Question about Fujitsu Siemens LifeBook T5010 Tablet PC
It wont turn on and there is a blue flashing light
Asus tablet zs800 won't turn on
Make sure the power cord is plugged into the computer and the wall and if it still wont turn on try wiggling the power cord connecter where it goes into the tablet .or hold the power button down and see if any lights flash on at all
Apr 21, 2017 | ASUS Tablets & eReaders
I cant get help cause you wont give me any. I have wasted almost an hour asking the same question over an over.
You would get better response if you ask just once and provide all the details available. For example, is the screen flashing blue, or another light? Exactly which model Samsung Tab E are you asking about? Have you tried contacting Samsung tech support?
Dec 01, 2016 | Samsung Tab Tablets & eReaders
I have an Apple IPad Pro. I bought a Bluetooth Keyboard Case from Amazon. I need to know how to get started. There doesn't seem to be an instruction manual. I'm in unknown territory.
It's fairly easy to set up usually. With the keyboard powered on there is usually a button that turns bluetooth on and a (usually) blue light will start flashing. At this point on the iPad you look in the bluetooth settings page and look for the keyboard to appear in the available devices. Tap the link to it and follow the instruction. The blue light should stop flashing and remain lit and the iPad BT settings will show that the keyboard is connected.
Oct 23, 2016 | Apple Tablets & eReaders
Proscan tablet won't charge and flashes blue screen while I try to turn it on ?
Go to you tube type in your Question all of it MAKE & MODEL should be included in it , a page should appear check out the video's having your tablet to hand and then follow instructions given . Hope this helps .
Dec 25, 2015 | Tablets & eReaders
My mx android box is blinking on the top of box but the main blue light does not come on so it does not work help.
try and replace the hdmi cors, it happened to me so u went out ans got a new one Nd it workes fine
Aug 23, 2015 | Tablets & eReaders
I have a 9.7 android impression tablet and it won't come on there is a blue flashing light on it and that's it
you have to turn it off and turn it on again and go back on it and then it shoul stop.
Feb 15, 2015 | Tablets & eReaders
Will not power up
Connect your tab to computer and do a firmware reset, in android term reinstall the rom.
Jan 09, 2014 | Acer Iconia A100 Android
My hp paviliOn tx2500 touchscreen laptop monitor will not turn on. The caps lock and numb lock lights flash on and off, and the blue lights around the screen work, and I can hear it turn on, however the...
cap lock & num lock flashes are an error codes
LEDs blink 1 timeCPUCPU not functionalLEDs blink 2 timesBIOSBIOS corruption failureLEDs blink 3 timesMemoryModule error not functionalLEDs blink 4 timesGraphicsGraphics controller not functionalLEDs blink 5 timesSystem boardGeneral system board failureLEDs blink 6 timesBIOSBIOS authentication failure
Jan 03, 2011 | HP Pavilion tx2500z Tablet PC
Battery light stays on even after comp is turned off or the battery charger is unplugged
hi, sounds like you need to replace your hard drive, blue screen of death means 2 things bad memory or hard drive regards
Aug 19, 2007 | IBM ThinkPad X41 Tablet PC
Fujitsu Siemens LifeBook T5010  Tablet PC Logo
77 people viewed this question
Top Fujitsu Siemens Tablets & eReaders Experts
Lakshman P
fyigen
Laxman Bisht
Laxman Bisht
Are you a Fujitsu Siemens Tablet and eReader Expert? Answer questions, earn points and help others
