FOR USE IN : Canon PIXMA iP1200, Canon PIXMA iP1600, Canon PIXMA iP1700, Canon iP1800, Canon PIXMA iP2600, iP6210D, PIXMA iP6220D, iP6310D, Canon PIXMA MP140, Canon PIXMA MP150, Canon PIXMA MP160, PIXMA MP170, Canon PIXMA MP180, MP210, Canon PIXMA MP450, MP460, MP470, Canon PIXMA MX300, Canon PIXMA MX310, Canon PIXMA MX470
Jul 31, 2010 | Acer Office Equipment & Supplies
Service error 5100
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-6
Apr 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp140 error 42
hi,
prirweto-i-12
Apr 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My canon pixma mp140 error 2 and the alarm light blinks. Help me. JJF.
try to reset your printer ---
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Mar 09, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon ir 2022 digital copier error code E001
how many blinks do you see in the led indicator? if it is 5 blinks then the problem is the printhead. if it is 2 blinks, then problem is in the feeding mechanism. if the problem is the later, then you might have to bring the unit to an authorize service center to have it checked.
Feb 18, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Error code E5
hi dear
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Mar 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon mp160 E2; printer won't re-set
hi dear
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
Direct Printing
E22 Carriage error
E29 EEPROM error
try this methode
Methode 1
button pressing
procedures below.
procedures below.
that's all
thanks
cropp
Feb 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
1,777 people viewed this question
old marine
old marine
