Question about Toshiba Satellite 1005-S157 Notebook
How to open case to fix ac jack? Need to re-solder
2 Suggested Answers
SOURCE: How to open case Toshiba Satellite L355-s7905
Hi I have the same laptop and had the same thing happen. I am not a tech, just some dude that is handy and has "messed" with hardware for a bit. So this advise is "USE AT YOUR OWN RISK", I'm not responsible for anything. Well with that said here you go.
Remove the batter for safety. As you go keep the screws separated so you don't have to remember which is which when you put it back.
Flip the laptop over and you will find about a dozen screw holes labeled F7. You need to remove all of these to open the laptop. You'll find some running along the back edge of the laptop as well.
In the battery well, you'll find some more screws labeled F4, you should remove these as well.
There is a slider screw towards the right center of the machine that helps hold the cd bay in place, you don't have to remove this one, but you can in the even that you need to move the bay to gain better access to the DC jack.
Once you remove all the screws, flip the laptop up right. Open the screen as if you were going to use it.
Along the top of the keyboard, you will see that the bezel edge has a break away section the same with as the key board.
Using a small flat head screw driver pry it open from either the left or right side, and continue unclipping it across.
This will expose four very small screws. Remove them making sure to keep them safe, as they are holding your keyboard in place. Once you remove them, slowly seperate the keyboard from the body of the laptop. You will find a flat wire connected to the mother board from the keyboard. You can use a toothpick to slowly slide out the white edge from the brown connection bridge. Once you slide the white plastic peace away from the brown the wire will come out easily. BE CAREFUL with the wire since it is very fragile
Now you should have the keyboard separated from the laptop, put it in a safe flat place and continue.
On the left side hand of the laptop body is a card slot, use it as a finger hold to gently but firmly pry the laptop open. It is held together by clips running along both side edges and the front edge. These can be a little tough to open, so apply slow gentle force till you hear them pop open.
Before you pull it apart after unclipping it, use the same method used to remove the keyboard flat wire from the mother board connection on the three connections holding the top part of the machine to the motherboard. You'll find two towards the bottom center and one at the top left corner. Play close attention to the small flat white one as this is VERY fragile and the copper flanges at the end can bend very easily.
At this point you should be able to freely separate the top half (cover) of the pc from the bottom. Exposing the insides.
You'll be able to easy work with the dc jack now, in my case it was the plastic housing of the body of the laptop that broke. I held it in place with a dab of hot glue.
If you find that the CD drive is in your way, you can remove the two small black screws on either side of its copper connector, then lift the back of the bay up of the body and slow pull it and lift towards the left.
Work backwards to put it back together.
Posted on Mar 22, 2010
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
Faulty connection for AC power adapter on an 8 month old yamaha digital keyboard psr-e413
If the adapter is faulty I recommend replacing it with the exact one for your keyboard. Any Yamaha music dealer should have one. If it is the jack in the keyboard that the adapter plugs into that is faulty it can be fixed. It is soldered to the circuit board and the solder joint has likely failed. You will have to carefully disassemble the case and maybe take the circuit board out if the solder side isn't accessible. Once you can see the solder joint wiggle the jack to see where the break is. You will need to resolder it. If the jack is broken ( the center pin in the jack sometimes breaks) you will have to desolder it and take it to a good electronics store to obtain the correct replacement and then solder it in.
Aug 23, 2010 | Music
When you move the computer working under external
issue with the ac jack. It has a loose connection. you will need to open up the laptop and remove the board to re-solder the AC jack.
Jun 02, 2010 | Acer Aspire 3000 Notebook
ACS295 speaker cable to subwoofer, one of the pins of the connector is broken, how can I fix it or get a new connector?
if connector is broken, you need to buy a new connector, but it takes a little handwork and some tools a screw driver some electric iron and solder.
u need to open subwoofer case and check for the connector is soldered in a board is 2 jack 3,5mm female connector and one red mini-DIN connector. replace the connector take a attention on soldering the connector, dont damage the board wires and pins, if the iron above 300ºC.
take a special attention on electrostatic discharge, normaly burns sensitive boards.
Jan 30, 2010 | Altec Lansing ACS 295 Computer Speakers
Open the back of tascam gtr1 to fix the input jack
0. If available, use grounding wristing band to prevent ESD damage.
1. Remove SD card and battery.
2. Remove 2 screws in battery compartment.
3. Slide back panel upward towards top of unit and it snaps off.
4. To remove front panel, gently pry two tabs at top between microphones and front panel pops off (jog dial and washer will also pop off).
5. Microphone jumpers must be disconnected from PCB headers to completely remove top panel. (Note: guitar jack solder pins are accessible without removing microphone jumpers, may be able to re-solder directly. )
Jan 01, 2010 | Tascam Audio Players & Recorders
I can't charge my battery nor use the laptop.
SOUNDS LIKE U BENT THE COPPER WIRE INSIDE CHECK MAKE SURE THE WIRE INSIDE THE PC JACK IS STRAIGHT.SOLDIER COULD HAVE CAME LOOSE ALSO.
Oct 27, 2009 | Gateway MX6214 Notebook
Cant use my adaptor
this seems to be a common problem. I have some experience soldering, so I opened up the case and replaced the part with a Radio Shack DC jack, soldering the tabs to the motherboard with insulated wire.
If you know someone who can solder, this isn't that hard a fix, once you figure out how to open up the case (in addition to the screws visible outside the case, there is one underneath the keyboard. Remove the faceplate over the speakers/HP Now buttons, then you can remove the keyboard.
Oct 12, 2009 | HP Pavilion ze4125 Notebook
Ac adapter connection is worn out, can it be fixed
The AC adapter jack on the back of this notebook (and many others) is susceptible to damage. Extra care must be observed whenever moving / sliding or lift up and setting the notebook down while the AC adapter plug is connected to the jack. Any force on the plug - be it left, right up or down can cause the jack's soldered connections to break free from the motherboard inside the case. Once this happens, the internal battery will no longer receive a charge and when depleted, the notebook will not start up. A way to check if this condition is present is to gently wiggle the plug while connected to the jack. Pay attention to any AC Power indicator light on the notebook. If it flickers, the connection is failing or failed.
This common failure is repairable, but it is not for the faint of heart. The disassembly of the notebook is required. Patience and jeweler's screw drivers (and sometimes other specialty tools and instruction guides) may be required just to open the case. Once opened, a thorough inspection of the jack's solder connections and circuit traces must be performed to identify problem points. This may require further disassembly of components. Inspect both sides of the motherboard for damage. It may be possible to simply "touch up" the broken connections with a clean, tinned 20 or 30 watt pencil soldering iron. A complete replacement of the jack is a better way to go though. The jacks are under $10 on eBay but this work is not for a DIYer that isn't willing to have the notebook reduced to the status of "paper weight". There are those on eBay that offer to perform the entire repair for about $100 when last checked, and is probably a better bet than DIY first time soldering application. Of course, the notebook manufacturer has the ultimate repair shop - but is probably ultimate in cost, too.
Aug 29, 2009 | Acer Aspire 1640Z Notebook
In put jack has disappeared inside the unit, can't charge battery. Can this be repaired?
it can be repaired, what you need to do is open the unit, and be careful not to loose the ac connection, and its simply a case of soldering the disconnected jack on to where it has fallen from. it may not be that damaged it may just be bent out of place.good luck.
Aug 16, 2009 | Protron PDV-288 7" LCD Portable DVD Player
Help!!!!!!!!!!!!!!
It's probably the power socket on the laptop not the power jack on the AC adapter. You need to open the laptop by removing the casing screws. Then remove the motherboard from the base so a new socket can be soldered on.
Apr 02, 2008 | Sony VAIO PCG-V505EC Notebook
Toshiba Satellite 1005-S157 Notebook Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
