Bra wire stuck under the drum. How do I get in to the drum to get it out.
    Champion:
  • 207 Answers
The only way without disassembling the machine would be trough wide rubber hose which connets filter housing and drum. If you're lucky you'd be able to reach it wit your hand or some tool. Still that would require a lot of work, luck and wouldn't come out without expenses for new rubber hose since they are usually glued to drum.
Posted on Apr 27, 2008
SOURCE: bra wire stuck in AEG washing machine
Hello, to fix this, what you should do firstly, is remove the machine from it's normal position, and then get a handyman to take off the back cover (which is not recommended by the manufacturer) and get right into the guts of the machine. Once you have found and identified the drum, internally, then open the waterproof cover, and note where are the parts and screws go. Keep digging the inside up until you ahave reached the bra wire. Alternatively, if the wire is still visivly poking out of the small holes in the drum, pull the wire out with pliers. Good luck! PS- If this information was helpful, please rate me either solved, thanks for trying, etc. Thankyou! Daniel Ballantyne
Posted on Oct 10, 2007
fanny
  • 146 Answers
SOURCE: Bra underwire stuck
Switch off machine and unplug it from the wall socket. Remove back plate and identify the heating element. It should be located at the bottom of the outer drum. Remove element and you will have limited access to the space between the drums. Rotate the drum slowly by hand untill the bra wire gets to the bottom of the drum. Remove obstruction with hook or long tweeser.
Posted on Nov 01, 2007
  • 135 Answers
SOURCE: Bra wire removel
Dont know what model you have. Search the net for a repair manual for your model machine. Some are downloadable. Then remove the tub to get to the bra wire.
Posted on Apr 12, 2008
  • 177 Answers
SOURCE: Bra wire stuck
you may not have to take the washer apart, take a good ligtht and look around inside the spin tub, if a part of the underwire is sticking thru, try and pull it out. Do not use the washer until the wire is removed or it actually could cut the tub and then the machine will leak $$$
Let me know the make and model if you need more assistance
T
Posted on May 24, 2008
  • 104 Answers
SOURCE: bra wiore inside drum
HAVE YOU A GOOD BRIGHT TORCH? IF SO I REMOVED MINE WITH A TORCH IN MY TEETH & A SMALL FLAT ENDED SCREWDRIVER, IF YOU CAN SEE IT TURN OFF ALL POWER TO THE MACHINE FIRSTLY THEN USING THE SMALL SCREWDRIVER COAX THE BRA WIRE TOWARDS THE NEAREST HOLE IN YOUR DRUM & THEN FEED IT THROUGH AS BEST AS POSSIBLE & THEN GRAB IT WITH EITHER FINGERS OR PLIERS IF IT IS A STRUGGLE TO PULL IT OUT.
DONT LEAVE IT IN THERE & THEN OPERATE IT AS IT WILL JAM IT & BLOW YOUR EXPENSIVE MOTOR WHICH ARE APPROX £80 OR HIGHER & YOUR PUMP IF IT JAMS IN THE BLADES BEFORE REACHING YOUR FILTER ..
Posted on May 22, 2009
Bra wire stuck in washing machine
You could try a very thin pair of twezers, or a very thin magnetic pick up tool,you might be luck.. if not the only other way is to remove the ruber door seal to get acces to the inside of the drum.
Dec 28, 2011 | Electrolux Refrigerators
How do I remove a piece of metal from bra which has got stuck under the insiden cylinder and drum
it completely has to be pulled apart and once you have done that you will probably find the bra wire while spinning around has ripped into the plastic outer tank so bad it will now leak and have to be replaced & this is the most expensive job to have done it sounds silly for a bra wire but you should honestly consider buying a new machine it often ends up cheaper to do so rather than spending 3/4's of the price of a new one fixing your one.
Jan 12, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a bosch washer machine which has got a bras wire stuck in the drum i think.When i run the washer now water is coming out from under the machine.
possibility of such a bra wire stuck in the drain valve or drain hose, you can check, ranging from filter sewage water to the drain valve (with drain motor). you should open the drain valve / motor assembly. wire bra might clog there. so that the rubber water valve does not close properly
Aug 05, 2010 | Bosch Washing Machines
Bra wire stuck between inner and outer drum how to remove Hotpoint WMF760
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Jan 24, 2010 | Washing Machines
Drum screeching when spinning?
could have some change stuck at edge of drum or the under wire of a bra even a screw or nail in one of the holes in the drum or worse a bad bearing!
Jul 01, 2009 | Washing Machines
Bra wiore inside drum
May 22, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Bosch Maxx WFL2061 Scraping sound when rotating the drum
under wire of a bra caught in drum , I have taken out hundreds,Close Ireland
Nov 12, 2008 | Washing Machines
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
Bra wire removel
Apr 12, 2008 | Washing Machines
Bra underwire stuck
Oct 31, 2007 | Bosch WFMC6401UC
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
