Question about LeadSinger MVK2 Consumer Microphone
Product is leadsinger karaoke -Model Enter Tech LS-K2.. The unit failed to fully turn on after the first two screens that indicated that the memory strip was detected folloed by advice to wait, After many tries the unit never worked even one time. I tested the memory strip P/N Leadsinger II - 50 Tracks- Party Mix on a computer. It showed that the memory strip was devoid of any data. A properly loaded MS is needed.
  • 11,800 Answers
Have you tried it with another memory strip/ SD card ? Maybe the one you have is a dud? If you can't find another one you could buy a Karaoke disk and just copy some of the files from it in your card, and plug it in the mic - if even now it's failing then you bought a defective item, get your money back.
Posted on Aug 06, 2010
  • phylgene Aug 12, 2010
    The problem was not isolated to be a firmware, software, medium or hardware problem so best solution was to replace the system (at no cost) with a working unit. The manufacturer nor any one in the organization responded to telephone or email queries nor is the system advertized on ebay.
How to connect enter tech model ls 3700T karaoke to tv
connect the RCA-cable to the TV one by one;
yellow (video),
white and red (audio).
Change the TV mode to "AV" or "Video" after
the magic sing is turned on.
Oct 03, 2012 | EnterTech Enter Tech Magic Sing Mic...
I cannot directly enter any song sumber bigger than two digits. What am I doing wrong?
Hi, you question is directionless, what product are you talking about and model is it. You have to provide these information for me to ba able to answer your question...
Take care
Feb 19, 2010 | LeadSinger Wireless HiFi Remote Duet Mic...
Downloading
you could have downloaded a different format. try to read the manual of your karaoke, look what kind of format used, then download the same format.
Dec 26, 2008 | LeadSinger LS-3222 Consumer Microphone
Cable conexion is broken
I removed the cable from microphone circuit board  and shortened cable by 20 cm. to eliminate damaged wires, stripped the individual wires and soldered the pins to the new wire ends and reassembled.  Used black heat shrink tubing  [10mm dia.] to reinforce cable end at mic to prevent future damage from careless handling.
Document wire colours to pins before disassembly
Red                   Audio L
White                 Audio R
Blue                   DC Power
Shield [ground]     Ground
Yellow                 Video
Dec 13, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
Karaoke microphone and wireless mic
Cord rolling might generally cause damage to the internal wiring.the only possible repair option is change the wire inside.A suggestion is to try not to wrap the cord tightly with the microphone.fold it separately and use a band to hold it.
Dec 10, 2008 | LeadSinger LS-3222 Consumer Microphone
Leadsinger sub mic, modle LS 3222. Green lite flashing but no sound. any help?
We had this problem too. Can you perform any functions with the duet mic? We couldn't, just had the light flashing. Turns out the light is supposed to flash (never is solid). Check the connections to the sub mic pack in the back of the main mic. Ours was loose. Once that was plugged in properly, we turned everything off and started again. All was fine.
Good luck.
Nov 29, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
Magic-Sing EG-18000 works, no sound
look and see if the RF light is coming on, if it is not then the transmitter (mic) is not on the same frequency as the receiver.
Nov 22, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
LeadSinger MVK2 Consumer Microphone Logo
797 people viewed this question
Top LeadSinger Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a LeadSinger Audio Player and Recorder Expert? Answer questions, earn points and help others
