Question about KitchenAid KIRD801HSS Kitchen Hood
KIRD801HSS. Can this be installed in an island, I think I read somewhere that it requires a larger than normal base cabinet
  • 8,197 Answers
Yes you can install vent in an island. If you need the install manual you can get it on the link below.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208284826.pdf
Good luck
Posted on Aug 07, 2010
What is a standard kitchen counter depth?
Counter depth is key to functional, comfortable kitchen design. Standard dimensions keep cabinetry within reasonable size for average-height users, and in relation to common sink and appliance sizes, but guidelines allow for slight or moderate changes. The countertop overhang plays a couple of roles and affects counter depth.
Standard lower, or base, cabinets are 24 inches deep, while upper, or wall, cabinets are 12 inches deep. Countertops typically overhang their base cabinets by about 1 inch, or at least 3/4 inch beyond the drawer fronts and cabinet doors. The overhang helps keep crumbs and spills from getting into drawers and cupboards below and completes the comfortable cabinetry contour that includes a 3-inch-deep toe kick on the floor. Island or bar-style overhangs often extend about 15 inches or more to create knee space for people seated at the bar. Deep overhangs require bracing, which may be provided by brackets, legs or even a steel plate underneath the countertop.
Apr 14, 2018 | Refrigerators
How do I find somewhere to tie in a set of fog lights, into the low beam head lamps.
Any reputable auto repair firm should be able to do this ok. Don't forget that you may be required to install a larger fuse or it may blow fuses as soon as you go to dim. Fuses are normally found under the hood or under the dash on drivers side.
Feb 21, 2015 | 2012 Honda CR-V
Dehumidifier smells stinky
Have you read its manual? http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0220en.pdf
It says (p8):
Care and Cleaning
1. Filter
a. Remove the filter every two weeks based on normal operating conditions.
b. To remove the filter, remove Bucket then pull filter downwards.
c. Wash the filter with clean water then dry.
d. Re-install the filter, then replace Bucket.
2. Cabinet
a. Dust cabinet with an oil-free cloth, or using a damp cloth.
b. Vacuum grill using brush attachment.
3. Water Bucket
a. Clean bucket with warm water and detergent.
I recommend you to use a mix 75% water, 25 % vinegar. To clean its water bucket.
Oct 01, 2012 | Frigidaire FDF70S Dehumidifier
Wall Oven does not fit flush into built in cabinet
I HAVE SEEN SOME CABINET MAKERS BUILD A TRIM PIECE THAT GOES ALL THE WAY AROUND THE EXISTING HOLE THAT HAS AN OUTSIDE DIMENSION LARGER THAN THE CABINET HOLE AND AN INSIDE DIMENSION TO FIT THE REQUIREMENTS OF THE OVEN. IT ATTACHES TO THE FACE OF THE CABINET AND STAINED TO MATCH THE CABINET FINISH.
Apr 10, 2008 | Ovens
Janome sewing machine
What sort of cabinet do you currently have, and is a photo possible, .....
...have you measured the overall size of the "footprint" of your machine, and will it fit, some larger Janome's are larger than a "standard" size for the likes of a Horn Cabinet (see them here), although a larger insert is possible for certain models.........I think a little more info is needed for us to really be helpful.
Feb 09, 2008 | Janome 1017 Mechanical Sewing Machine
Put together
1 Chrome Rail (for attachment to Worktop)
4 Self-Tapping Screws (to attach chrome rail)
1 CO2 Cylinder Support Stand
1 CO2 Cylinder (empty)
1 CO2 Regulator (high/low pressure gauges)
1 CO2 Air Line Hose (red)
2 CO2 Air Line Hose Connectors (black)
1 Beer Keg Coupler
1 Beer Tower Unit (complete with faucet, hose and wing nut)
1 Rubber Washer (to be installed inside wing nut)
1 Beer Tower (Quick Connect) Bayonet Attachment (beer tower installation)
4 Machine Screws (to attach bayonet to beer tower)
1 Gasket (beer tower base)
1 Pull Handle (beer tower faucet)
1 Beer Keg Stand (required for 30 liter keg installations only)
1 Protective Plate (refrigerator cabinet floor)
2 Cantilever Wire Shelves (conversion to all refrigerator application)
1 Chill 'n Tap Exterior Cabinet Plug (located on worktop)
1 CO2 Air Line Hose Plug (located exterior rear cabinet)
1 Plastic Drip Tray (2 piece)
1. Remove Worktop: Using a Phillips Screwdriver, remove the
three screws located on the front underside edge of the
worktop and the three screws located at the rear (back)
side of the worktop.
See Fig's. 1 & 2
Remove the worktop from the cabinet and position the
worktop on top of the cabinet so that the front corners
are staggered across the front corners of the cabinet.
2. Installation of Top Rail: Attach the chrome rail to the work
top using four self-tapping screws from the underside of the
worktop through the pre-drilled holes. (attach the front ends
of the rail first)
3. Re-Install Wo r k t o p : Install the front of the worktop onto the
cabinet, then lower the rear side of the worktop over the
backside of the cabinet. Secure using the same screws
removed earlier. (the smaller screws at the front the larger
screws at the rear)
4. Installation of CO2 Cylinder Support: Install the cylinder
support onto the four studs located on the exterior back
wall of the cabinet. (no tools required) Align the holes in
the cylinder support with the studs and push down firmly.
See Fig. 3
5.
Installation of CO2 Cylinder: Install your " fully charged"
CO2 cylinder into the support stand. IMPORTANT NOTICE:
ALWAYS EXERCISE EXTREME CAUTION WHEN
HANDLING PRESSURIZED C02 CYLINDERS:
6. Installation of C02 Regulator:
Attach the CO2 Regulator to
the C02 cylinder by screwing the regulator nut onto cylinder
valve and tighten (snug) using an adjustable wrench.
7. Installation of C02 Air Line Hose to Regulator: Attach one
end of the (red) air line hose to the hose barb connection
on the CO2 regulator. Secure hose by using one of the two
(self locking) black plastic snap on clamps provided.
(use pliers to snap the clamp tight to assure that there are
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
CHI
See Fig's. 1 & 2
of the rail first)
screws at the rear)
See Fig. 3
5. Installation of CO2 Cylinder: Install your " fully charged"
6. Installation of C02 Regulator: Attach the CO2 Regulator to
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
LL'N TAP ACCESSORIES (included with this unit)
Jan 07, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
KitchenAid KIRD801HSS Kitchen Hood Logo
191 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
