Question about Samsung SC-D303 Mini DV Digital Camcorder
Tape compartment won't close - Samsung SC-D303 Mini DV Digital Camcorder
Sony dcr-trv350 tape wont close
there is a risk of hardware damage.make sure you dont force the tape into the cassette compartment to avoid damage to the unit or tape.here's what you can do.
1.remove the tape from the compartment.
2.ensure proper type and size of tape is used.
3.ensure no packaging material or foreign material inside the compartment.
4.if attempting to record, make sure cassette tape rec/save switch is set to rec position.
5.reinsert the tape, make sure it's properly inserted.
6.if still won't close or tape ejected again,remove tape.
7.reinsert a diff tape.
8.attempt to close compartment.
9.if issue unresolved, press the tiny reset button while cam is powered on (located in the panel where the lcd screen goes to,just below all the other buttons). you may also do a power reset procedure: remove batt, remove ac adaptor,set power switch to vcr, leave the cam without power for at least a minute, switch power back to off, reinsert ac adaptor/batt and turn cam on, attempt to close tape compartment.
if issue persists, service would be needed. hope this helps.thanks:)
Mar 26, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
Cannot find way to eject tapecassette
Check eject lever near battery, press it downward to open tape compartment, take out old tape and put new tape, close tape door and let it go inside by itself. Close tape compartment.
Below image will help you to locate eject button/ lever in DCR-HC18E camcorder.
Thanks.
Sep 20, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
I have a panasonic mini dv video recorder. After
close the tape compartment take the batery of press the power button on and holding the power press put the batery back and wait let me know
Jul 07, 2009 | Panasonic PV-GS150 Mini DV Digital...
Wont take tape
I just posted that I had the same problem with the Elura 100 not taking the cassette, although the compartment will close without a cassette. And I did have the problem with the left wheel rewinding, then the beep occurs.
I was tinkering a bit. I decided to take some video on the SD card, and I let it record for a moment. After that, I went back to trying to get the cassette compartment closed, and it worked! Almost like the camera needed reset.
We'll see if it stays corrected!
Prior to that, I have tried using a can of air, loading a new cassette, etc. And I DEFINITELY did NOT have any condensation!
Hope that works for ya!
Jan 31, 2009 | Canon Elura 100 Mini DV Digital Camcorder
Tape not loading
Drop it on a carpeted floor from half a metre
I got the solution fromFixYa on 3rd Feb 09 it worked for me
Dec 16, 2008 | Canon DV-MV830i Mini DV Digital Camcorder
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Sony Handycam DCR-PC1E
Yeah ! Your problem is very simple. u can solve it on your own.
If you dont put the tape the comparment closes well and as soon as you pot the tape the compartment does not close , Right ?
The solution is there within ur hands itself.
If you want the compartment to be closed, then simply dont put the tape inside. let it be outside itself. U see, its so easy !
Aug 08, 2008 | Sony Handycam DCR-HC90 Mini DV Digital...
Opening the tape compartment
something may be jammed in one of the hinges of the compartment door.
Jun 26, 2008 | Sony Handycam DCR-PC100 Mini DV Digital...
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Inserting tape into camcorder
bent guide pins, dried out grease, belts got old although you say new, some object stuck inside jamming gears.... the list goes on.
Mar 22, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Samsung SC-D303 Mini DV Digital Camcorder Logo
54 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
