Question about Craftsman Garden
Tecumseh carb diagram # carb 5208 MgA need to see
Tecumseh carb diagram # carb 5208 MgA need to see where all seals and orings are in this carb.
3 Suggested Answers
mickey813
  • 472 Answers
SOURCE: looking for a diagram for a tecumseh 12 hp carb.
LOTS OFF LUCK TO YA YOU MAY TRY SEARES ENTER YOUR MODEL #
Posted on Sep 30, 2009
  • 6468 Answers
SOURCE: Tecumseh HH60-105079E caRB REBUILD DIAGRAM
see if someone is doing it on 'you tube'
Posted on Apr 08, 2012
Where can I get a diagram of carb choke and throttle linkage set up?
I bought a brand new 13 hp Tecumseh on my rider,was trouble from day one,fought it tooth and nail,finally took to shop,they put a brand new Taecumseh carb on it,couldn't get it to run,went to a dinky lawn mower shop,was told the carb was not the right one,wow,they sold me a used one that looked way different,but it worked super,so try another non-tecumseh carb or fight it forever.
Jun 07, 2015 | Garden
I need a formula 8 horse tecumseh carb diagram off of a snapper rider. trying to rebuild carb.
you need engine numbers, carb numbers... something
but take those numbers over to parts tree dot com and look up your engine.
Oct 26, 2014 | Garden
I need a free diagram of a tecumseh carburetor 5TPXS.3582AA Spec. 206915F
You can find a free diagram at www.sepw.com, use the part number of the carburetor as a model number under tecumseh brand lookup. Your carb part number is 640065a.
Jul 12, 2013 | Garden
Need carb linkage diagram for tecumseh LEV120 engine
yes or a bad safty switch check the seat the brake and the clucth
May 07, 2013 | Garden
Looking for carburetor assembly drawing thanks Tecumseh 4hp TVS105 53048D SER. 4159B
I didn't find a schematic, but here is a site that may be able to help you:
www.lawnmowerpros.com/Tecumseh/tecumseh-Carburetor-Kits.asp
Contact the number at the upper right of the page if you can't find a schematic close to yours. They may send you one for free if they have it.
Good Luck!
Jim
Oct 10, 2010 | Mtd 22" Yard Machine Push Mower
Lawn mower works when primed, but will pump gas to continue running.I tried to clean the valves.
if its a briggs engine then the nole in the bottom of the carb bowl( looks like a half in nut) is partially clogged. Clean oit with a torch tip cleaner or fine wire. If its a tecumseh engine then the nole thats deep inside the carb that has 2 orings on it is clogged the same way, remember to replace both o rings if you remove them/
Nov 15, 2009 | Toro Lawn Mower With Toro Power Tools
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
Tecumseh hm80 snow blower motor linkage
below is a web site for you to check out the parts at. Hopefully this helps you out. If not, let me know and I will try to get you a better diagram. thanks.
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-HM80-155315N-PARTS-LIST.pdf
Mar 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Fuel in crankcase
hello
if im showing the right diagram. the carb on your bike as an oring that seals off the float valve seat. i would pull it out and inspect it. another little trick is to hook up fuel to the carb with the float bowl off and push up on the float and ensure that it is sealing. cause this very much does sound like fuel is bypassing the float valve assembly. really that is the only way you are getting fuel into the crankcase. and also is consistent with it running so rich. hope this helps. thank you.
Mar 22, 2009 | 2000 Yamaha DT 125 R
Garden Logo
281 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
