Question about Electrolux EOD5330 Ultrafan Electric Double Oven
Heated oven to 200 and on putting food in the oven there was a bright white light and a bit of smoke. I turned off and left for 20 mins and tried again and would not heat up properly. Has my element burnt out? Is this likely to be expensive?
    Sniper:
  • 174 Answers
That was your element burning out. you can change it from inside the oven but be carefull not to lose the wires. if you do you have to take the oven out to reconnect them
Posted on Aug 06, 2010
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
I left silicone guard on grates and put on self cleaning. My oven is now filled with a white powder.
Thank you for your inquiry, Cheryl!
I understand that you left the silicone guard on the grates and turned on self-cleaning, now you have white powder inside of your Frigidaire range. This can be removed by using hot water, baking soda, and a non-abrasive cloth. It may take elbow grease in order to remove the white powder. I would recommend not using the oven until you have removed the white powder. I hope this information is helpful for you. -Matt
Apr 29, 2015 | Frigidaire 30" Self-Cleaning Freestanding...
Smoking Oven when using grill
It appears that the smoke is excess fat / food splatters that have landed on the grill element. If you had a faulty element it would not work period Also check that any boil overs from pots above are not finding their way to the rear of the element.
Jun 10, 2013 | Ovens
White residue left after using self cleaning feature - I can't remove it with soap and water and elbow grease. What would work? This looks awful!!!
The residue your seeing is the remains of whatever was left in the oven when you decided to creamate in. Grease, food, etc was basically turned to has and then powder coated into the metal. Bit of advice for the future though, avoid using self clean mode not only for the scenario you have, but for your bank account as well. The temperatures the oven reaches in self clean exceed that of which the oven cavity can handle letting heat pass upward, usually damaging the lock mechanism for sure, as well as the control board and touchpad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 23, 2012 | GE Profile JT952 Electric Double Oven
The broiler and the burners all light but the oven doesn't.
your oven igniter is no good. remove racks from oven, unscrew the 2 screws in the back of he bottom panel. remove panel. there will be a metal plate on top of the flame spreader. remove the wing nut holding the plate and remove plate. you should now see the igniter. now try turning the oven on. after a few seconds you should see the igniter glowing. if it gets to a real bright then it is good. if it doesnt it is bad. unplug the stove.changing it is fairly simple. just remove the 2 screws holding it in place, gently pull on the wire to see if there is a connector, if not then you can always cut and join the wires to install the new igniter. igniter should run you less that $20 bucks. its pretty simple to change. after changing the igniter and before reassembling your oven, just plug it back in and turn the oven on. oven should lite. do not put hands or ace inside the oven while attemping to lite.
Feb 02, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My gas range/oven emits a toxic smoke that burns our eyes WAY different than spilled food. The smoke comes out the right side vent rahter than the usual left side vent and only when we cook higher than...
When the oven gets dirty and you don't run the clean cycle, dirt builds up and burns away the hotter the oven gets. Run the clean cycle if you have a self clean mode on the oven. throw the metal burner and grates in the oven too. (no plastic) open a window because it will stink and it takes a few hours to run. If not, use oven cleaner then run the oven to the hottest temp for at least 1-2 hours to burn the old dirt out..
Good Luck, Bill
Jan 07, 2018 | Ovens
Do I need to preheat the oven when cooking in the iven When using as a grill the grill smokes all the time
hi, what you need to do is turn the grill on and leave it on what is happening is all the steam and fat and grease form the cooking you have done in the oven has risen and stuck on the heating element the grill uses, so open your windows and turn the grill onto its highest setting and just leave it after a while the smoke will stop.
You need to do this so that any food you cook using the grill doesnt smell of the smoke thats burning on the grill element.
Dont worry you wont do any harm to it this is a very common problem with combo ovens and grills and the same goes for microwaves with the grill feature so dont worry to much its what happens over time if you dont use the grill much.
So just switch the grill on and leave it it can take upto 20 to 30min to stop smoking but after its burned off all the grease and fat etc it will stop smoking and stop smelling so dont worry everybody who has one goes through this same problem.
let me know how you get on or if you need further assistance ok.
Its best you do this once a week or so to ensure that it dont build up to much as it can really stink the whole place out and if you cook food without burning it all off your food will taste like the smell witch believe me isnt nice, so just leave it all to burn off leave your windows and doors open and after about 20 min you should find the smoke will stop and the smell will go away.
You may find it only takes 5 to 10 min but dont worry no matter how long it takes your not doing any harm your just cleaning the element.
Dont try cleaning it with cleaning products as this can cause harm to the element and could taint any food with the cleaning product you use.
The only real help you can give is that before you turn it on to burn off the grease use a stiff hand brush and brush the element to remove all the dried on loose bits this will then make it quicker to stop smoking.
But other than that just leave it and it will sort itself out.
Jan 13, 2010 | Creda Europa E010E Electric Single Oven
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
NEFF OVEN PROBLEM - SMOKE AND FUMES COMING OUT OF OVEN
Take the cover off that is surrounding the fan and you will probably find food or something there or on the fan blades. If it is not a food smell, then there is probably some wiring that is burning. I suspect that there is food behind the housing of the fan.
Feb 02, 2009 | Ovens
Hotpoint bottom oven
Cooking is determined by 3 things so let's look at what they are and what they do.
They are:
  1. The Fan Oven Element - This is very much the same as a light bulb only instead of giving off light it gives off heat. Like a light that is switched On or Off by a wall switch, the Element is switched On or Off by a Thermostat according to the temperature required. In short if the element fails your oven will be cold.
  2. The Fan & Motor - This sucks the air in through the centre mesh and circulates it around the Element and pushes the heated air out of the top, bottom and sides of the back-plate. Fan ovens cannot heat properly if the fan is not running OR if the fan runs too slowly as the motor starts to fail.
  3. The Thermostat. - This is basically an On/Off Switch that responds to the temperature in the oven. If The Fan is running correctly and you are achieving some temperature in the oven, then the fault will be with the Thermostat.
I hope this Helps - Terry
ALWAYS ISOLATE THE POWER SUPPLY BEFORE WORKING ON THEI APPLIANCE!
May 06, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Electrolux EOD5330 Ultrafan Electric Double Oven Logo
203 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
