Question about Hayward Navigator Pool Cleaner
POOL CLEANER GETS STUCK ON THE MAIN DRAIN - Hayward Navigator Pool Cleaner
If it's an older Navigator and it just recently started to hang up on the drain cover, replace the throat assembly, part 29. The lugs or hold offs on the bottom of the assembly have worn down and are not breaking the suction as the Navigator travels over the top of the domed drain cover. Replaced mine and no longer have the "my navigator gets stuck on the main drain" problem.
Posted on Aug 13, 2010
    New Friend:
  • 4 Answers
Possibly worn shoes or access cover. Install hayward main drain bumper. Its sold as bumper for pool vac ultra. Works on most covers. You'll see the concept and figure it out.
Posted on Jan 06, 2016
  • 990 Answers
You need to shut your main drain off. Your cleaner acts as a roving main drain and picks up heavy dirt. Tyhis replaces the main drain. When you leave it active the cleaner suction and the main drain suction together cause the cleaner to stop dead.
Posted on Aug 06, 2010
  • David DiStefano Jul 03, 2011
    This is a MAJOR problem with MANY users. I found the solution at: www.maindrainclipon.com
    The owner/inventor is an aeronautical engineer who had the same problem so he designed and patented a solution
My barracuda g3 gets stuck on the drain after working fine since I moved into the house 4 months ago. I have the main drain turned off. I recently got a new diaphram, although it worked for a couple of...
I would first try turning the drain valve off. If it quits getting stuck then maybe that is the solution. If so then maybe you can open the drain valve only slightly and it will still not get stuck. If it gets stuck even with the drain valve off then you guess is as good as mine.
I hope this helps.
Sep 14, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My Hayward pool sweep gets stuck when it goes over the drain at the bottom of the pool
It could be worn shoes on your pool cleaner causing the problem, but it is most likely just that you need to get a ring drain cover to cover your anti-vortex drain. It creates a smoother surface and is designed specifically to work with in ground automatic pool cleaners that are getting stuck on the drain.
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
Mar 19, 2011 | Hayward Navigator Pool Cleaner
My barracuda gets stuck on pool's drain. This is annoying since I have to be around to watch it and pull it off. Valve to main drain is shut. What else should I do?
There is a ring that you can buy to go over anti-entrapment main drains that will prevent automatic pool cleaners from sticking on the drain. They are designed specifically for this purpose. If you are sure that the main drain in closed, this is going to be the best and cheapest solution.
Jan 28, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
The barracuda keeps getting stuck on the main drains. I have tried every different setting to even with no vac on the drains it still gets stuck what to do
Is your main drain closed completely? That is the first thing to check. If the main drain isnt completely closed, that is going to be your problem. If it is the pool cleaner that is causing the problem, there is a ring that you can buy that goes over the main drain to prevent automatic pool cleaners from sticking. You will need to install one of these and it should remedy the problem.
Jan 18, 2011 | Zodiac Baracuda G3 Automatic In Ground...
Our baricuda g3 often gets stuck on the main drains in our pool. we have the main drain lines shut off. cant figure out why the cleaner only gets srtuck in that one place
Since you have already verified that the main drain line is closed, it sounds like you need to install one of the smart ring drain covers below. They are made specifically to work with in ground pool cleaners to prevent them from becoming stuck on the main drain. They are easy to install and should eliminate the problem.
Nov 06, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
It gets stuck in the pool drain and wont move
If these pool cleaners are getting stuck on the main drain, it is probably an easy solution. First, make sure that your main drain in closed. Make sure the main drain grate is installed. If the main drain is not flush with the pool, you have an installation problem and you will need to consult with a pool builder about soultuions to fix it.
Aug 18, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Stuck barracuda
It is probably not a problem with the shoes. These pool cleaners (and automatic pool cleaners in general) often get stuck on the main drain since the implementation on the new anti-entrapment drains. There is a ring that you can buy that goes on the drain. It is designed specifically for preventing pool cleaners from getting caught on the main drain.
Jun 08, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Baracuda always gets stuck on the main drain plug in the inground pool
I have found an inexpensive device that will fix this problem. Go to www.maindrainclipon.com for details.
In addition you can buy an installation tool that allows you to install the device on the existing main drain without getting into the water.
Mar 15, 2010 | Zodiac Baracuda G3 Automatic In Ground...
The zodiac G4 pool cleaner has slowed down considerably and now gets stuck on the drain so i have to continually drag it off so it will circle the rest of the pool
Your Zodiac should ballence all suction with the skimmer and no suction should go through the main drain. A main drain is better called a deep suction to collect heavy dird and your cleaner is a roveing suction and replaces the drain. If both are on the two suctions pulling against each other will always stop the cleaner.
Oct 03, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Hayward Navigator Pool Cleaner Logo
1,946 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
