HOMEMAKER WASHING MACHINE MODEL : HMXQB70-722 HOW CAN YOU GET BRA WIRE OUT WHICH HAVE GOT BETWEEN THE INNER AND OUTER DRUMS.
    Champion:
  • 207 Answers
The only way without disassembling the machine would be trough wide rubber hose which connects filter housing and drum. If you're lucky you'd be able to reach it wit your hand or some tool. Still that would require a lot of work, luck and wouldn't come out without expenses for new rubber hose since they are usually glued to drum.
Posted on Apr 27, 2008
Our Washer has a loud "ticking" noise in the wash
Could be something like a bra strap between the inner and outer drums. need to remove the agitator and inner drum to investigate and remove.
Could also be a bearing in the drive gearbox, if this is the case the machine is not worth repairing as the box is sealed and not serviceable.
Nov 29, 2010 | Admiral AW22 Top Load Washer
Bra wire stuck between inner and outer drum how to remove Hotpoint WMF760
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Jan 24, 2010 | Washing Machines
How do i reemove a bra wire caught in between the outer drum and inner drum of a hoover nextra 6 washing machine
Hi
Disconnect the machine from the power source and also disconnect the inlet hoses.
First start by opening the top hatch. You can do this by first opening the lid. there are 2 screws under plastic caps in the corners, under the lit. Open the screws.
See if you can lift the top hatch back. If not, you need to open the screws, or sometimes no. 7 bolts, in the back of the machine. These join the top hatch (plastic part) to the machine body (metal part).
When you raise the top hatch, there will be a power connection with earth wire, and a presure hose which connect to the bottom of the control panel. You can disconnect these. Take note, as you need to put them back on later.
Once you remove the top section you have clear access to the top of the drum. There is a plastic rim on top of the drum which you need to remove. Sometimes they are screwed on, and sometimes they clip into place. The old hoovers were clip on plastic. The newer hoovers are more like Simpson and have screws.
Once you remove that, look down in between the inner and outer durm and see if you can see the bra wire. If you can get to it with a long object it will be alot easier, than having to remove the inner drum. If the bra wire is free and just sitting on the base, just tilt machine to its side and with the help of a few people turn it upside down.
Removing the inner drum is a pain, and I do not suggest you do that yourself, unless you have the right tools.
However I can help you with it if you can not get to the wire. Let me know.
Regards
Ash
Nov 20, 2009 | Washing Machines
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
Bra wire stuck inside washer between drums - WSSH300GWW
If you are unable to remove the wires from inside using needle nose pliers, then my advise is to call in a professional. Taking out the inner tub on a front load machine is involved, and you open yourself up to several potential leaks as well as bearing damage.
May 04, 2009 | Washing Machines
How do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Feb 26, 2009 | Hotpoint First Edition FEW12 Front Load...
Bra wire stuck somewhere in machine
You will not see it as it is trapped between the inner and outer drum, what you need to do is remove rear panel and the large hose from the pump to the bottom of the drum,
Then reach in with your fingers and see if you can feel it , if you can't then short of removing the drum (not recommended) ther is not a lot you can do, hopefully it will find it's way into the filter, where it wiil not be a problem
Plz rate this solution.
Dec 15, 2008 | Washing Machines
Bra underwire stuck
Switch off machine and unplug it from the wall socket. Remove back plate and identify the heating element. It should be located at the bottom of the outer drum. Remove element and you will have limited access to the space between the drums. Rotate the drum slowly by hand untill the bra wire gets to the bottom of the drum. Remove obstruction with hook or long tweeser.
Oct 31, 2007 | Bosch WFMC6401UC
Fix my machine
Hi vickie234 Quite often the noise can be attributed to something getting between the inner & outer drums. If I had a dollar or pound for every under bra wire I have removed from washers I would be a rich man. Occasionally the clips that hold the element in place between the drums can also cause this same noise. Turn the drum slowly with your hand & see if you can hear the wire or clip. The only solution to this is to remove the wire. Not easy if you haven't done this before. Reagrds
Jul 22, 2007 | Indesit W 123 Front Load Washer
Bra wire has between drums
you will need to call in an on site tech.but from my exp.the tub assembly would need to be replaced if you want to solve this problem.
Jun 23, 2007 | Hotpoint WMA54 Front Load Washer
Washing Machines Logo
197 people viewed this question
Top Washing Machines Experts
