Question about Targus AMW15US Mouse
I have a targus mouse and need to change the batteries
4 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: change batteries in a targus portable mouse
I found the user guide in French. It says to slide back the cover behind the Logo on top.
also found it in English:
Installing the Batteries
Optical Mouse
1 Remove the battery cover from the top of the mouse by
pressing the top center (over the Targus logo) and
sliding it back.
2 Insert the supplied batteries , making sure that the
positive (+) and negative (-) ends of each battery match
the polarity indicators inside the battery housing.
WARNINGS: When replacing the batteries, you may use
alkaline or other heavy-duty NiMH batteries. Never
combine an alkaline with a NiMH battery in a device.
Avoid mixing new and used batteries in a device.
3 Slide the battery cover back in to position until it “clicks”
firmly into place.
4 Turn on the mouse by sliding the on/off switch on the
bottom of the mouse to the “on” position.
The optical sensor, located on the bottom of the mouse,
glows red.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jun 07, 2009
yooperbud
  • 8637 Answers
SOURCE: targus mouse remote
If the Red Light is on the batteries should be good enough to function. Try
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 20, 2009
pumpkinman
  • 1165 Answers
SOURCE: Targus Bluetooth Laser Mouse Rechargeable Battery Trouble
check batterys to make sure there placed in mouse properly.try other usb ports.Batterys may be bad from factory.try some other rechargeables in it.if you have a charger for rechargeable batterys place the batterys in that and see if they charge.if they do then your pc is not charging them correctly/
Posted on Jun 11, 2009
How to open targus amw2507us mouse
Hallo,
Under the mouse in the rear side it is a clamp what have to be pressed, and then the top cover will be off and can replace the battery
here it si a linke and a picture for it
512a5b26-0126-4353-a121-013d2bc0df22.jpg http://cdn.targus.com/web/us/downloads/pawm20u_ug.pdf
Sep 06, 2014 | Targus 2.4ghz Wireless Laptop Mouse With...
How to install batteries in targus mouse
On the black cover, press on the Targus label - to release the latch - then slide the cover backwards. It's a little tight but the cover should come out. You'll need to (2) AAA batteries for replacement. Cheers
Jan 12, 2011 | Targus PAWM001U Mouse
I have model # PAWM004 & CANNOT LOCATE ON THE MOUSE WHERE THE BATTERY COVER IS? NEED TO CHANGE BATTERIES
On the black cover, press down on the Targus label - to release the latch underneath - then slide the cover backwards. It's a little tight but it shoud come out. I did it just a minute ago. You'll need two (2) AAA for replacement. Cheers.
Jan 08, 2011 | Targus PAWM001U Mouse
How do you get back off mouse to iunsert batteries
Remove the battery cover from the top of the mouse by pressing the battery cover hinge located on the bottom of the mouse and sliding it off.
If you need the user manual, follow this link to the download from Targus...
http://www.targus.com/us/downloads/AMW05_UG.pdf
Oct 31, 2009 | Targus AMW05US Mouse
Describe your Targus Wireless Keypad &
there is no need of softwere for both. im now using logitech brand. But we need to set progrram in control pannel. we should use battery in mouse and key bord. To contact usb senser. thanks ( nepal)
Jul 11, 2009 | Targus Wireless Keypad/Mouse PAKP003U
Change batteries in a targus portable mouse
Optical Mouse
sliding it back.
firmly into place.
glows red.
Thanks, Joe
Jun 07, 2009 | Targus PAWM001U Mouse
Targus mouse not recognized
What is the OS of your computer? This Targus mouse would work with Win 98, Win 2000 and Win XP. Vista was not mentioned. And if you are running Windows Vista for you laptop, then that could be the reason why it was not recognized by the computer.
Is this the wireless optical mouse? If yes, you need to follow the steps below to isolate the problem:
1. Connect the USB receiver into different USB ports of the computer.
2. Replace the batteries with the fresh ones.
3. Try connecting the mouse into different computer to see if you've got a defective mouse.
If you've tried everything and got the same problem, you may need to refer to the manufacturer, because I'm not sure if this mouse is a Plug-n-Play device or if it needs a driver.
Have a great day!
May 26, 2009 | Targus PAWM001U Mouse
Targus amw15us not working
have you tried to change batteries? low battery will cause your mouse not to connect to the receiver.
Feb 04, 2009 | Targus Wireless Optical Notebook Mouse...
Targus mouse remote
Feb 07, 2008 | Targus Wireless Remote Presenter Mouse
Targus AMW15US Mouse Logo
189 people viewed this question
Top Targus Computers & Internet Experts
J John
Dudeman321
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
