Question about LG Xenon GR500 Cell Phone
Won't read new memory card - LG Xenon GR500 Cell Phone
  • 677 Answers
Hi,when a memory card does not read on a phone, it means that the memory card is bad or is not compatible with the phone.
If the old memory card being used before works, that means the new memory card is bad and will need to be replaced.with another.
Have a nice day.
Posted on Aug 06, 2010
My memory card is not working
Memory cards, also called memory sticks or MS cards, can create problems with a computer. Sometimes, a computer will not read the card or errors cause problems when removing files from the card to put them onto the computer.
Problems range from a virus on the memory card to inappropriate software on the computer. Fixing the problem partly depends on the cause of the problem, but making the card work is simple and takes only a few minutes.
Scan for viruses. Some viruses or worms infect MS cards.
A computer that suspects a virus might interfere with the memory card as a result.
Look for viruses or problems with the anti-virus software that won't allow the memory card to open. If a virus if found, remove the virus through the anti-virus software before opening the memory card.
Check that the computer has the appropriate software installed to read the card.
Some MS cards or memory sticks might require more updated software or specific software that is not on the computer.
If the software is installed, look for current updates and download any updates to determine if the problem is old software.
Open the control panel.
Click on "Add New Hardware" and see if it is available.
If the hardware for the memory card is not installed on the computer, this will allow installation.
Once installed, the card should read.
If the memory card is not showing up, the problem is often damage to the card, which prevents reading the card. If the card is damaged, it must be replaced.
Use an adapter.
Some memory cards are not designed for reading in a computer directly and require the appropriate adapter.
The adapter changes the data to the appropriate system for the computer to read it.
Hope this helps
Nov 16, 2012 | Electronics - Others
Jazz T20 memory card won't read
if you look at the memory card then you might be able to see if there is a lock on the card.
Jun 10, 2012 | Video Cameras
While taking pictures my camera all of a sudden froze and said card error, tried putting memory card on computer but it won't read it have tried using recovery programs but it freezes them please help
If your memory card is 4GB or larger, AND if your computer is two or more years old, your computer's card reader might not be able to read the newer 4GB SDHC card. In that case, just purchase an inexpensive USB card reader from WMart, or Amazon (here's an example). Try a different card reader first to see if you can directly copy and paste the pictures from the card onto your hard drive. If the new card reader doesn't see the files, then try recovery software. Here's some freeware to try. If the software still doesn't see the card with the new card reader, you may next need to try the corrupted card procedures described at the bottom of this linked article.
Nov 26, 2011 | PNY 4GB Secure Digital High Capacity...
Computer won't read my memory stick pro duo. Computer won't read my Droid SD card and I am using the adapter.
is it possible that the auto play window just isnt poping up. go to the start menu > my computer> the look to see if it shows up there. have a great dat
Aug 25, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
My camera has been great until the other day. It won't recognize that the memory card is in the camera and keeps saying the memory is full. I had downloaded the card's contents and after that it...
Yes you need a new SD card, it is rare but happens where the SD card malfunctions and it is not read by the camera, it happened to me and I put in a new card and it worked find.
Jul 03, 2011 | Cameras
My Sandisk memory card is not read in any mobile or pc.
hi my dear friend
SORRY my friend your memory card is now corrupted WITH mallware virus
OK
Apr 08, 2011 | SanDisk 2GB microSD Memory Card
The message said "card locked" so I bought a new memory card after several attempts to fix it. With the new card in, the message now reads, "card unreadable"
Make sure you're using an SD card, 2GB and smaller. The M537 won't work with higher-capacity SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 03, 2010 | HP Photosmart M537 Digital Camera
Memory card not working
Not saying it is, but are you absolutely sure its not the camera software itself. Does it have any warranty? Is the card a new card and have you made sure that the TAB on left of SD card is not allowing READ ONLY. The tab flips up allowing the card to be formatted bit like the old floppy disks.
Apr 26, 2008 | Pentax Optio T10 Digital Camera
LG Xenon GR500 Cell Phone Logo
89 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
