Question about Kenmore Heating & Cooling
I have a Kenmore DX1400 HE central air unit about a year old and it start turning on and of quiet often. The local tech said that it is not draining. What make it not drain?
bobotfel
  • 236 Answers
SOURCE: 20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Posted on Jan 12, 2008
  • 143 Answers
SOURCE: Mr. Slim MSY-A17NA noisy interior fan
If the inside fan got loud because it developed mold, the only cure is to keep cleaning it.
Posted on Jul 26, 2008
jumptrout51
  • 3361 Answers
SOURCE: central air conditioner doesn't cool
The capacitor is located inside the control panel on the outside unit. It is round or oval and silver in color.It runs the outdoor fan and the compressor both.
The terminals are marked= C, /F or fan/, H or herm. C-F-H.
The microfarad rating is printed on the capacitor. Make a color code wire diagram before removeing wires.
Disconnect power to the unit. Use a insulated screwdriver to short out the terminals on the capacitor before removing it.
Posted on Apr 27, 2009
  • 252 Answers
SOURCE: A/C drain pan not draining.
The drain must have one and only one trap in it. A trap is where the pipe goes up then back down so that water is kept in a section of the pipe - will stop the air from blowing thru the drain and not letting the water drain - may not sound right but it is! I've seen this many times! Drain traps are not understood at all by the HVAC industry.
Posted on May 12, 2009
  • 6 Answers
SOURCE: Kenmore DX1400 central air unit when running turns
Kenmore DX 1400 should be an ICP products central heat pump unit. As such, it will have the exact same charactoristics as the Tempstar, Comfortmaker, Heil or Arco air brands R410A, 14 SEER series of controls.
I am assuming when you say unit is shutting down that you mean only the outdoor unit, and the inside blower( air hanler / furnace? contiunues to blow.
First, there is a control in the outdoor unit called the "comfort alert module" this module closely monitors the compressors operation, as well as hi and lo pressure switches and amps of the compressor. If it senses a fault, in some cases a specific fault will cause the unit to shut down, it may not restart. The module has a set of lights. there is an index to translate the code faults by what color and timing of the flashes.
Secondly, there are several things that can cuase the result you have posted. Unit shutting down due to low pressure control could mean low freon charge, or freon restriction in the system. Both of these require a professional to look at the problem. if your installer put in an aftermarket time delay relay, this can cause the problem.
Last but not least, the rsult you are getting could be caused by a circuit board failure. heat pumps will have this.
End result, call a service company known for their ability to solve problems. Without more precise informaiton, the above suggestions are just avenues to look at. More information needed for a precise answer
Posted on Aug 23, 2009
My central vac unit does not turn off even when hose is disconnected. I have to unplug the motor unit in the garage to shut it off. What do you think the problem is? It is a 7 year old Electrolux
Possibly the power module. Or a short in the wiring. Take it to the local Aerus Electrolux store and have it checked by a service tech to be sure. The pm is a lot less expensive to replace than a whole cv.
Nov 21, 2010 | Electrolux Central Vacuum
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
Water leakage, just started using since June.older 10 yrs +_ Marty Margolis
Hi!!
Make sure unit is tilted backwards about an inch so condensed water can drain in the back. Make sure drain hole is not plugged, if so, use a piece of wire to unplugged.
AC units have to be serviced at the beginning of summer every year or at least every other year . It will be cheaper to take unit to service shop than to have a HVAC Tech come to your house.
Good Luck!!
Aug 14, 2010 | Kenmore 75085 Air Conditioner
Kenmore DX1400 central air unit when running turns on and off contiuosly and sometimes will not turn on at all for days? We have checked the breaker, of course no problem, checked the thermostat and it...
Aug 22, 2009 | Heating & Cooling
Jul 12, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a one year old Beam central vac. It has supervalves. The handle (connected to the hose stopped turning on the unit. The handle still powers the brush but no longer turns on the suction?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566201
Generic problem for all Vacuums
I have a one year
posted by jon89 on May 02, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Beam Central Vac may have more than a one year factory warranty and it sounds to me that you may have a bad relay switch the Central Vac, if you do it should be covered under the factory warranty. Otherwise, you may have a bad supervalves or a wire came loose, if the hose switch turns on the power nozzle then it may be a bad supervalve or a bad relay and to contact the installer or the manufacturer of Beam. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
Heating & Cooling Logo
46 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
