Question about Freezers
My salad is freezing-not sure what the best setting is or which direction is cooler on the dial-1-6?
    Problem Solver:
  • 14 Answers
Try setting it at 3 1/2. 6 should be the coldest
Posted on Aug 08, 2010
Metalfrio prep table freezing evapoator
Check that all vent areas are clear of any dust or food packaging. If you have ice build up it needs to be thawed out also because it will only continue freezing until it gets proper airflow.
Sep 17, 2014 | Metalfrio SCL2-60-16 Salad Sandwich Prep...
Setting tempture
Turn the temperature control in the direction furthest away from the off setting.
Nov 19, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
Which way do I turn the temperature dial on a true 3-door reach-in stainless steel cooler?
Numbered 1-9 - one is the warmest setting, nine is the coldest. For a cooler it should be good on 5 for a freezer 7. If it doesnt work well on those settings the thermostat is usually bad.
Aug 03, 2013 | True Freezer GDM-49RF
What temperature shoud it be on please - it has from 1 to 3
I would suggest setting it on 2. But to eliminate guessing, the dial should be set so the temperature in the freezer compartment is 0 degrees F (-18 C). The best way to ***** this is to put a thermometer in the freezer and adjust the dial until the temperature is steady at 0.
Charlie
Mar 16, 2011 | Candy 2.5 cu. ft. / 71 liter Upright...
I have a Rank Arena BF260 freezer I got from my dad. There is a switch on the front, if it is to the left, there is no icon on it, if it's to the right it has a snowflake icon show. Dad didn't even realise...
It is the fast freeze switch. It keeps the freezer full on even if it gets down to its operating temperature. You will see the yellow or orange light come on. You do this if you want to add some new item in the upper fast freeze compartment. Make sure you turn it off after about 2 hours.
Oct 17, 2010 | Freezers
Kenmore upright freezer only 3 years old running ,no clicking noise, no ice build up but won't completely freeze although set to 7 (lowest temp)
check door seals, also check vent direction, a dial or lever in fridge, it adjust how much air goes to fridge and freezer
May 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Freezers
The back of mt fridge is frozen. I've set the temperature between 4 - 5. If I put food near the back it freezes. What is the best thing to do?
Move items that are susceptible to freezing towards the front. The air circulates in from the back and anything set directly in the airstream will freeze.
Eric
Oct 14, 2009 | Freezers
For a walk in beer cooler i installed a 1/2HP compreser 50 feet to the evp 2 fan fairly large,am i underpowerd or too far because i am getting freezing in the evp.any ans.
No your are Ok . You may be to small on your unit. Check the charge you may be low. Make sure site glass is clear. Also I have had to install a dfrost time on several of my coolers. If you have one just set defrost for more or more often. Got to keep the beer cool. Rus
Jul 14, 2009 | Freezers
Freezers Logo
49 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
