Question about Brother Office Equipment & Supplies
I have brother MFC-8500... I forget now how to load paper to fax. upside down or right side up?
  • 268 Answers
Always load the paper to be faxed face down in the automatic document feeder.
I hope this helps.
Posted on Aug 06, 2010
My mfc 6490cw sends blank faxes
Normally this is caused by not loading the item being faxed in the ADF (Auto Document Feeder) correctly. Try sending a Fax of only one page by putting the page Face down on the Scanner plate (Lift the top of the printer to access the scanner plate). if this works then check the ADF scanner plate is not obscured.
Oct 20, 2014 | Brother MFC-6490CW Inkjet All-in-One...
Hi do i fax with the paper facing up or down?
not sure about this specific model. However, on the loading platen you should see a diagram of a sheet of paper with the top right corner turned over which indicates the paper should be face down. If it doesn't have this diagram you should assume it is face up.
Jul 22, 2011 | Brother MFC-3220C Plain Paper Inkjet Fax
We have a Brother MFC -8500 fax machine. Every day
The Drum unit is a consumable.
Buy a new Drum from Staples , Office Max etc and replace it soon.
It will stop and refuse to print when a certain page count is reached.
Jan 07, 2011 | Brother IntelliFAX 2800 Laser Fax
When i am faxing do i put the paper up or down on this thing brother mfc-7420
Either lift the lid lay the paper in print side down, or put it into the document feeder print side up. In either case the top edge of the page should be at your left to appear right-side up at the receiving, but that's a minor point.
Sep 15, 2010 | Brother MFC 7420 All-In-One Laser Printer
My fax machine keeps saying there is a paper jam.
look on the bottom of your drum unit. there is a sensor opening that might have a tiny piece of paper in it, not allowing the sensor flag to reset. if thats not it, closely inspect behind rear door.
hth,
razors
Apr 05, 2009 | Brother MFC 8500 All-In-One Laser Printer
How can I fax a Paper?
Load the original face down
dial the fax number
press START
Mar 17, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
When fax, the paper cannot be loaded.
The machine clicks when you plug in the power is the gear porblem, most likely the gear is broken.
the one that does not pickup paper is the roller.
you can change the roller form the licker to this one.
hope that helps.
Dec 01, 2008 | Brother MFC 8500 All-In-One Laser Printer
Brother mfc 8500 clicking noises
If you open the cover and remove the toner/drum unit, you will see (on the left side as you remove) a small hole with two triangle teeth.
on either side of this hole are two small phillips head screws. this is the problem we had with our clicking noise. As the machine tries to turn the toner/drum, the innards of the toner are becoming harder to turn. So the part of the fax machine that fits in the hole end up stripping the teeth in that hole. If you have an old toner cartridge, you can remove the gearing from it (where the small phillips head screws are) and use it to replace the gearing on the newer cartridge. Or go buy a new toner cartridge.
Jul 24, 2006 | Brother MFC 8500 All-In-One Laser Printer
131 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
