Question about Vehicle Parts & Accessories
I have a 2006 chevy truck with valet start system. the remote will not start engine and the only way i can start truck is use key and start it in neutral. i have replaced the neutaral saftey switch already and know its a issue with the valet its been in my truck since 2006. how can i disable it?
  • cwarden2010 Aug 08, 2010
    silverardo 1500 ext cab. i did find it does start in neautral and for sum reason the park light only lights up for a half a second when i put the key in then goes out. R N D 1 2 all light up right
    Problem Solver:
  • 11 Answers
TAKE MAIN WIRES OFF THE BRAIN.AND BY THE WAY WHICH CHEVY TRUCK
Posted on Aug 08, 2010
Can't get into trunk to jump start car. Remote or key won't open trunk
Check your owners manual, there is usually a manual cable inside of the vehicle to release the trunk for just such an instance.
Jun 04, 2015 | 2006 Jaguar XJ8 L
We have a 07 Chevy Silverado with factor Onstar and discovered a loose wire under the steering column. Found lots of diy wiring and it looks like an aftermarket power door system had been installed- Valet...
First why could not Onstar unlock car Yes if this system was installed wrong it could interfere with the lock and unlock relays if you do not have the remote remove the valet system and restore factory wiring then call onstar to see if they can control the system now.
May 05, 2014 | Cars & Trucks
I had a avital remote start pot on a 2004 chevy venture van. everything worked ok for a month then the remote locks, poer windows and dome lights quit working. are they all connected together for the...
Avital is one brand of remote starter that features easy-to-use keyless remotes. These remotes can be programmed wirelessly to your engine and then added to your keychain. Once programmed, you will be able to use the remote from as far as a couple hundred feet away in your house, the street or a parking lot. If your remote is not working, you can troubleshoot the remote and get it resynced in seconds.
  • Enter your caricon1.png, leave your driver's door open and insert your key into the ignition.
  • 2 Turn the ignition to the "On" position and press and release the "Valet" button on your remote.
  • Press and hold the "Valet" switch again after releasing the first time and wait for the system's siren to chirp and the LED lighticon1.png to blink.
  • 4 Continue holding the "Valet" button and then press the starter button on your remote.
  • 5 Wait for another chirp and release both buttons to complete the process.
  • Apr 08, 2014 | Cars & Trucks
    VALET MODE DISPLAY ON THE CLUSTER
    go to the trunk of the car and put the key into the trucnk tumbler and open it, that will deativate the valet mode...
    Jan 10, 2014 | 2006 Jaguar XK8
    Dealer gave me a shaved key works on starting ignition not on door lock the other three keys work on everything car doesn't have engine immoboliser removed the remote keyless entry fobs what is
    Many times the dealer gives you a valet key made to give to the vet to park your car, these keys work even though the theft deterant system is active, but they will only work for short periods untill the theft system activates and imobolizes the vehicle. The system is reset when the valet brings your vehicle and you insert your normal (chiped) key.
    Apr 04, 2013 | 2003 Toyota Highlander
    Need program to add additional key fob to my Python 474P model on a 2005 Kia Sportage
    To program additonal remote; open door, turn ignition on. Press and release valet button one time then, press and hold valet button. While holding valet button, press lock button on new remote. Turn ignition off. Test system.
    Sep 29, 2012 | Remote Start System
    My security system won't disarm on my 1999 chevy blazer
    Is this an aftermarket alarm? If so, first locate the valet switch. It should be a black push button. Next, turn the ignition on, press and release the valet switch. This should disarm you aftermarket alarm. This is the most common manual disarm procedure for Directed (avital, python, Automate, Viper) and Audiovox (prestige, pursuit, code).
    If this is the factory alarm and, you don't have the remote. Unlock the vehicle using your key in the driver's door.
    Aug 16, 2012 | Vehicle Parts & Accessories
    Valet Key Doesn't Start Engine
    Sounds like the chip in the key is not allowing the security system to allow the car to start. You may need a new key from the dealer.
    Jun 25, 2012 | Volkswagen Jetta Cars & Trucks
    Where is the valet switch on a 2004 chevy malibu LS?
    There should be a key specifically for a valet.
    1) Open one of your vehicle's doors and turn the ignition, using the car key, to the "Run" position. Check to see that the dome light comes on. Make sure that you have the dome light set to the position where it powers the light when the door is opened, as there are usually three settings: one for "On," one for "Off" and one for when a door is opened.
    2) Press the valet remote push-button to access the channel that you want to program: once for "Arm/disarm," twice for "Trunk Release" and three times for "Remote Start." The valet push-button is usually located under the driver's side panel, and it must be pressed within 15 seconds of opening the door. The push-button may also be installed underneath the kick panel.
    3) Press the valet push button once again and wait to hear a chirping or a honking sound. If you do not hear either of these sounds, your vehicle might have a jumper installed that has turned the valet programming feature off. Refer to your vehicle's instructional manual to learn how to set the valet programming feature to the "On" position. Keep holding the valet button pressed as you continue onto the next step.
    4) Push the button on the remote that you wish to assign to a particular valet channel. Press the button on the hand-held valet remote that you wish to assign to a particular valet channel. If you wish to program multiple remotes, repeat this step for each of them. If you program four or more remotes, the old programming will be erased.
    5) Let go of the valet push-button and exit your vehicle. Your handheld remote is now ready to use.
    Tips & Warnings - Some valet remote channels require different programming individually, so refer to the owner's manual or to the link provided in the "Resources" section of this article, for specific instructions.
    - Valet remote programming methods may vary, depending on the vehicle's make and model.
    Feb 17, 2011 | Keyless Entry Remote Fob Clicker for 2004 ...
    My factory remote starter won't work, when button on key fob is pushed the parking lights flash like they're suppose to but the engine doesn't start.
    Make sure to hit the lock button twice then hold the start button until starting. There can be several issues for a malfunction.If this does not work we can definitely look into other options but the biggest reason for an factory remote start not functioning is the check engine light being on.It completely disables the remote start function. Here is a list of possibilties of why the remote start will not function.
    A current vehicle DTC that illuminates the malfunction indicator lamp (MIL)
    • The vehicle is in valet mode. • More than 2 remote starts have been attempted. • The hazard switch is in the ON position. • A current hazard switch DTC is set. • The vehicle hood is ajar. • A current hood ajar DTC is set. • The CTD system detects an alarm trigger. • Excessive engine RPM • Excessive coolant temperature • Accelerator pedal position greater than 0 percent • Vehicle not in park • Vehicle theft deterrent malfunction • A current automatic transmission shift lock control system DRC is set. • A vehicle speed sensor signal is detected by the ECM.
    Dec 16, 2010 | 2006 Chevrolet HHR
    Vehicle Parts & Accessories Logo
    53 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Marvin
    Marvin
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
