Question about LG 24 in. LDS 5811 Built-in Dishwasher
Heated plug after about60 minuts and stop working and turn off
  • 4 Answers
Open the front door panel and check to see if your wires have melted into the black spray on insulation. You need to free them and check to see if any are broken, if they are cut them, splice them back together. Then insert the wires into a cut bicycle tube and put the door back on. Try it and see if this fixes your problem. You are not the first to have this problem.
Posted on Aug 07, 2010
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
My electrolux vacuum, model 4870 just stopped while I was vacuuming. Now it will not go on. It was working just fine a few minutes ago, then just stopped. Any ideas
it may be over heating.Check to make sure your hose and power nozzle are not plugged..Simply turning machine on without the hos then putting hose on while running and see if the motor sounds different,ie.winding up higher.....if this doesn't help try changing the bag
Mar 07, 2015 | Electrolux Vacuums
R=8 128 Code on Pentair Mastertemp Heater what does it mean?
check manual bypass possible overheating or running out of gas
Apr 10, 2012 | Pentair Mastertemp Heater
I have a Maytag Neptune model number MDG9700A gas dryer...When I first turn the dryer on the dryer will get hot for about minute then the gas turns off and will not heat up again...It glows fine after...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Maytag Neptune MDG9700A Gas Dryer
Neptune dryer mde9700ayw dryer is not spinning and no heat. the timer still working. it stopped with 8 minutes left.
Have you tried un-plugging it and waiting for 5 minute before plugging back in to allow it to re-set?
Feb 06, 2011 | Dryers
Frigidaire crown gas dryer runs fine but after about 10 minutes it turns itself off and i cant turn it back on for about an hour
From the description you give the most likely cause of this problem are bad gas coils or a bad gas valve.
You say you see the flames for 10 minutes before it stops heating but you don't mention if the igniter is continuing to glow. One thing we need to know is if the igniter continues to cycle on and off when the dryer stops heating.
There is a small square plug on the front panel you can remove to try and visually check if the igniter is glowing.
The problem won't be the thermal fuse or one of the thermostats. Once the fuse is open the dryer won't heat but it won't start to heat after 20 minutes.
After the dryer runs ten minutes and stops heating then check if the igniter is still cycling on and off. This is important because if the igniter is working then the thermostats and igniter are okay.
When the igniter glows at some point you might hear a click and the igniter would stop glowing. The click is from the flame sensor and after the click and the voltage is removed from the igniter at the same instant the voltage is applied to the gas coils and you should get a flame.
You might hear a hum, buzz or vibration from the coils when this happens. If the coils seem to react to the voltage but there is no flame then most likely the gas valve is bad. If the coils don't do anything then most likely the coils are the problem. The gas valve and gas coils can work for 10-15 minutes and then heat up and stop working till everything cools down.
One other thing I must tell you about the gas coils. Here is a link to the gas coils you will need. These are the new style that will last quite a bit longer the the older one. The coils are like the spark plugs in your car. The will need replacing in time due to wear. Below is a video to walk you thru the repair process.
utube.png You-Tube video "RjonjNitfVk" placeholder
Jan 09, 2011 | Frigidaire GLGR642A Gas Dryer
My MAGIC CHEF MCO153uw stopped working. It heats
This sounds like a thermal protector is turning the microwave off. If I were to hazard a guess, it would be the magnetron (produces the microwaves) is overheating causing the shutdown. If the fan was not running it would create the same condition by causing the magnetron to overheat.
Nov 14, 2017 | Magic Chef CMV1000B Microwave Oven
I plugged my djx 700 into a club system, within minutes it was boiling hot, it did not stop working but i only used it for 30 minutes, i'm using it for 7 hours on friday night in the ame club, will it stop...
Suspect a ground problem someplace in the system.
Make sure your system is plugged into exact same recepacle that anything else you connect to is plugged into.
Also make sure a spot light is not heating it.
Oct 28, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 minutes then turns itself off automatically how do i stop this? My HP laptop keeps shutting itself off after...
hi,
Please check for the exhaust,is it coming properly and check the bottom of the Notebook is it heating ?
If heating then this is the issue with the processor fan.
If the temprature is normal then check in BIOS(leave the system in BIOS mode for 8 minutes) if then also it is turning off surely this is the heating issue.
If above mentioned is not working please revert.
Feb 09, 2009 | HP Computers & Internet
Faulty washing machine
if its no heat there only 2 items it can be heater element or the thermostats u could test the element by replacing the plugged in wires with wires that hasve a plug on place the wires into right places turn the plug on and if the element works it will start to glow turn it off as soon as u see it glowing from the inside of the washer also u can check the thermostats by dropping them into hot water and u should hear them pop
Nov 18, 2008 | Washing Machines
LG 24 in. LDS 5811 Built-in Dishwasher Logo
43 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
