Question about Jandy Lite 2 Natural Gas Pilot Light Heater
I have a Jandy lite 2. The heater didn't work and I had a fl4 code. the repair man replaced 2 fuses and it worked but he told me that the power control board could blow unless i had the voltage changed from 230 to 115. Before i could have this done the board blew. I finally had the voltage changed and the power board replacement was almost $1000. The repairman told me that jandy knows that this happens at the higher voltage but refuses to acknowledge it. What do you think?
  • mzgodny Aug 07, 2010
    The solution was helpful. I now feel that I did all I could do.
    Thanks
  • 2,272 Answers
Yes the repair men is correct.That this board blows at higher voltages.Many other users are too facing this problem.But if the unit is under warranty the Jandy company is really helpful and provides replacement in such cases.But if its out of warranty then getting the board replaced from local repair men is advisable,because company charges are very heavy for the same replacement procedure of board.
Thanks.
Posted on Aug 06, 2010
Jandy Lite 2 LJ pool heater FL4 Fuse amp size
if blown they are 220 volt 3 amp you can also remove them
May 20, 2015 | Jandy Pool & Spa
Had an FL4 error code and in-line fuses were blowing, replaced the R0367100 igniter (old one missing the tip) and fuses, but still blowing the 2 fuses and getting the 04 code.
make sure the wiring is correct then take fenwall off turn around to see if burned spot where ignitor wires go in sometimes the ignitor will take out the fenwall shorting it out so you will keep going through ignitors
Sep 15, 2014 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
Jandy Lite 2 heater won't ignite FL4 code?
So, you replaced part R367100 (Igniter)? This part if very susceptible to failure if touched. I would inspect and/or run a continuity check to make sure it has non cracks. Does it glow red when you attempt to start the heater? Remember, that is the how it ignites the flame, by getting red hot.
If it glows red hot, but does not light then I'd do the following testing in between;
Check that the inline fuses on the igniter aren't blown,
Check if the control board is sending a charge,
Check the flame sensor for gunk build up. Unfortunately to replace the flame sensor look like you have to purchase a whole new burner assembly to get a new flame sensor.
I also believe there is a toggle switch on the front door. It may need to be depressed before the system will ignite.
May 10, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy lite 2 heater model lj325n - code fl4 - hot surface igniter problem- I tapped the gas valve and checked the fuse , still getting the same code.
Igniter circuit is open. Check fuses on igniter wires. Identify and correct loose or broken wires.
Element has a fine crack in it. Replace
Igniter fault. Replace igniter.
Aug 31, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Fl 4 code
fl4 = Igniter Failure
A. Igniter circuit is open: Check fuses on igniter wires
B. Element has a fine crack in it: Replace igniter
C. Igniter fault: Replace igniter
Apr 09, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy Lite 2 heater gives FL4 display
F is an igniter failure. Try the following. A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. C. Replace igniter.
Jul 10, 2009 | Jandy Laars Lite2 - 125,000 BTU Propane...
Describe your Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Problem FL 4 code and have changed igniter and still getting the FL4 code its the lite 2 model...
A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. See manual for details. C. Replace igniter.
Jul 04, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
