Question about Sony TA-FE370 2-Channel Amplifier
Hi there i have this amp it powers up but no sound what could it be thanks
    Genius:
  • 1,175 Answers
Is there a tape monitor function on the amp? If so, is it off?
Have you tried headphones?
Posted on Aug 17, 2010
Why does my Konzert AV502A have no sound output?
You don't give us much to go on. What happened last before you discovered your amp had no sound? Did the speaker wires cross with exposed metal? In other words, did you short out your amp by touching the negative speaker wire with the positive speaker wire? That will "Fry" your unit. Did you check the fuse? I assume you have a good power cord that is properly plugged in. Does your amp light up when turned on? What other issues can you tell us to give us more clues so we can help you?
Feb 20, 2015 | Audio Players & Recorders
Hi, i have a marantz pm720 amp, when i switch it on, straight away it starts to make loud cracks through the speakers like spikes,then it will cut sound all together for a few seconds then back on, when i...
Hi Paul;
There are one or more transistors failed in the output circuit
I would have tech look at the amp and see what the power supply is doing without spkrs connected
Aug 20, 2010 | Marantz PM7200 2-Channel Amplifier
Sound turns off after tv is started sound only one
Hi my name is Roety,
I can help you with your issue ,
Without a model number, I do work on sony LCDs.
The audio is on the mainboard. You need the mainboard replaced.
Reboot every device by unplugging the AC power , if the sound still cuts off replace the mainboard
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 10, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Vizio 42 change channel no sound for 25 sec..hooked up dvd player sound is half power???
Your main processor board may be failing.
make sure you have all settings to default, also reboot the TV by unplugging from AC power.
I will reply asap
Thanks
Oct 09, 2009 | Vizio L37 Television
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
I have a 2000 Mercedes S500 (W220) with a Bose amplifier in the trunk. Everything works on the navigation screen but the sound. NO SOUND.
hello,good day,yes your may check the power supply and contact,if not corrected,send your car to a dealer for proper diagnose,maybe erase fault or configuration of your system is needed,to correct the problem,ty
Jul 22, 2009 | 2000 Mercedes-Benz S-Class
Hi, Peavey Classic Guitar amp , Has NO SOUND
Hi Mike,
If you switch on the amplifier, do you hear nothing at all?
Or do you hear low level noise or hum out of the speaker?
Don't know if you're technician.
If the tubes are glowing, you can measure the high voltage.
Check also fuse 3 and 4, thats the neg. voltage -27V and -14V.
regards,
Gerard
Jul 06, 2009 | Peavey Audio Players & Recorders
Sony TA-FE370 2-Channel Amplifier Logo
115 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
