Question about Proscan 42LA45H 42 in. LCD TV
My Proscan is approximately 2 and 1/2 weeks old. In passing my hand over the top of the thin frame, there is an enormourous amount of heat coming from the top of the tv. It is so intensely hot that it make the entire family room unsually hot. If there is danger of a fire, please advise me so that we can request another tv in place of this one.
Rule of thumb, if you can keep your hand on it, despite it feeling hot, then there is no danger of fire. Flat TV's use a lot of power for the ventilation slots available and so appear to be hotter than you would expect. 40"+ screens use about 150 to 200W the same as two old-style bright light bulbs - it's going to give off heat.
Posted on Aug 06, 2010
0152 coed
P0152 P0152 - O2 Sensor Circuit High Voltage Bank 2 Sensor 1Possible causes - Faulty Front Heated Oxygen Sensor Bank 2
- Intake air leaks may be faulty
- Exhaust gas leaks
- Front Heated Oxygen Sensor Bank 2 harness is open or shorted
- Front Heated Oxygen Sensor Bank 2 circuit poor electrical connection
- Inappropriate fuel pressure
- Faulty fuel injectors
eplacing the Front Heated Oxygen Sensor Bank 2 usually takes care of the problem
Symptoms- Engine Light ON (or Service Engine Soon Warning Light)
- High Fuel Consumption
- Excessive Smoke from Exhaust P0152 Description The front heated oxygen sensor (or O2 sensor 1) is placed into the exhaust manifold. It detects the amount of oxygen in the exhaust gas compared to the outside air. The heated oxygen sensor 1 has a closed-end tube made of ceramic zirconia. The zirconia generates voltage from approximately 1V in richer conditions to 0V in leaner conditions. The heated oxygen sensor 1 signal is sent to the Engine Control Module (ECM). The ECM adjusts the injection pulse duration to achieve the ideal air-fuel ratio. The ideal air-fuel ratio occurs near the radical change from 1V to 0V.
Mar 19, 2013 | 2005 Dodge Ram 1500
How do I replace the oven door gasket on my VGIC3686
Replacing a Door Gasket
If the oven won't heat to the desired temperature or heats unevenly, the problem could be a defective door gasket. The best way to test for this is to pass your hand around the door, being careful not to touch it, while the oven is turned on. If you can feel heat escaping, the gasket needs replacement. Replace it with a new gasket made for the range.
On most ovens, the gasket is located on the frame of the oven, and the door closes against it. This gasket is generally friction-fit in a channel and can be replaced. In other units, the oven door has two sections, and the gasket is not mounted on the door frame, but is installed between the front and back sections of the door. Don't try to replace this type of gasket; call a professional service person. Here's how to replace a frame-mounted gasket:
Step 1: Pull the old gasket out of the channel. On some oven door frames the gasket is held in place with screws. To get at the screws, bend back the exposed edge of the gasket.
Step 2: Clean the channel and the door frame with a solution of mild household detergent and water.
Step 3: To install the new gasket, start the replacement at the top of the door frame and work down the sides, easing the gasket around corners. Finish the installation along the bottom, butting the ends of the gasket firmly together.
Apr 16, 2012 | Viking Kitchen Ranges
I bought bell trianing wheels and i have no idea how to attach them to the bike they did not come with any instructions
Unbolt the bolts on the rear wheel (pay attention to approximately the amount of torque to remove the bolts). Slide on the legs with a hole on one end and a curved end to fit the frame. Slide on the training wheels so the training wheel sticks out and is at an appropriate height for the bike. replace bolts with approximately the same torque as before. Also make sure the tire is seated as far back in the frame as possible to keep tension on the chain.
Jul 14, 2011 | Cycling
Volume fades out then may come back on-Proscan TV Model#PS35690LW
hello,
this will require you opening the back cover of the television.
Check for dry soldering and re solder in the audio section of the printed circuit board....
Good luck...
May 24, 2010 | Televison & Video
Water not heating in Rilvia espresso machine
Hi
There is a reset button on the side of the boiler. Make sure that the machine is unplugged. Remove the water tank. Take out the 4 screws on the top. There are 2 black wires go to the high limit thermostat that has a red button in the middle. Push the red button.
Nov 07, 2009 | Rancilio Silvia Espresso Machine
2 thin vertical line on lcd monitor
The thin ribbon that connects the board on the back of the lcd screen to the front glass of the lcd screen got damaged.
It wraps around the top of the screen and is very thin and can be easily damaged.
May be from old age and heat at the top of the screen or it could have gotten hit at the top.
If you keep pushing it in and out you may damage another one and make another line.
The cheapest way to repair this is to replace the lcd screen with a good used one because trying to find a shop to try to repair it would cost more than a new monitor.
Sorry there isn't an easy fix to this.
Fran
Mar 29, 2009 | Taxan Crystalvision 680 TCO 99-S 15" LCD...
Problem with proscan 19LA25Q
Watching a movie tonight...and slowly there was odd behavior from the screen. No volume at first, then flickering, fragmenting and now, as the others only shows the red power. I have noticed some strange flickering the past 2 weeks or so. I thought it may be the cable, so did not concern myself too much. I believed that was the problem tonight as well. But the screen is definately not responding to the remote or manual button.
Thanks
Mar 16, 2008 | Proscan 19LA25Q 19 in. LCD Television
Pages printing with streaks.
try making a copy on the glass, does it come out with the streaks or clean?
If clean then look at the strip glass on the copier there is a pen dot or white out that 's giving you the streak. clean.
Jan 24, 2008 | Toshiba e-Studio 232 Black and White...
Kenmore Side by Side Refrigerator Model #106.50544001
It's time to replace the dual water inlet valve (the part the water line connects to). A bit of sediment or other fine object can get in the seat or the material itself can deteriorate and allow a tiny amount of water to pass up to the icemaker.
Jan 04, 2008 | Whirlpool GR2SHWXPB 21.7 cu.ft. Top Mount...
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Proscan 42LA45H 42 in. LCD TV Logo
62 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
