Question about Canon PowerShot A75 Digital Camera
When i depress the button to take a picture there is a significant amount of time that passes before the picture actual is taken. 9 out of 10 times the "moment" is gone
    Brigadier General:
  • 11,967 Answers
You need to learn the "half-press" technique. You press the button half-way and wait for the camera to lock in the focus (it will beep)...then when the moment is right, press the rest of the way.
Posted on Aug 06, 2010
How to set self timer for D90
Instructions for this are on Page 179 of the D-90 users manual. First go to the menu and select the custom settings menu then scroll down to "timers/AF Lock."
Select this then select the number of shots you want the camera to take at one time on the self timer setting. Exit the menu.
Then go to the top of the camera and find the little button to the right of the control panel which contains a series of stacked rectangles.
Depress this button (camera must be on) and the control panel will clear. Rotate the wheel on the back of the camera while holding the button down until you see a little clock symbol.
If you have set it in the menu to take only one shot, you will see only the little clock. If you have set it to take multiple shots you will see the series of stacked rectangles next to the little clock.
Depress the shutter fully then walk or run to get in the picture. Just before the picture shoots, the autofocus light will flash warning you that the picture is about to be taken. The camera will shoot in the amount of time you have selected in the menu.
If you want to shoot another delayed shutter picture, repeat the procedure using the button and wheel.
May 10, 2013 | Nikon D90 Digital Camera with 18-105mm...
Jaguar XK8 2008 Handbrake module location please
I assume the brake is stuck? If so do this,Lift handle until there is significant tension, then press the button WHILE pulling up at the same time. Now lower the brake while keeping the button depressed. __________________
Nov 08, 2012 | Cars & Trucks
I just installed a new power supply and now i get a message saying cd rom priority...no medium i then stat it up with my recovery disk it asks what language and that it will reboot the system to factory...
Installing a new power supply should not involve any recovery process. You may have corrupted the hard drive some how prior to the power supply going out. And, if it has taken a significant amount of time to process the recovery, the recovery partition in the hard drive may have been affected as well. You're probably going to need the actual recovery disc to reformat the hard drive - chances are the hard drive is just corrupted and is still good.
Jan 08, 2011 | Dell Computers & Internet
How do you erase all of the stored pics on the sd card at once?
Use the Format command to quickly delete all images from the memory card. This will also prevent fragmenting of the memory - which can significantly slow the transfer of images to your computer - and increase the amount of time it takes to save a picture after pressing the shutter button.
To format a card on in your camera, at the main menu choose "Settings" then select "Format".
I hope this helped!
Oct 22, 2010 | Samsung L100 Digital Camera
Air is leaking through trigger when trigger is not depressed. When trigger is depressed and nail tail cover is in safety position (holding gun in air) it completely stops. The gun fires well but there is...
could be either that or a damaged o ring, when was the last time serviced, all o rings replaced?? could be that the tool needs a thorough cleaning and new one installed. it is not hard
Aug 26, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
The shutter button doesn't take a picture
you have to hold down your shooter button a little longer for image to be taken.it makes it look as if you are pressing the button twice. the first captures the image and the second takes the actual shot.QED.
Dec 29, 2009 | Canon PowerShot A540 Digital Camera
Canon 40D LCD Wont come on buSY flashes in view finder
Okay, this is simple. Your camera can take several pictures at one time in a burst. However when you release the shutter button your processor takes a second to actually SAVE the pictures to the card in the camera. One thing than has helped me in my wedding photography business is to buy the fastest speed cards I can find. It significantly reduced my "busy" time.
Nov 30, 2008 | Canon EOS 40D Digital Camera
Delay in picture taking
Melzim, another user, is exactly right. The lower-end digital cameras experience a significant shutter delay when using the camera; it's an unfortunate fact.
What you can do, outside of investing in a newer model (which do have improvements over the earlier models) is simply try to anticipate your subject's movement - or concentrate on portraiture, etc.
There is a huge value, over time, in having pictures of smiling families, standing still, believe it or not.
The A85 is simply not the camera to use to freeze action.
-lizwb
Nov 06, 2007 | Canon PowerShot A85 Digital Camera
Response time not where it used to be
"I wonder if it's the battery" (he says desperately bashing his head against a brick wall)
Jun 28, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Problematic Camera
I just discovered that the real problem is a STICKY SHUTTER BUTTON, staying down after taking a picture. This prevents the green ready light from coming on until I jiggle the shutter button. It has actually started to be hard to press, making a definite clicking sound as it goes down. I can even feel it catch on something. If I move it around a bit, it will eventually come up, allowing the ready light to reset. Can this be cleaned? How about adding a drop of WD40 or something? Anybody ever take one of these apart? Any tips as to how to do it safely??? Thanks.
Sep 13, 2005 | Kodak EasyShare DX4530 Digital Camera
Canon PowerShot A75 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
