Question about Belkin (F5D7633UK4A) Wireless Router
How do I make my router secure with a password?
How do i find the security code for a netgearwgr614 router
For finding security code of Netgear WGR 614 router follow the steps-
1. Login the Admin.
2. Click on Advanced
3. Go to the Administration
4. Click on Set password
5. Enter old password.
6. Enter New password.
7. Repeat New password.
See in images:-
Not finding security code visit:- Netgear Router Tech Support Number
Feb 13, 2015 | NetGear WGR614 Wireless Router
Forgotten password for wifi network
Which operating system ??
Your wireless Internet password is the encrypted security pass phrase that was set up when you installed your wireless router.
Your router allows you to access the Internet.
If you have access to more than one wireless network, you may need to remember multiple passwords.
If you happen to forget one password, you have two options: reset your password or locate the current password.
Windows 7 allows you to view the security characters of all your wireless network passwords.
Click the "Wi-Fi" network icon located on the Window's taskbar.
Right-click the name of your network's "SSID" name and select "Properties" from the drop-down menu.
Click the "Security Tab." The network security key is now visible but unreadable.
Click the "Show Characters" check box and this will reveal your wireless password.
http://www.thewindowsplanet.com/939/how-to-recover-wi-fi-network-key-in-windows-7.htm
or
Reset My WiFi Password
Wireless networking is a common feature in homes and offices.
Wireless routers provide access to a single Internet source, and wireless passwords ensure that only select users can access the network.
If a password is forgotten or lost, the password can be recovered or reset by accessing the router's Web-based settings menu.
Most wireless routers also have a reset button, which is capable of returning the router to its default settings which includes resetting the password.
Connect to your Wi-Fi or attach your computer directly to the router with an Ethernet cable.
Open your Web browser.
Enter the default address of your router.
The default address is listed in your user manual or on the product website.
Linksys and 3Com routers typically use "192.168.1.1" while Netgear routers use "192.168.0.1."
Enter your username and password.
Many routers use "admin" for the username and password by default.
Locate the wireless security settings. Disable the wireless security.
Reset to Factory Defaults
Locate the reset button on your router.
Typically the reset button is a small indented hole on the back of the device.
Insert a long thin object such as a paperclip and hold down the reset button for 30 seconds to revert the router to its factory default settings.
Locate the wireless security settings and add security as necessary.
How To Reset Your Router's Password
http://www.lostintechnology.com/how-to/how-to-reset-your-routers-password
Jan 06, 2014 | Computers & Internet
Have a linksys router trying to connect need default password or cisco password
By default, the router has a SSID ID of 'linksys', with *NO* security, and *NO* password. Configure the router to enable security, and to set the SSID and to set a password.
Sep 15, 2012 | Linksys E2500 Wireless Router - Ieee...
How can I secure my wirless wiht a password/security key?
Router passwords can easily be learnt of by other users in homes or offices. So make a case-sensitive password .Just check the few steps to secure your wireless router......how to secure your wireless router
Sep 03, 2012 | Linksys Wireless-G WRT54G Router
Hello Need to secure this router but don't know password
hello
if you dont know tghe password you have to reset the password to its factory setting and that way the password gone also, at the back of the router there is small button for reset press that one and it will reset.
thanks
Mar 08, 2011 | Linksys Wireless-G WRT54G Router
I am trying to put my brothers lap top on my wireless, I put in the pin but now it ask for the security password
The security password is the password for the router,If you have forgotton the security password there is a reset button in the back of the router Press and Hold for 10-15 seconds/Then give it 1 minute to reboot. However this will reset the router to default settings so if it is secure it will be unsecure/ Here is a link to show you how to secure the Belkin router. Hope this helps
http://www.ehow.com/how_4829036_secure-belkin-wireless-router.html
Oct 02, 2010 | Belkin Computers & Internet
Router password
>If you're trying to put password for the Router, then type "http://192.168.0.1" into the address bar, then hit "Enter."
>Use "Admin" as the username and leave the password blank when the login screen appears.
>Please click on Administrator settings and change the User Name and Password.
If you're trying to put a password/secure the Wireless network, then follow the steps:
>In the Router setup page, click on Wireless Settings.
>Under Wireless Security Mode, select Security Mode: WEP/WPA/WPA2.
>Enter the Security Key manually or enter the Phrase to generate the Security key automatically (only in WPA/WPA2) and save the settings.
>Please note the Security Key to connect to the Wireless Networ.
>The Wireless is secured now.
Good Luck!!!!
Jul 02, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
How do I secure my router
For securing your router do the follwing:
1. Change your admin password on your router (you must setup a difficult password ... something like Admin015^^#2X)
2. Create Wireless Password using WPA or WPA 2 tehnology and setup a strong password.
3. Activate firewall on our router.
Mar 05, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
When i try to connect to a secured wireless connection my laptop asks for a device ownership password, that is either printed or labeled on the device. i cannot find where this password is?
The password is not a preprinted password, it is a security password on your router. You need to log into the router and check your wireless security to see what you have used. If wireless security password is blank (use wap personal security), enter a password and then use the same for your computer when asked.
Please leave feedback if this solves your problem, otherwise send more information about your problem.
Feb 11, 2010 | Linksys WRT160N Wireless Router
Can't connect to internet with my router when i use password
you can access your router with following link
http://192.168.2.1
then type user name as "admin" and password "admin" or blank or "password'
then check wi fi security and check encryption password .also check there is anyt MAC security enabled?
Jul 11, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Belkin (F5D7633UK4A) Wireless Router Logo
20 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
