Question about Dryers
Amana gas dryer model tga400w - need the part number for the belt so I can get a replacement
  • 94 Answers
SOURCE: Amana dryer belt
You will probably have to open it up from the top and/or back. If the belt looks alright (it probably won't, though), check the belt tensioner. Carefully observe how the belt goes on and around the tensioner before replacing.
Posted on Oct 07, 2007
yalmer
  • 552 Answers
SOURCE: How to replace drum belt.
Opening the cabinet and removing the drum of GE dryer models
Note:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Posted on Feb 05, 2008
  • 160 Answers
SOURCE: Replacing dryer belt on Maytag
i would take off the cover, it might be reg or star type screws and look at this page
http://www.partselect.com/ModelFrames.aspx?ModelID=64957&ModelNum=DG410&mfgModelNum=&ManufactureID=1&Selected=36056&Position=6&mfg=Maytag&Type=&Mark=6
Posted on Jul 10, 2008
TheMobilian
  • 8220 Answers
SOURCE: Amana dryer belt has come off, need to put back on, Help....
Here is a pictoral of a variety of different BELT CONFIGURATIONS for dryers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 22, 2009
  • 653 Answers
SOURCE: I HAVE AN AMANA GAS DRYER THAT MAKES A VERY LOUD
Here is the link for the owner's manual, but it doesn't look like much help. Just cut and paste on the address bar of your browser. http://shop.amana.com/assets/pdfs/literature/40125301.PDF
Once you get through looking over the manual, here is how you fix your dryer:
  1. Unplug the power plug, disconnect the gas line, and vent hose, and pull out where you can access all sides.
  2. Take a putty knife and insert it between the top and the cabinet at the front corners to release the spring clips.
  3. Flip the top toward the back making sure the wiring harness to the timer and controls does not get pulled.
  4. Take off the access panel toward the bottom of the cabinet, push the belt tensioner away from the belt, and pull the belt off of the motor pulley.
  5. Lift the drum out of the cabinet, clean and re-grease the ball and socket at the back of the drum, clean off the surface where the belt rides with steel wool.
  6. If the idle rollers turn freely, clean the lint off of the surfaces, put the new belt on the drum and lower back into place.
  7. Put the belt back on the motor pulley, put the bottom cover back on, flip the lid closed, reconnect the gas, vent hose, and plug in.
If you found this solution helpful, please don't forget to rank it.
Posted on Mar 27, 2009
Ngd7200
if you rapped the belt around the pulley and it's not tight enough then you popped the spring off of the pulley,you'll have to pull the drum again so you can see where the spring connects to the pulley,here's the sears site,put your model number in,click on cabinet parts and you'll see number 15 tention spring,this has to be connected to the pulley arm.http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dryer-Parts/Model-NGD7200TW10/1268/0151200/W0712024/00002?blt=06&prst=&shdMod=
Nov 12, 2011 | Amana NGD7200TW Gas Dryer
Can you give me an illustration on how the dryer belt goes on my Amana dryer LG8319w2 model number???
Hi and welcome to FixYa I am Kelly,
The routing is here around the motor and idler pulleys: (AMANA all models)
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramA
amana.gif Hopefully this is exactly what you needed. If not, respond here and I will help you. Thanks for choosing FixYa, Kelly
Jul 16, 2011 | Amana Dryers
Have a five year old Amana Gas Dryer Model Number NDG5805 that makes a buzzing sound only when it is heating, what could be the problem?
the gas valve coils on the gas valve body that hold the gas valve open to supply gas to fire the burner are getting loose and need replacing
Mar 08, 2011 | Amana NDG5805AW Gas Dryer
Belt worn out - need to find the model number: amana heavy duty gas dryer - limited edition
you gave the model number it's NDE6800AYW,the belt part number is 33002535 and it's around 25 bucks
Jul 31, 2010 | Amana NDE6800AYW Electric Dryer
I have an Amana model NDG7800AW. A few weeks ago
The roller to the belt tensioner is binding causing to make the warbling noise.The bearing needs to be replaced which comes with the roller. A new belt is advisable as well when replacing. The stalling problem could be also from the belt being stretched or the timer relay is weak
May 01, 2010 | Amana NDG7800AW Gas Dryer
Amana Gas Dryer LG3912W When dryer is turned on ignitor glows for 5-10 seoonds, then shuts off. I don't hear any opening and closing of gas valve. Is it the gas valve solenoid? Also when dryer is tumbling...
Good day,
If your sure it is getting gas, then the problem is with the gas valve. There are 2 coils mounted on top of the gas valve and they are either shorted or open. In either case they need replace.
Simple job, just remove both wire connections, then the bracket is held on with one screw. Remove the bracket, and the coils will lift right off. Very common problem.
P.S. When purchasing the dual coil kit, if the Amana seems pricey, check with the counterman and ask for the Whirlpool kit. It's identical except for the part number.
The rollers are an obvious solution. You'll have to inspect them first. The belt tensioner is another item, and in rare cases the blower wheel attached to the motor.
Dec 16, 2009 | Amana ALG331RAW Gas Dryer
Amana electric dryer model #LE8217W2 belt replacement
This will help:
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 08, 2009 | Amana Dryers
How to remove the lower panel, GAS AMANA DRYER, model LEA 30 AW
generic instructions.... remove screws through lower panel bottom lip, panel lifts straight up and out.
........................or.....................
Use a putty knife to release the front clips (one near each front corner) and pop
the top to view belt.
Need model # for exact instructions
Feb 10, 2009 | Amana ALG331RAW Gas Dryer
Dryers Logo
53 people viewed this question
Top Dryers Experts
Marvin
Marvin
