Question about HEALTHRIDER S600 Treadmill Motor Control Board : 152004
My treadmill stops abruply after 20 minutes or so. what can be the problem /
    Scholar:
  • 34 Answers
This machine has what they call a thermal switch. It is designed to
shut the machine off if it gets too hot. This heat is caused by
friction. Friction is caused 99% of the time by the walking belt or
the drive belt. If it is the drive belt then it can be solved by
either applying a treadmill lubricant (must be made for treadmill
belts) or by purchasing a new belt. If you feel the underneath side
of the belt and you feel a screen door type feeling you just need
lubricant. If you feel a smooth surface you will probably need a
new belt. If you have lubricated in the past year and your belt has
the screen door feel then take off the motor hood cover and check
the drive belt. If it is worn then you will need to replace that.
You can purchase either of these products from the manufacturer, at www.iconservice.com. a couple of other places that may have them for discounts are www.ebay.com, www.fitnessrepairparts.com, or www.treadmilldoctors.com.
Posted on Aug 10, 2010
My t9600hrt treadmill stopps working after about 15min and then i can start it up again and same
Lube the treadmill for deck belt+roller bearing too.
This happen because the lack of maintenance schedule.
See the video, if after you fix it, the problem remain, is TIME to replace the old deck board.
God bless you
Feb 25, 2013 | Vision Fitness T9600 Deluxe Treadmill
My treadmill runs for 15 minutes than stops for a minute than start up for 10 minutes than stops, than start up
It is designed to be able to be restarted after about 5 minutes. When it stops, wait 5 to 10 minutes, reset the circuit breaker. Of course you still have the same problem.
The motor contoller board is most likely overheating do to friction, so you're going to need to lubricate the walking belt(this should actually be done every 6 months) you can order a kit on ebay for about 15-20 bucks, it's called " lube n walk ", and no, I don't sell it, but I use it on the treadmills I service.
I recomend you loosen the belt one full turn on each side before you lube the belt, apply the lube and run the treaadmill for one mile without anyone on it and then let it rest for a while.
After that give it a try. if the belt slips, then tighten it back up one turn, but don't over tighten it.
I also recomend using a single outlet surge supressor.
That should solve your problem.
Jan 11, 2011 | RTO Image 15.0R Treadmill Walking Belt
The treadmill stops after about 20 minutes or so. I push the fuse back in, and then I can start it again. It shuts off again after 15 - 20 minutes or less. Can I replace the fuse, or what is the...
try lubricating the running belt. Any decent sized fitness store should have a lubrication kit. Also, make sure the machine is plugged into a dedicated circuit. Meaning, there are no other devices on the same circuit as the treadmill. Not just the same outlet, but the entire circuit of the room you have the treadmill in. You also want to make sure it's not on any extension cords. Plug it into a surge protector (power bar with a cord less than 6') and then directly into the wall. Those are the 3 main culprits why treadmills shut down after a short period of time.
Jul 10, 2010 | Proform LX660 Treadmill Walking Belt
I have a 1400 that when it has been running for 20 or 30 minutes goes to Power Failure and generally throw me against the rail to an abrupt stop. I do believe it is home electrical as I run a 20 amp...
This generally means that lubrication is needed to be applied between the belt and belt. You may purchase these kits thru www.jadfitness.com the products name is Lube and Walk follow the instructions that come with it to apply the lubrication.
Jun 11, 2010 | New Balance 1400 Treadmill
Treadmill shuts off after 20 minutes need to reset
do a friction test- put key in console,without pressing ANY other buttons, make incline go up to 10. then push yourself off backwards, if diffacult, this is friction,like rubbing hands together, no lube under walking belt- walking belt needs to be replaced, when it shuts down belt stops but console keeps going- its friction
Jan 06, 2010 | Life Fitness 9100 Next Generation...
I have a Proform 760 EKG treadmill. It suddenly stops dead, (and I mean stops!) after 20 minutes. I have been thrown from the deck a couple of times before I got an egg timer to keep track of the 20...
yes, unplug your unit.
Use a 9volt battery and touch the red and black wires to the battery coming from the motor. if the motor moves it's good. if not you need one. you can visit www.iconfitness.com to order this part or contact us @ www.nashsfitness.com
Aug 09, 2009 | Exercise & Fitness
Walking speed for 2 hours and the machine just shut off would't turn back on for 20 minutes why?
The motor has a thermal protection device that will stop the motor if it becomes overheated. Eric
Aug 04, 2009 | Nordic Track /proform Treadmill...
HEALTHRIDER S600 Treadmill Motor Control Board : 152004 Logo
416 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Techmotionusa.com
Techmotionusa.com
greg kinsley
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
