Question about Nokia N70 Cellular Phone
How can i connect my internet with my n70 to my laptop
I have this INTERNET CONNECTION problem, i installed everything the M-ROUTER,GNUBOX,WIDCOM BLUETOOTH, now please tell me how can i link my n70 internet connection to my laptop with the use of the pc suite?
please solve my problem ...
  • cha1975 Sep 09, 2008
    wher can get free gnubox for n70
  • Anonymous Mar 13, 2014
    internet button keeps blinking and everything thats connected to the router wont connect to the internet
In addition to lovely life suggestion, you must check first your configuration, if there is any, go to menu, tools, setting, connection, if none ask your network for configuration setting
Posted on May 19, 2008
In addition to lovely life suggestion, you must also configure you phone, by asking configuration from your network provider
Check whether u install ur pc suite properly or not.follow these steps.
1)connect ur data cable to ur phone and laptop .
2)a icon shows connecting of ur phone
3)click pc suite icon on ur laptop .the click connect to internet.click on settings change ur operator according to ur sim card.
Posted on Apr 29, 2008
I cant connect my wireless n router to my internet connection
hey can you see your router pppoe connectied to you pc or laptop
Jul 05, 2009 | Computers & Internet
Laptop says excellent connection - not able to access internet
connect laptop to router using lan cable.
check internet connection. Should be ok.
Only then enable wireless using same WLAN protocol you use on Router: WEP or WPA with same encryption key TKIP or AES.
Be sure no access list enabled on Router or add Laptop MAC address to access list.
Dec 28, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Can;t use intent on mobile
Here is what you should do step by step:
I.Configure your Computer
1.Install Bluetooth Adapter
2. Bluetooth Configuration->Local Services-> Add Serial Services ->Bluetooth Serial Port->Properties
Check – Startup Automatically
Check – Secure Connection
COM Port: COMx( mine is COM6)
3.Control Panel -> Phone and Modem Options->Modems->Add-> Check Don’t detect my modem->Next->(Standard Modem Types)->Communication cable between two computers->Next-> on witch port do you want to install it ? -> Selected ports -> COMx ( in my case COM6)->Next->Finished
Now in phone and modem options->Modems you should have : Communications cable between two computers : Attached to : COMx ( COM6 my case)
Select Communications cable between two computers -> Properties->Modem-> Maximum Port Speed : 115200 -> ok ->ok.
4.Control Panel ->Network Connections ->Create a new connection-> Next->Set up an advanced Connection-> Next-> Accept incoming connections->Next-> Check : Communications cable between two computers ->Next-> Check: Do not allow virtual private connections->next->next->select: Internet Protocol(TCP/IP)->Properties:
Network access : Check Allow callers to access my local area network
TCP/IP address assignment : Specify TCP/IP addresses:
To: 192.168.0.y (y=52 in my case)
->OK->Next->Finish
5.Network Connections
Bluetooth Network -> Enable
Internet Connection ( your internet connection ) -> properties->Advanced->Check:Allow other network users to connect trought this computer’s Internet Connection->OK
If all goes well : Bluetooth Network-> Properties-> Internet Protocol ( TCP/IP)->Properties Should have the following setting:
Checked Use the followind IP address:
IP address: 192.168.0.1
Subnet mask: 255.255.255.0
->OK.
6.Start->Control Panel->Administrative Tools->Services->Routing and remote access->Properties->General: Startup type : Automatic - this service MUST be started
**7.Install AnalogX Proxy http://www.analogx.com:80/files/proxyi.exe (for the latest version)
Proxy->Configure-> Proxy Binding: 192.168.0.x ( for me x=50 )->ok.
! If you use a proxy, remember to start it .
II. Configure Phone:
1.Install GnuBox - http://gnubox.dnsalias.org/gnubox/ ( for the latest version)
2.Configure Access point
Tool->Settings->Connection->Accces Points-> New Access point->Use Default Settings
Connection name: Bt
Data Bearer: Packet data
Access point name : Bt
User name: none
Promt Password: NO
Password: ****
Authentication: Secure
Homepage: none
Option->Advanced settings
Network Type: IPv4
Phone IP address: Automatic
Name Servers: Automatic
**Proxy serv. Address: 192.168.0.x ( for me x=50)
**Proxy port number: 6588
3.Configure all the applications from your phone witch require internet acces to use Bt Access Point
4.Configure GnuBox
Options->Install Set to GPRS
Options->Install Create Records
Options->Install->Copy settings from GPRS
Options->Install->set RAS login script
Exit GnuBox
Open Gnubox
Options->2box Bluetooth->Serial Port
Select – your computer
Do you want to require encryption? Yes
Options-> Install->change default AP
** Configure NetFront
Options->Settings->Connection
Enable Proxy : Yes
Proxy Host : 192.168.0.x ( in my case x=50)
Now you can browse the internet from your phone.
NOTE: First Configure the phone and your pc without the ** settings, and if you can’t browse the Internet form your phone then use the ** settings.
Hope this works fine.Thank you.
Nov 25, 2008 | Computers & Internet
Not getting internet on my laptop
What you can try is :
re-install wireless card
power cycle your router & modem and then try to connect
if it still does not work then call your internet service provider and he ll assist you with the settings
Nov 20, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireless connection
Make sure that your computer is getting a valid IP address from the router. If your wireless network is secured, you might as well consider checking the wireless settings.
Oct 06, 2008 | NetGear WGT624 Wireless Router
"Local Access Only"
You need to look on the back of your router and find the small reset button. Push it and everything should reconfigure. If not Go into your device manager and see if you can find something called a NIC card or Network Interface Card, or something called an Ethernet card, if those are not listed, it means your driver has been deleted somehow. You can go to the manufacturers website and download a new driver.
Sep 22, 2008 | Linksys WRT55AG Router
Have connected the wireless router,I am receiving internet to laptop but now internet is lost from pc. Connection has been installed correctly i think.
you should make a connection from your PC to your router then connect your laptop to your PC's internet connection... you will need 2 dongles 1 in your PC and 1 in your laptop (unless you have it built in). get the connection on the PC first then find the connection from your laptop to your PC
Aug 21, 2008 | Computers & Internet
My wireless router wont work
Run a cat5 cable from the laptop to a cat5 port on the router, open internet explorer in the address window type http://192.168.1.1 or what ever the IP address of the router once you have accessed the router create your PPPOE internet connection, enter your Internet Service Provider's username and password. Once you have done this, disconnect the cat5 cable and connect wirelessly to the router from the laptop. If all this fails press and hold the reset button on the back of the router for 10-15 seconds this will reset the router to factory defaults. connect to the wireless router and create the PPPOE connection. BPCS
Dec 29, 2007 | D-Link DI-634M Wireless Router (DI634M)
Losing internet connection when I try to connect laptop to wireless router
Your cloning the mac address - thats the problem. It should use it's own mac address to connect to the modem. You need to power down the modem, then repower after a minute or so to let it connect to the new mac address. The problem you are seeing is due to network collisions betweenj the desktop and the router with the modem.
Nov 29, 2007 | Belkin (F5D7230-4) Router (587009)
Nokia N70 Cellular Phone Logo
212 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
