Question about Goodman CKL60AR60 Air Conditioner
Leak found in evap coil. Need to replace 2.5 ton evap coil. would like to know thw cost. Please advice
  • 144 Answers
Im not sure what your seer is or the type of freon you have in it this coil may no longer be available I would need more info
Posted on Sep 11, 2010
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
I have a 1.5 ton air handler unit that keeps freezing. Ive blown the lines cleaned thw coils and replaced the filter.
If you have done all this then you need to have a tech come and top of the refrigerant, and if he doesn't see a leak, but you have a slow leak that happens over time it will freeze again.
Low level will cause the handler to freeze with other conditions, but it appears you have covered the rest.
Apr 12, 2013 | Goodman Manufacturing 1.5 Ton 13 SEER Air...
What evap coil can be efficiently used with a 10 seer rheem raka-024jaz condenser
Hello, if the outside condenser is 2 ton than the inside evap coil should be 2 ton aswell. There are 12,000 btu's per ton and the number 024 in the model # represents btu's per ton so you have a 2 ton unit.
Jun 25, 2012 | Heating & Cooling
EVAP COIL REPLAESMENT PART # MODEL # CK36-1B
You will want to pick up a 3 ton coil. The 36 stands for 3 ton, 42-3.5 ton, 48-4 ton and so on. When replacing coils, the biggest thing to worry about is size and diminsions
Jun 22, 2011 | Goodman Heating & Cooling
I am removing a 3 ton condenser and replacing with a 31/2 ton condenser . The evap coil is a 3 ton with an expansion valve with a 11/2 ton to a 3 ton rating. Will i have any problems. The 31/2 ton unit is...
Yes you will have problems you can go up a 1/2 half ton on the coil but not with the condenser don't do it you will regret it even with an expansion valve.
Jun 21, 2011 | Heating & Cooling
My 7 year old Kenmore (Frigidaire) top-freezer refrigerator M/N 253.73092302 has lost much of its cooling ability during the past 2 months and it is gradually getting worse. Recently, it quit making ice. ...
Not good news by exactly what you said shows a freon leak depending on the location of the leak perhaps on the suction (low side) the likely hood is that the cost of evap coils and or the compressor is better to buy a replacement. Sorry to be the bearer of bad news. What I found here at my location is that L.G. is a poor choice parts take along time to receive and some tech info is hard to get.
May 14, 2011 | Refrigerators
This is a 3 1/2 Ton unit that is low on R22 but still does cool enough to freeze up. The A/C tech insists that it needs over 4lbs of freon, does this seem right to you?
Hello TF YES to make ice on low freon you lost more than 1/2 of the factory/system charge.4 lbs is about rite.I would like to find the freon leak as you will always have to replace the gas every now & again untill found & repaired.
Aug 03, 2010 | Heating & Cooling
Carrier air handler tonnage?
That is a fairly large difference. It is usually ok to have the inside evap. coil and blower up to 1 ton larger than the outside condenser. That will make the unit slightly more efficient as well as less likely to freeze up on low airflow situations. It is not recommended to install a new condenser on an old evap coil. There has been a lot of changes to the design of the coils in the last little while. For example a 10 year old 2 ton coil may only have 3 cubic feet of volume but a new 2 ton coil may have 4 cubit feet of volume.
There are many factors that may have infulenced the decision on what size condenser to install. Many of which can only be done by visiting the home and doing alot of work, checking the duct sizing bioth supply and return, inspecting the insulation and windows of the home etc. etc. Most of the time that never gets done. You can blame the contractor for not doing a complete check, but at the same time you can blame the customer because many contractors that are that good loose the job to a cheaper bid that did not no any of the research. It is a catch 22 for everyone involved.
There is ALOT more to sizing equipment that many people think, sadly that also includes many HVAC contractors. Way too many people use "rule of thumbs" or flat out "guess".
Sorry for the rant but your queston can only be answered by a good well educated HVAC contractor visiting your home. That type of a contractor is getting hard to find these days in such a price competetive world.
Oct 14, 2008 | Carrier Heating & Cooling
Evaporator Coil
Yes, just count how many pins per inch and replace with the same number of pins per inch.
Sep 09, 2008 | Heating & Cooling
Goodman CKL60AR60 Air Conditioner Logo
52 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
