Question about Konica Minolta Maxxum 7D / Dynax 7D Digital Camera
Taking pictures outside, sunny day..images appeat dark, why?
    Brigadier General:
  • 11,967 Answers
Check your "exposure compensation" and ISO settings.
Posted on Aug 06, 2010
Taking picctures outside they come out completly white and inside they are fine.
Not sure what type or model of camera you have. But most camera's have a Mode dial. The best thing to do is to turn that dial to the little green camera logo. That is the automatic mode. If you have chosen the moon and star, you only can make pictures in bad light situations.
Dec 09, 2013 | Samsung DigiMax Cameras
Using a DSC-T1, when taking a still picture the LCD screen is very dark when taking outside and no picture visible inside. This is true of the picture if printed off.
Does camera shows old saved picture correctly? if YES, then its has god bad ccd imager problem and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
If camera Does NOT playback old saved pictures, let me know.
Jun 08, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Picts turn out black when taking outdoor shots with fuji s1000
pls also update ur firmware from here it would likely resolve some issues or problems
http://www.fujifilm.com/products/digital/download/s1000fd/fupd.html
Apr 12, 2009 | Fuji FinePix S1000FD Digital Camera
I take pictures inside a car of people and sometimes the pic come in good and sometime not what is the best setting iso
Hi there, and thanks for coming to FixYa.
The ISO setting determines how sensitive your camera's image sensor is to light.
General rule of thumb...the lighter your surroundings are - the lower your ISO. So, depending on how bright the light is outside your car when you take the picture, use this:
If it's overcast 600 to 800 ISO.
If it's really sunny then us 200 to 400 ISO
If it's dark out then only use 1600 ISO
You should experiment with these ISO settings, you may have to notch it up or down depending on the light outside.
Rob
Mar 07, 2009 | Cameras
Images are coming out REALLY dark
first GET TO AUTO MODE WITH FULL AUTO
if this doesn't work try going to manual and setting the exposure up to +1 or +2
Feb 04, 2009 | Nikon D40x Digital Camera
No picture when its sunny outside colour is distorted inside its a jvc digital cam gr-d33ag
On several camera the ccd is sensitive to bright and causes the images to come out very dark or out of focus because the auto focus sensor is being blinded. Try taking pictures with you back towards the sun and try turning off your flash this some times helps out. I hope this helps you and happy photo taking.
Mar 28, 2008 | Cameras
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Dark image....even using flash.
The problem here is likely the auto setting. Put it to sunny, clear day instead of indoor picture and you should be ok. Also, point it at neutral colored objects when you take the picture and allow it time to adjust by holding the button in partway before depressing it fully.
Jul 26, 2007 | Canon PowerShot A630 Digital Camera
Picture are dark indors after i dropped camera
yes this can be repaired
the problem is with the image sensor,not with the lens as you can still take pictures outdoors
repair cost of this camera is $135.00 flat rate from kodak's authorized repair center
May 25, 2006 | Kodak EasyShare Z740 Digital Camera
Konica Minolta Maxxum 7D / Dynax 7D Digital Camera Logo
60 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
