Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
The bump knob on my tb70ss model troy built weed eater came off and the heat build up and centrifical force caused the spool to melt and become distorted. I replaced both plus the inner reel but it occurred again after the fourth time I used it with the new parts, What is causing the bump knob to come off and is there a repair manual for this model?
  • 513 Answers
Check gear head for grease and i have turned a lot of customers onto a speed-feed head i have had great feed back on them. They have 2 different heads but will fit almost all trimmers. One fits curved shaft and the other fits only straight shafts. You can google www.speed-feed.com look at video and how much it will help in respooling the head. I use it personally as well.
Posted on Oct 12, 2017
  • 708 Answers
Believe you may have bad gears in item no. 17 would try replacing. To see this diagram go to partstree.com type in your model no. etc.The bump knob on my - iplimage (3)-pdt4gccsesyirln1xmij4nvf-5-0.png
Posted on Oct 11, 2017
  • 65 Answers
SOURCE: troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Posted on Aug 22, 2009
SOURCE: Screw cap to reel head of ryobi ss30 weed eater will not come off
hey! I just had the same thing happen to me 30mins ago. I tried prying it off with a screw driver and punching it out.No such luck. Frustrated, I tried turning the spool from the base and it popped right out and I was able to easily disassemble.
Posted on Sep 01, 2009
SOURCE: lost manual for troy bilt weed eater mod#tb514cs 4cycle
I didn't find that exact one either, but recently had to work on my Yard Man 4-Cycle Straight Shaft and used a Troy-Bilt manual for a similar trimmer - worked great.
If you don't find yours at this site, maybe a similar one will work. It looks like the difference is the TB525 receives attachments. If you're trying to fix something right now, here's the manual for that one until you find yours:
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/big_red_tb575ss.html
Posted on Sep 08, 2009
bulldogchief
  • 388 Answers
SOURCE: How do you add trimmer line to Troy Bilt TB539E
This model trimmer uses .095" diameter line, your local home improvement store will carry replacement line and it will also carry a replacement spool with the line already spooled on it.
This trimmer is a "bump advance" trimmer meaning you bump the head on the ground while it is spinning to advance line out.
What to do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head if the trimmer and unscrew the cap and CAREFULLY remove the spool...you do not want to lose the spring! Take a look at the spool, it will show the direction to spool the line, spool the line then replace the spool by first putting the spring back on the shaft, then put the end of the line through the hole(s) on the side of the outer head, press the spool in place and screw the cap back on.
Of course you can eliminate about 90% of the headaches by buying a pre-spooled head at your local home improvement store...then you follow the directions above and can skip the spooling part. Cheers!
alpug
  • 1961 Answers
SOURCE: I need to down load the ower manualfor troy bilt
here is the manual. Just click the file to download instantly.
1. 769-04481_TB539E_Operators_Manual.pdf
Please don't forget to give this answer a four thumbs up rating.
Thank you for using Fixya.
Alp
Posted on Sep 25, 2010
How to restring the weed eater head on the Troy built gas weedeater
Unscrew the bump knob. Remove spool and wind line in direction of arrow on hub.
Jul 01, 2018 | Troy Garden
STRING KEEPS BREAKING ON A TROY BILT WEED EATER TB539E
Take a look at the hole in the spool where the business end of the string comes through. There should be a smooth metal grommet or smooth short tube there. If the metal is missing, then the string is breaking because it rubs against plastic and heats up very quickly. Or the tube or grommet might have a rough or sharp spot. You might be able to polish it up with a Dremmel type of tool.
Sep 01, 2010 | Troy Bilt Tb70ss Gas Trimmer
How do you do you but the LINE in a gas fired weed eater troy built
The owners/users manual that comes with these units always explains this in good detail. Go here to view those pages in a Troy Bilt trimmer manual. You will need Adobe Reader. Scroll thru the pages till you get to the section on replacing the string.
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb70ss.html
Aug 26, 2010 | Troy Garden
The spool came unscrewed from the shaft - we can't
It's probably a left-hand thread, turn it counter-clockwise to tighten.
May 01, 2010 | Troy Bilt Tb70ss Gas Trimmer
String trimmer cutting attachment doesn't turn fast enough
Take the shaft off at the motor,see if any thing is worn there.Also,take head off of end of weed eater,check for grass or any build up in there.
Aug 29, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy built weed eater won't feed line
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Pull Cord won't pull on model TB525CS
Hi try this web site its called pats small engines shows exploded view
Jun 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Blade on my weed eater troy build
I would suggest that you obtain a blade that fits. Reducing the mount will be dangurace
Jan 26, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
189 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
