Question about Sony Bluetooth Headst HBH705 Sandcolor Wireless Headset
How to put a hbh705 into pairing mode - Sony Bluetooth Headst HBH705 Sandcolor Wireless Headset
  • 677 Answers
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Posted on Aug 06, 2010
How do i put lg hbs-700 into pairing mode
I had the same issue, fixed by using the Manual mode for pairing. From the manual:
2) Manual Pairing (Pairing with another phone or re-pairing)
a) With the Power off, press the CALL button and move the power switch to the
'ON' position at the same time for 4 seconds.
b) When the headset enters Pairing Mode, the LED indicator will show a solid
blue light. After the procedure repeat Easy Pairing steps c through f.
Steps C through F are to go to the bluetooth settings area and manually select the HBS-700 for pairing.
Mar 14, 2015 | Home
Big Ble / iphone 5s pairing
clear any past stored passwords. reset unit and put into discovery mode. Usually holding the pair button for a few seconds puts the LED blue into fast flashing - discvery mode
Apr 09, 2014 | Brookstone Big Blue Live Wireless...
Jam2 speaker will not go into pairing mode so i can pair it with my ipad2
On my Jam2, pushing and holding the play button puts the device into pairing mode. Nothing in the instructions suggests this, but it definitely works. You'll know it's gone into pairing mode when the blue indicator light begins flashing quickly.
Sep 08, 2013 | Radio Communications
Phone cannot find headset
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone.
Mar 11, 2010 | Samsung Bluetooth?® WEP200 Headset...
Pair bluetooth em227 with my phone
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Mar 05, 2010 | Southern Telecom Emerson Bluetooth Headset...
I don't know how to pair it to my mobile phone..need to put the headset inot pairing mode??
Yes. To put your headset into pairing mode:
1.) Make sure your headset is off.
2.) Hold the Power Button on until the blue light stays lit (about 8 seconds). This puts it into pairing mode.
Nov 05, 2009 | Samsung WEP170 Wireless Headset
How do you put in pairing mode?
Here's how to get the LG HBM-710 Bluetooth headset into pairing mode:
While the headset is OFF, press and HOLD the power button. CONTINUE to do so even after it has powered up. About 3-4 seconds after the startup beeps there will be one more beep. Then, the red light will go solid.
You are now in pairing mode! Hooray!
Go through the necessary 'Add a Device' steps on your cell or whatever and you should be G2G!
Mar 24, 2009 | LG HBM-710 Wireless Headset
I cant pair motorola H350 to Voyager
Can you pair the voyager with anything?
Are you putting the bluetooth headset into pair mode correctly?
Feb 06, 2009 | LG VOYAGER VX10000 Cellular Phone
Pairing 730 and lg vx 860
To put the LG HBM-730 into pairing mode you must press the MFB for 5-10 seconds from power off. Pairing mode is denoted by the LED glowing solid red. LG has chosen to stick with the default pairing code of '0000'. Using Bluetooth specification 1.2, as is the custom, the HBM-730 supports both headset and handsfree profiles.
I found this on the internet and hope it works for you
Sep 05, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Activate pairing mode
Holding down the multifunction button for eight seconds puts the unit in pairing mode and an LED lets you know the status of the headset. Flashing blue and red means the H4 is in pairing mode, flashing blue means it is paired and flashing red means the H4 needs charging.
Aug 10, 2008 | Cell Phones
Sony Bluetooth Headst HBH705 Sandcolor Wireless Headset Logo
619 people viewed this question
Top Sony Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Rob Beech
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
