Question about Weather King 10AJA4801AH Air Conditioner
I need the wiring diagram for a weatherking 10aja4801 4 ton outside condencer. Thanks
farfield
  • 462 Answers
SOURCE: need wiring diagram for 1980's 3 ton package unit
I assume you know if this is correct voltage and single or 3 phase, and whether it will fit your application or not, how is the duct work going to attach, how many people will be in the conditioned area, what is the building made of, how much insulation is has...
A little more to it than just "turn it on".
If you get the models and serial and can contact the manufacturer or their representative you might get a wire diagram. Most any package unit would do. As long as you keep the original equipment controls. If you "patch" it up it may be hazardous by not having safety's where it was designed for. Or for instance It may have a anti freeze thermostat. By passing this could lead to coil freeze up and compressor damage. Leaving out a pressure switch (if any) may do the same or could become dangerous to people in the event of fan motor failure. A low temperature fan speed switch may not be needed now unless you plan to run the AC in below 55'f.
And a few dozen other factors that might need to be considered.
If you feel confident after this then contact carrier.
Please rate me as high as you can and thanks for using fixya.
Posted on May 19, 2009
TheMobilian
  • 8220 Answers
SOURCE: i need wiring diagram for an old coleman suncutter/whole house a/
yeller cool
red common
white heat
green fan
Posted on Jun 06, 2009
jumptrout51
  • 3361 Answers
SOURCE: Weatherking 3 ton Run Capacitor
Could be; age,lightning,power surge,defective wire,loose wire,tight compressor. Capacitors fail sooner or later. They are like batteries they do not last for ever.
Posted on Aug 04, 2009
  • 548 Answers
SOURCE: How many tons is a 10AJA3001 Weatherking A/****?
http://www.furnacecompare.com/air-conditioners/rheem/10AJA3001.html
Posted on Sep 05, 2009
SOURCE: I HAVE A WEATHERKING MODLE WAKA-037JAZ OUTSIDE AC
It appears you may have a 5ton unit, if your house is over
2000sq. feet then Im guessing that 60 thats appears in
the model number is equal to 5ton. 12,000 btus per ton
of cooling
Posted on Feb 28, 2010
WHY does it not cool for more than 10 minutes, than shutsoff
low refrigerant charge look at the sight glass if you see bubbles your low on freon. check your condencer coil outside clean the coil with condencer coil cleaner spray on wait 10 minutes hose off. most times a dirty condencer coil is the culprit
Jul 28, 2014 | Carrier 519exx042000aaaa 3-1/2 Ton Ac/hp...
Trying to get info (tonnage seer rating) on a weatherking mod# 10ajb48a01 condencing unit to find a matching evaporator coil and cannot find anything on internet
This is a 4 ton model condensing unit. You can go up 1/2 ton for the evaporator, meaning a 4 1/2 (A) coil will work just fine and allow a bit more cooling capacity.
Sep 10, 2011 | Weather King 12AJA4801AH Air Conditioner
My weatherking outside compressor isn't big enough to handle my cooling needs. It is 1.5 ton unit, can I put a bigger ac unit onto this one without changing my heating system which is sufficient?
if your indoor unit is 1.5 ton the answer is no
if your indoor unit is 2.0 ton then you can jump to that size.
Note :your duct system may have been designed for a 1.5 ton and may need to be reconfigured for a size increase.
Your hvac contractor should know this?
Jun 14, 2010 | Weather King 10AJA4201AH Air Conditioner
Wiring diagram for contacts on the outside unit
I have a wiring diagram I can send you. I took a picture of mine. Mine is a Ruud Achiever PNE 2 ton.
May 23, 2010 | Ruud Matching Split Air Conditioner
What size ac ?
The condenser is 2 ton or 24 thousand btus.
Mar 08, 2010 | Heating & Cooling
I HAVE A WEATHERKING MODLE WAKA-037JAZ OUTSIDE AC UNIT WITH SPLIT GAS FURNACE-WHAT TON IS THIS UNIT
of cooling
Feb 28, 2010 | Weather King 10AJA6001AH Air Conditioner
Aug 04, 2009 | Weather King Heating & Cooling
Weather King 10AJA4801AH Air Conditioner Logo
159 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
