Question about Bertazzoni X30 4 GGV X Gas Kitchen Range
I need a t-style trim piece to bridge the very small gap between range and countertop. What is the best way to close this gap?
    President:
  • 1,430 Answers
There are pieces specifically for this. They can be purchased at lowes, Home Depot and most appliance store. They can be purchased in several color options, cost less than $20
Posted on Aug 06, 2010
Once we leveled our Electrolux slide in gas range, using it's feet, it created a gap between the left side and the countertop. Is there a filler (removable when necessary) we could use for th
Thank you for your post, Wendy Berg!
I understand that you are searching for a filler piece to go between your Electrolux range and countertop. I was unable to locate any type of filler piece I see the manufacture has a side trim kit, rear filler panel, and backguard kit but nothing specific to your request. I hope this information is helpful. -Matt
Sep 27, 2014 | Electrolux EI30GS55LW | 30" Slide-in Gas...
Granite countertop
Granite needs to be color matched epoxied together at the seams. If they are sitting level and flush (and Solid) a home owner solution is to use matching silicone filling the seem then cleaning off with a good solvent. tape the top on both sides before starting. The second solution works to keep out food, but may not look great if they are not flush or have not been cut cleanly and the gap is not too wide. You will need suction cup turn buckles to pull them tight. Do not do any of the above if you are not comfortable with your skill level or feel it may damage your top. Granite can be stained using the wrong products.
Oct 12, 2013 | Dishwashers
I have a new viking stove slide in electric top range that was installed in our kitchen with existing granite counter tops. But there seems to be a small gap between the stove and the counter. My previous...
If you are talking about a gap caused by the height of the stove, You can lower the height of the stove by adjusting the threaded leg posts on the bottom of the stove. A more difficult fix would be in raise the height of the countertop and cabinets by shimming the bottom of the cabinets.
If your gap is not a height issue, then you can experiment with some type of trim around the stove itself. Local granite dealers has an assortment of trims for issues like this.
I was able to find a number of trims for a back gap on my granite countertops and backsplash from my local European Marble and Granite.
Mar 15, 2013 | Cooktops
Trimming endcap on Formica countertop
is it already in place? you can trim it with a skill saw, make sure the blade is sharp and sand down the corners after to make them more round
Jan 28, 2013 | Building Materials
Westinghouse range hood wrf900cs light blew, light globes replaced but lights still not working
I had the same problem. An audible pop and the lights stopped. Fans still works, light bulb filaments appear intact.
My problem was that a short piece of the copper on the printed circuit board, inside the switch housing, had vaporized as if it were a fuse. I soldered a bridge of copper wire across the small 5mm gap and all was working again.
Access the switch compartment by removing the filters, undo a couple of retaining screws to remove switch unit.
Make sure the electricity to the unit is Off/unplugged before proceeding!!!
Switch unit cover has 4 screws holding it on. Once inside the unit, trace the wire (mine was grey colour) from the light switch to the small printed circuit board. The copper printed circuit link to the connector had gone...no sign of burning, just gooone!
Solder a bridge of copper wire across the gap and reassemble switch unit to test.
....send beer donations to me in qld...cheers!!!
Jun 29, 2012 | Kitchen Ranges
Trim on replacement windshield leaves a 1.5 inch gap on both sides on 2005 Ford Freesytle
Sounds like they put in the wrong windshield. Some styles of windows use black-out trim and others use chrome or body colored trim.
Probably the best thing for you to do is go to a few car lots and see what the other Freestyles look like. Then be sure to compare your Body trim (GL, L, LX) with yours. Or go to the Ford dealer Bump shop and ask them to identify your part.
Feb 14, 2010 | 2005 Ford Freestyle
Is there suppose to be a gap of 1/8" - 1/4" between the lip of the range and a granite countertop?
Ranges have a built in safety factor when the cooktops were designed so that the perimeter of the stove stays warm at best when using. The granite is very thermally stable and will not have an issue here. But the oven area needs a little air space from your cabinet/wood surface.
Jul 26, 2009 | Electrolux 30" Self-Cleaning Slide-In...
Trim between range and tile countertop
The range usually about 1/2 inch higher than the counter. Normally there is a gap on each side typically about 1/2 inch. The range would heat up and expand at a different rate than the counter, so they cannot touch...
Apr 10, 2009 | Amana ACF4215 Electric Kitchen Range
Took off trim around lightbulb
Place the circle of the springs on the two small post that are in the center piece of the trim that heads into the hood, make sure that the two legs of the springs are to the outside of the post. The small legs should lay against outside the center piece. The larger legs should be angled downward. Look in the hood and you should see a piece of metal with a central vertical opening on each side. Take the trim piece with the springs attached and lift the wings of the springs so that they enter the slits. The important part is that the small legs of the springs must be placed against the outside surtace of the hood. As you push the trim piece in the hood the wings of the spring will be forced down through the slits by the pressure of the small legs of the spring against the exterior of the surface of the hood. This pressure will keep the trim piece in place. It may help to remove the filters so that you can see inside of the hood. Make sure that the small legs of the spring are against the outside surface of the hood or there will not be any resistance to create pressure by the springs.
Mar 16, 2009 | Dacor EHD3618SS Kitchen Hood
The window fell off it rollers
  1. Remove all door inside handles.
  2. Remove the door inside locking rod knob.
  3. On styles with door pull handles, remove the screws inserted through the handle into the door panel.
  4. On styles with remote control mirror assemblies, remove the remote mirror escutcheon and disengage the end of the mirror control cable from the escutcheon.
  5. On styles equipped with switch cover plate in the door armrest, remove the screws securing the cover plate, then disconnect the switches and cigar lighter, if so equipped, from the harness connectors.
  6. Remove the remote control cover plates and remove the exposed screws securing the cover plate to the door inner panel.
  7. On styles with integral armrest, remove the screws inserted through the pull cup into the armrest hanger support. On some styles it may be necessary to remove the screws behind the armrest deflector or courtesy lamp remote control cover plate. On styles with armrest applied after the door trim installation, remove the armrest to door inner panel attaching screws.
  8. On styles with with two piece trim panels, disengage the retainer clips at the front and rear of the upper trim panel. Remove the upper trim panel by lifting upward and sliding slightly rearward to disengage the the front door inner panel at the beltline.
  9. On styles with electric switches located in the door trim panel, disconnect the wire harness at the switch assembly.
  10. To remove the lower trim panel, remove the attaching screws along the upper edge of the lower trim panel. Then starting at a lower corner, insert a pry type tool between the door inner panel and the trim panel and disengage the retaining clips down both sides and across the bottom. On styles with courtesy lamps or reading lamps located in the trim panel, disconnect the wire harness at the lamp assembly.
  11. On styles with one piece trim panels, remove all the clips around the perimeter of the trim panel. Push the trim panel downward and outboard to disengage it from the door inner panel at the beltline. Disconnect any courtesy lamp wire harnesses, if so equipped and remove the trim panel from the door.
  12. Installation is the reverse of removal. On styles with adjustable trim supports at the beltline, the door trim panel can be adjusted in or out so as not to restrict door window operation.
Oct 14, 2008 | 1988 Cadillac Sedan DeVille
Bertazzoni X30 4 GGV X Gas Kitchen Range Logo
202 people viewed this question
Top Bertazzoni Kitchen Ranges Experts
ray gallant
Anthony Kelly
Anthony Kelly
S Sigs
S Sigs
Are you a Bertazzoni Kitchen Range Expert? Answer questions, earn points and help others
