SOUND BUT NO PICTURE
THE PROBLEM IS I HAVE SOUND BUT NO PICTURE , IT SEEMS TO START UP OK AND AFTER IT HAS WARMED UP THE PICTURE DISSAPEARS,
  • bmar1108 Jan 20, 2009
    sound but no pic
  • 558 Answers
Blown capacitors on the inverter / vga board replace them and al will be good.
Posted on Apr 27, 2008
My samsung led tv is getting dark
With a DLP TV, getting a darker picture means it is time to change the bulb.
Feb 16, 2015 | Samsung Televison & Video
Lg 42le4500 tv when first turned on its okey after 2 minutes no picture black screen but sound ok, turn it off and back on againdoes the same
I would bet on some component(s) have become thermo sensitive. Most of the time capacitors can do this type of thing. Most likely the defective caps could be in the power supply.
To locate the defective caps, you would have to be able to run the supply and use the combination of a heat gun and freeze spray (liquid air spray) for cooling. At the same time you would have to monitor the output of the supply to see the components that cause the output change.
It is also possible to have thermo sensitive components on any of the other boards. This would also require proper troubleshooting.
The service rep would replace boards until he found the defective board. Then he would return the set with the new board and the bill for his work.
If your set is out of warranty, it may be better to consider a new set. Servicing these can be fairly involved and expensive.
Jerry G.
Jun 25, 2012 | LG Televison & Video
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
Picture loss
Hi Joe
has the problem been resolved, I am experiencing the same thing, guarantee is 3 weeks out of date -typical!!
Jan 16, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Sony Videoscope TV continuous hissing sound from back of tv and picture seems to be getting worse model kp 46c36 year 1997 once tv has warmed up hissing sound stop but picture still a little iffy
Ur high voltage is dying,the FBT,the flyback transformer is the prob.the big block of plastic with a red wire a with a cap hook to the CRT(crt tv).
Sep 29, 2009 | Televison & Video
Toshiba tv when switched on no picture n no sound comes
**presuming** this is a horizontal, very thin line right in the center of the tube, and sometimes the picture is ok, then the vertical circuitry has one or more bad solder joints.
A ***QUALIFIED TECH*** needs to resolder the joints in this area. This is not a beginner soldering job. Special care must take place to avoid electrical shock or WORSE!! seriously.
Feb 12, 2009 | Televison & Video
Picture won't come in clear until TV "warms up" for 15 minutes or more
Change the capacitors first per the instructions in the link below. Symptoms could be anything from high-pitched hum to no picture at all. On these defective models, I would start at the caps and work back. It won't hurt to replace them anyway.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Aug 28, 2008 | Polaroid FLM-323B Television
I have an Sharp Aquos flat screen tv and it is randomly 'blacking' out. The picture dissapears but there is still sound and i can still use the remote. I have it hooked up through a set top box, but there...
If the unit is still under warranty take it back for refund or replacement. If your tv is not under warranty, then you have a problem with the inverter board or the bulbs (ccfl) are bad. I have seen the inverter board and the bulbs be bad. Good luck to ya!
Jun 11, 2008 | Sharp Televison & Video
How do I fix this?
seems like you have either a lose joint or a crack in the board in the vertical section of the tv. if you are a tech person you could open it and check it out. good luck
Nov 29, 2006 | JVC AV-42WX94 42" TV
Open Questions:
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
