Question about Dryers
Heat no longer works! Can we fix this ourselves or do we need a repairman?
  • 525 Answers
Any time, a repairman can do for you a good job
Posted on Aug 06, 2010
I have a heat and cold comfort aire window unit it blows well but the air is not cold just cool
call an air conditioning repairman sounds like it needs a little recharge and sadly we can not do those ourselves
Jul 23, 2015 | Heat Controller Comfortaire REG-253J 25000...
Tip
We recently installed a new dryer and everything worked but it did not heat. We...
This advice is for all ELECTRIC Dryers that have a "No Heat" problem.
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
I hope this information is helpful to you. If you need further assistance, please go to my profile at: http://www.fixya.com/users/jsrock516 and use the "Ask Me" feature for a quicker repsonse to your questions/comments.
on May 02, 2009 | Kenmore 62602 Electric Dryer
The drain pump isn't working. is it something we can fix ourselves or o we need to hire a repairman?
Drain pumps are usually not difficult to replace. A pair of piers to remove the hoses and usually a socket set to remove the screws.
Sep 25, 2014 | Maytag Washing Machines
Oven heating element won't heat
Unless you are qualified to troubleshoot appliances or work with electricity, you should probably call a repairman.
Sep 09, 2012 | Frigidaire Ovens
Maytag washer model mav5920eww won't spin
It is either your gearcase or timer. They both are recommended to be replacd by a repairman.
Apr 30, 2012 | Washing Machines
I think the igniter is bad? The machine runs sometimes i get heat and sometimes i dont. Any soutions?
If the electric ignition component is bad, you'll have to have it replaced. We had similare circumstances many years ago and could not do the repair ourselves. The parts were not too terribly expensive and we found a reasonable repairman. The dryer has worked ever since. The main thing to remember is to consider the cost of the repair and the remaining life of the appliance. If you hope to keep the dryer for at least another 5 years, repair is best. If you have had it for 15 years, you'll do better to replace it.
Nov 01, 2010 | Dryers
Repairman was out on Staurday to fix 70" SONY KDF70XBR950 7
Yes an the projector unit also has channels around the fan that may be clogged. Also dust buildup on the bulb can cause erratic fan.
Apr 13, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Washing machine won't stop filling with water
if it keeps filling when unplugged replace fill valve if shuts off ckd pressure switch and hose to switch from tub
Nov 18, 2008 | KitchenAid KAWS750L Top Load Washer
Spin cycle
Ok,first off this machine has a clutch brake assembly on it that is known for sticking.It will sometimes hit a very high squeak at the last spin as it stops.Ive come up with the solution to fix this but Id have alot of trouble explaining it this way .Please contact me and assist you in depth any time you need.  archieferrarini@yahoo.com
May 15, 2008 | Maytag Performa PAV2200
Heat Pump was repaired and then went out again
Repairman fixed a wire? sounds a little vague. If the outside coil is covered with ice, then it may be the board. Most defrost boards have a test terminal on them. Touch something to the test posts and see if the reversing valve switches on and the unit starts defrosting. If nothing happens, then its the board. There could be much more things causing it not to work, but I need more info.
Feb 28, 2008 | Amana PTH123B25AJ Heat Pump Air...
Dryers Logo
32 people viewed this question
Top Dryers Experts
Marvin
Marvin
