Question about GE Freezers
Defrost is not working on a side by side is there a fuse somwhere
    Guru:
  • 1,524 Answers
Bad timer
Posted on Aug 08, 2010
Where is the defrost relay button?
Frigidaire equips most of its refrigerator models with automatic defrosting capabilities. This means that owners don't have to set a calendar reminder to manually defrost. The internal automatic defrost control and timing mechanism is placed at the bottom of most Frigidaire refrigerators, next to the stationary panicon1.png that captures water - even the defrosted meltwater is automatically evaporated. You might be confused about how the defrost timer works, thinking it is broken. Frigidaire understood this might be an issue for some owners and suggests double-checking the defroster for normal operation because it may not be malfunctioning at all.
Read more: http://www.ehow.com/how_12165725_troubleshooting-frigidaire-defrost-timer.html#ixzz32x8RyDGe
May 27, 2014 | Frigidaire Ffhs2622mh 26 Cu. Ft....
My freezer is not cold. The temperature dial reads 1-5 then an igloo and a snowflake. Do I put it on the snowflake to get it cold or the igloo?
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Take care in solving the problem....
May 01, 2011 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Kenmore Freezer Model 253.26732104 Compressor
the defrost timer may need reseting. when the defrost is on, it cuts power to the compressor so they don't run at the same time. it's usually behind the bottom front grate on the right side. also check the main circuit board. there's a fuse on it.
Jul 31, 2009 | Kenmore Freezers
Fridge not getting cold
you have a defrost problem.when you open your freezer door and look at the back panel look and see if their is frost built up.if so that means you do have a defrost problem.you will need to pull panel off and defrost coils.then you can check your defrost thermostat which is round and has 2 wires that go to it.it sits at the top of coils.see if it seperated.if so that is your problem also check defrost heater see if any breaks in it.if those check out then could be defrost timer which is located in ref.side.it would help to know what brand it is.it sounds like a side by side ref,but dont know what brand.
Mar 24, 2009 | Freezers
Freezer/refrigerator
Refrigerators with an evaporator (called a humid plate on this type of refrigerator) in the refrigerator section are called a semi-automatic defrost. This means that the freezer section occasionally needs defrosting but the refrigerator section defrosts by a means called "heat leakage defrost". How it should work....
the cold control, (the electrical device under the dial), leaves the compressor off for long enough for the plate to melt off each cycle.
If yours is not melting off perhaps you have a faulty control or you have it set too high. hope this help
Oct 07, 2008 | Frigidaire Freezer Refrigeration White...
Turbo air freezer
Check the time setting on the defrost timer. It may not be set to the correct number of minutes for defrost. Compare it with the side that is working properly for the right time of the cycle.
Jul 25, 2008 | Freezers
Water is building up in the bottom of my side by side freezer and freezing.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
May 07, 2008 | Freezers
Freezer leaking water
Apr 09, 2008 | Freezers
Frost Free Freezer
sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 04, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
FREEZER SECTION WORKING OK, FRIDGE SECTION NOT WORKING
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
Jan 22, 2008 | Freezers
Freezers Logo
42 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
