Question about LG DH305 Dehumidifier
I have a Goldstar DH305 dehumidfier. It acts just like the 304 sample question. It runs for about a minute then shuts off. Turning the control level to min, then back to max and it runs again for about a min. I cleaned the regular coils, but I couldn't find the heat disapating coils. How do I bypass the control to see if that is the problem.
  • heidm Aug 08, 2010
    IHere is the main problem: It runs for about a minute then shuts off. Turning the control level to min, then back to max and it runs again for about a min.
    I haven't seen any suggestions that would solve the problem.
    How do I bypass the control to see if that is the problem?
    It just keeps shutting off after about a minute. I would like to bypass the control but I don't know how to do that.
  • LG Master
  • 12,061 Answers
This is your thermostat faulting usually it's the sensor thats attached to the copper coils. this is a common thing.
getting hold of spare parts will be almost impossible, to obtain unless you are an authorised service person.
You are going to have to get the unit looked at by a professional service center/person. to get this resolved I fear.
Also one would have to obtain a service manual, I have searched for one,but couldn't find any.
As usual, please ask for a "quote" before proceeding with any repairs, in case this is indeed a symptom of a greater problem, that first thought.
Posted on Aug 08, 2010
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow links for your query...
http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
http://www.ehow.com/way_6060029_dehumidifier-troubleshooting.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 06, 2010
Hello. I have the Goldstar Dehumidifier Model DH305 - This is the third summer I used it. I only use in the summer. I clean and take very good care of this machine. I went to use it this year and it came...
hi,
It has high and low fan speeds, variable humidity controls including 'Max', and automatic shut-off with indicator when the reservoir is full.
so pls recheck the automatic shut-off when the reservoir is full .
may be the automatic shut-off botten are stymed.
good luck
gorbesia
Jun 13, 2011 | Goldstar Dehumidifiers
My dh504el dehumidfier shuts off and say the bucket is full however the unit is set up to flow out a pipe
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Feb 24, 2011 | Goldstar DH504EL Dehumidifier
Won't come on
Definitely check the air filter, it has a sensor and will stop working if it's dirty. Easy to clean by running water through it.
Jun 09, 2010 | Goldstar DH304 Dehumidifier
I need to know how to attach a hose to the Goldstar DH305 Humidifier
There should be a spot on the water tank, that is threaded to fit a hose, but is blocked by a piece of plastic. You must remove the plastic "plug", the connect a hose to it. Also there is a "special" part that could be used. This part can be found at http://www.appliancefactoryparts.com/search/modelinfo.php?modelsID=117164, and I am sure other places also. I hope this helps
Jul 15, 2009 | Goldstar DH504EL Dehumidifier
Goldstar dehumidifier model # DH305
I had this problem on a similar model. There is a pressure switch the tank when full pushes in, sometimes mine would stick. A little graphite for key locks was my remedy. Had to clean it up some though. Good luck!
Jul 13, 2009 | Goldstar DH304 Dehumidifier
Dh305y6 keeps shutting of within minutes
sounds like you need to replace your humidistat control. this is just like a thermostat on an air conditioning system, except inside of sensing temp and turning off, it senses humidity and turns off.
Jul 02, 2009 | Goldstar DH504EL Dehumidifier
Will not run or turn on light will not turn on
Had a similar problem with Goldstar model DH305. A solution was already posted about cutting the two white wire going to humidity control, and it works until tray fills up (no control). However, if you want a complete fix which allows you to control by selecting humidity level go to the following site:
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=282871&modelsID=&typeName=dehumidifier
Part number is 6877A30013L
May 27, 2009 | Goldstar DH304 Dehumidifier
Dehumidifier
IS THE ROOM HUMIDITY LOW. IF IT IS BELOW 30% THE HUMIDISTAT WILL SHUT DOWN THE UNIT. THE AMMBIENT TEMP SHOULD BE ABOVE 65 DEGREES AND THE HUMIDITY SHOULD BE ABOVE 50 %.
Mar 26, 2008 | Kenmore 53301 Dehumidifier
LG DH305 Dehumidifier Logo
107 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
