Question about Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor
I have the remote controlled Riptide 80lb thrust bow mount. The motor runs, but it will not turn. Sounds / looks like something is binding in the turning control motor. Any suggestions?
Editor925
  • 285 Answers
SOURCE: Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
Posted on Mar 17, 2009
  • 10 Answers
SOURCE: bow mount 80lb to transom mount
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Posted on May 08, 2009
SOURCE: I lost istallation manual for minn kota power
Contact the people at this Email address. Minn Kota <Motors@johnsonoutdoors.com> The address is between the brackets. They emailed me a manual for a different trolling motor. They are nice folks. It will take up to a week for you to get a reply.
Posted on Jun 05, 2009
  • 6 Answers
SOURCE: I have a Minnkota Riptide 80# thrust trollmotor.
1. possibly a broken connection to the motor where the propeller is located. 2. Also could be a bad motor. 3. Look for a fuse location for a possible blown fuse to the motor. 4. motor brushes could be the problem.
Posted on Nov 24, 2009
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
The turn feature on my remote trolling motor will not work
Maybe the pin is sheated on the prop...or something is caught in it..
check the prop.
Dec 30, 2012 | Minn Kota Riptide St Saltwater 80 Bow...
Have a minn kota riptide sf 101 thrust 62" shaft.
There is more than the shaft, there is the housing and then everything needs to fit and have correct clearances.....I suggest sell the old one and get a 52 inch new one...
Mar 01, 2011 | Minn Kota Riptide SF 101 Saltwater...
Have a Minn Kota Riptide 70lb thrust 24 volt. While lifting the motor the cables were cut. We spliced them with a heavy duty connector and it worked fine for several weeks. Now the motor will not run on...
Does the splice get hot when you are running the motor? If yes, then the splice could certainly be the problem. I would have replaced the wire completely. However, the problem more than likely is the controller.
Oct 28, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn kota riptide 55 bow mount with foot control and auto pilot. problem is prop doesn't seem to spin as fast so top speed is about half to two thirds of what it was when new. unit is about 5yrs old.just...
Sounds as if the motor has either bearings going bad and/or water has gotten in the housing washed the lubricants out. Motors do wear out eventually. I'm not sure if the brushes are replacible. Have you checked for any constrictions like fishing line? And also the contacts on the controller could have minor corrosion meaning take it apart if possible and clean with steel wool or a dremel.
Oct 16, 2010 | Minn Kota Riptide St Saltwater 55 Bow...
I have a Minnkota Riptide 80# thrust trollmotor.I have power to the head but motor will not run. It is a bow mount with twist grip control.When I mash on the power indicator button ,it lights up showing I...
Nov 23, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Looking for parts.
You nearest Minn Kota service centre is
G/M Industries
9502w 800s
Swayzee
, IN
46986
Phone: 765-922-4816
8am-10pm Monday - Sunday
Jul 11, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Bow mount 80lb to transom mount
May 06, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor Logo
22 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
