Question about Sony Handycam® DCR-TRV250 Digital-8 Camcorder
Camera wont let me tape or play back. Bells go of and C:31:22 flashes. I have a head cleaner cassette but the camera wont let it play
SOURCE: reinsert cassette
OMG!!! OMG!!! OMG!!! i cannot believe this tip worked i was soooo amazed!!!!!
Posted on Sep 17, 2007
ctf1800
  • 4402 Answers
SOURCE: "Reinsert the Cassette"
go here
Posted on Jun 11, 2008
renx
  • 71 Answers
SOURCE: Cannot find a head cleaner for Sony Digital 8 (DCR-TRV460)
Yes you can clean the heads. It's a delicate procedure, but, requires no disassembly. But, I'm curious about your mention of "blurry spots." Typically, on a digital camera, the video when the heads are dirty, will either just appear as a white screen, or, will come out blocky and glitchy (like poor satellite reception). "Blurry" would result from a dirty lense or filter. However, to clean your heads, I would run to Radio Shack and buy cleaning fluid refils. Take a Qtip and dampen it with the cleaning fluid. Open the camera, remove the tape and look for the video drum. Lightly rub the Qtip along the drum horizontal to the spin direction (not across the grain). Turn the drum and clean until you have swept the entire circumference.
Posted on May 02, 2009
SOURCE: loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Posted on May 06, 2009
  • 3 Answers
SOURCE: error code c:31:22. beeps. flashes eject sign
This is a very common problem with many of Sony cameras. Please tap the camera at its bottom and left side a few times after removing the battery. I am sure that its going to work for you.
I have this problem repeatedly coming up for my cam and I solve this by this home made remedy !
Posted on May 29, 2009
Not recording? Wont let me retrieve anything. Says end of tape with a blank screen.
sir,
Did you test the previously recorded photos, or with a recorded cassette? if it is not showing the prerecorded pictures it means there is some problem with the video head, eject the cassette look the head drum carefully, if there any dirt on the head, clean it with a head cleaner cassette.(put the cleaner cassette in and play it,it will play for 3 minutes only, rewind the cassette and ply several times). some old cassette also will not give good result, if your system too old, the head may be weak so that you have to replace it.
Feb 02, 2016 | Video Cameras
Handy cam hi8 dcr
Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Aug 26, 2013 | Sony Handycam DCR-TRV280 Digital Camcorder
I have a Canon ZR90A and started noticing horizontal gray lines displaying across the screen when it plays back. What is causing this?
The most common cause of horizontal lines during playback is dirty heads/tape path. If you have a head cleaner tape, try playing it for about 5 to 10 seconds and then try your tape again. Repeat as necessary. Try not to run the head cleaner for long periods of time because you may wear down your heads quicker (cleaning cassette is somewhat abrasive). If you do not own a head cleaning tape, I highly recommend purchasing one. Sony (in my opinion) makes the best miniDV head cleaning cassette. We use this brand in our repair shop and they last for years. I have posted a link to the particular tape I am speaking of. Your local camera/camcorder shop may have these for sale.
http://www.amazon.com/Sony-DVM12CLD-MiniDV-Cleaning-Cassette/dp/B0000632H7
Hope this helps you.
www.austintelstarservices.com
Sep 12, 2010 | Canon Video Cameras
Bands or lines on screen during playback
Hi tlaufer ,
              According to the symptom this problem is related to the VIDEO HEAD, As you earlier try to clean the head but no results, Please open the cassette compartment of your camera (as when you insert the cassette in it) for 30 mins (remains open cassette compartment) Actueally some time due to moisture head get durt.
After 30 mins insert the cassette and play it. Hope it will start work again fine.
      But if no result from the said procedure then there must be a damadge of point of the head, in this condition you have to replace the VIDEO HEAD assembly.
Thanks for using fixya.
May 23, 2009 | JVC GR-D73E Mini DV Digital Camcorder
When I insert a tape, the screen flashes "reinsert cassette".
Hit your camera several times with a flat hand (bottom, tape side). Its strange but my problem was solved. On internet I found maybe 10 or 15 other people who did the same.  Really works!
Apr 05, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Play back problem
Your camera playback heads appear to be dirty. You can purchase a head cleaner cassette from an electronics store or take it to a service centre where they will clean the heads.
Check that the tape itself is not damaged, as this can cause the same symptoms.
Jan 03, 2008 | Sony Hi8 CCD-TRV138 Camcorder
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC-GR-D371U
Sep 25, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Panasonic NV-DS27 - "playback blank"
try to clean the video head using a blank new tape and fast forward it 5 times if needed...dont use a video cassette cleaner it will ruin your video head...
Aug 01, 2007 | Panasonic NV-DS27B Mini DV Digital...
Open Questions:
Sony Handycam® DCR-TRV250 Digital-8 Camcorder Logo
19 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
