Question about GE PSW26MSR Stainless Steel Side by Side Refrigerator
I have a GE stainless steel side by side model PSW26MSRB. Incoming water supply line to ice maker popped out from back panel of unit spilling water (looks like it was originally attached with adhesive collar). I reinserted, but it popped out again when it tried to fill. Inside, the feed tube to the ice maker appears frozen over. I think pressure from incoming water is forcing the tube to pop out the back of the unit.
  • 166 Answers
Your water valve has failed. the valve is slowly seeping water eventually causing the fill tube to completely freeze over. You are right - the incoming pressure is causing the tube to pop out. you can usually pull the feed tube out from inside the freezer and thaw/clean it out. but you will need to first replace your water valve.
Posted on Aug 06, 2010
Door dispenser not working
Is the ice maker working properly? There is a water filter in the refrigerator through which both the ice maker and water dispenser are supplied and over time it will slow down the flow and eventually block. Have you changed it recently? Often, ice cubes will get smaller as it blocks and the ice maker will also quit.
Also, have you checked the water supply line that goes to the ice maker and water dispenser? It should be a small diameter copper or plastic line that connects to the back of the refrigerator.
Ed
Jan 08, 2014 | GE GSH25JSTSS Stainless Steel Side by Side...
Water is leaking down the side and back of the freezer from the ice maker. I have the GE CAN9 ice maker. Were is the ice maker water valve located ?
Bottom right in back of ref.<br /> Its what the water line from the wall attaches to.<br /> <br /> <br /> If this was helpful please rate me.<br />IMUFO2<br />Leo Ponder Appliance-Tyler,Texas<br /><a href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a> <br />
Aug 30, 2010 | GE Profile PSW26P Stainless Steel Side by...
The ice machine stopped making ice
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jun 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
Home from vacation--no ice.
Check the fill area of the ice maker for an ice blockage.
- make sure the tube on the back of the Ref. is connected to the white rectangled block of the fill tube.
- check to make sure the water filter in the bottom of the unit was not kicked and has popped out or is not seated / locked in place.
- Check to see if water is actually getting to the unit.. from the 1/4 inch supply line.
If your icemaker is the common one there here is a way to test it:
(I noted GE Profile but not an exact model number)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Last question... does water in door work?
Thanks for using FixYa.
Kelly
Apr 03, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
GE Profile refrigerator side by side, water and ice through door. Ice maker works fine, water will not shut off. Had to turn water to frig off.
The water inlet valve on the back where the water supply connects to the unit is stuck open. You may can clean the valve out and get it to closing or just replace it.
Dec 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
The water and ice taste and smells bad, and when the ice melts the water is cloudy
Replace water supply line. Do not use the braided metat line or vinyl. Use the plastic tubing ice maker line or copper.
Oct 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
My GE side by side ice maker quit making ice, no water sees to be entering the unit.what do i check for?
Pour 2 / 3 cup of water into the ice maker .
If it dumps the cubes , but does not refill with water , replace the dual water valve behind the refrig . This is the piece , the wall water line connects to , on the refrig .
If it does not dump the cubes , replace the ice maker .
Oct 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
How do i turn off the ice maker on a ge profile. thereis a bad leak from the hose in the back. can i just turn off the ice maker to stop the water flow?
You can lift the lever in the ice hopper to turn off the unit, or simply unplug the electrical connection to the ice maker inside the fridge. If your leak is in the line between the house supply line and the valve on the icemaker, turning it off will not solve your troubles. If that is the case, you can turn off the supply line valve.
Jun 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not filling with water, makes noise trying to fill
take out the line connection in the back of the icemaker where it goes through the wall check for clogs.
Dec 14, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE PSW26MSR Stainless Steel Side by Side Refrigerator Logo
333 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
