Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Blinking green timer light after power outage.
  • Mitsubishi Master
  • 8,617 Answers
Failed capacitors on the DM and the Power boards. You can get the V26 Chassis DM/ Power repair kit from www.tvrepairworld.com which contains the replacement caps and the CD with instructions.
Posted on Aug 08, 2010
There was a power outage in my zipcode; and when the power came back on, the timer light on my tv was blinking and will not stop. This is not allowing me to turn on my tv.
Thats a very common problem caused by bad DM capacitors. The caps discharge during the power loss and then cannot recharge when the power is restored whcih causes the steady blinking green led. You can get the DM repair kit for your model at www.tvrepairworld.com which does include the upgraded caps and the CD with instructions.
May 06, 2011 | Mitsubishi WS-65809 65" Rear Projection...
After a power outage my wd62525 won't restart.......the green timer light has been blinking for more than 24 hours HELP!! (I did try to reset, same blinking)
There is chance that the power outage might have damaged the power supply. It does happen, it's most common with storms. I recommend that you go to a shop and get that board checked
Dec 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi TV Model VS45609 Blinking Green Light
I have a Mitsubishi VS 45609 tv. I turned it off at midnight and tried to turn it back on the next morning and nothing happens. Can you help?
Nov 03, 2009 | Televison & Video
MY GREEN TIMER LIGHT WILL NOT STOP BLINKING
The manual indicates that this can be caused from recovery after a power outage, although it doesn't indicate thow long this lasts.
I recommend two courses of action:
Disconnect the television from power and let it sit overnight before plugging it back in.
If this doesn't work, reset your TV according to the instructions in your manual.
Oct 24, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
http://servicemanuals.vstore.ca/
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No power just blinking green light
I had this problem last year. Just the blinking green light. the tv would not turn on. It was the power module. A local electronics tech fixed it for me for $300.00. It was a circuit in the panel that needed to be changed.
Aug 29, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi wd 62525 chassis
I was told there was a bad batch of capictors so we reaplaced all of them and still the blinking green light ,and no tv still help bagelbaker77@yahoo
Jun 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
153 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
