Question about Panasonic CW-C80YU Air Conditioner
My current Panasonic CWC80Yu air conditioner died. Does anyone know of a replacement unit that will fit the Panasonic wall sleeve ? The Freidrich CP08F10 dimensions are real close. Will it fix my existing through the wall sleeve? I have a stucco house.
Agent Don
  • 310 Answers
SOURCE: Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Posted on Apr 15, 2008
Coldcut
  • 1554 Answers
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Posted on Jun 13, 2008
burzerko
  • 254 Answers
SOURCE: Putting a window air conditioner in the wall
I dont see a problem with these working in the wall, however you will probably need to install a condensate line to drain away the water that will be left from condensation. These items may be purchased from any hardware store.
Hope this helps Ya please rate me
Posted on Jun 22, 2008
crouchdash
  • 83 Answers
SOURCE: my panasonic in wall air conditioner doesn't cool anymore --
Hi, if your 6 year old Aircon has not yet been re-charged eversince it was bought, then yes it's time for a refrigerant re-charge.
I hope it helps.
Posted on Jun 01, 2009
  • 34 Answers
SOURCE: panasonic air conditioner issues
does it freeze up? this could be a sign of low freon. does the fan turn on? if not the compressor will get hot and shut itself down on overload the fan can be easily replaced for around 100.00
Posted on Oct 10, 2009
Looking to replace a guasar wall aircondition that fits a sleeve the size of the aircondition was 26 3/4 by width is 25 1/4
Fredrich makes one which may work in sleeve or install a new unit with sleeve and put molding around hole in wall .
Oct 01, 2014 | Quasar HQ2051TH Air Conditioner
My exist. unit is a very old sears coldspot through the wall mounted in a 12x18 in.exact sleeve. Can i remove unit and replace with FRA052XT7 ?. Exist sleve is vented on both sides & back.This is...
Get rid of the old stuff,too big to be used
Newer unit can't be inside the old sleeve as you call it
Just install the new unit how you see fit, to seal
it up
5000BTU is too small
A 7,200,8,000 or 10,000 BTU is the same size & about
the same price.
Jul 18, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
I have a freidrich quietmaster wall air conditioner and the condenser works fine until you use the money saver then it starts to blow hot air
blowing hot air is the unit's way of further cooling its compressor, this should not last long and should cycle back and forth
May 03, 2011 | Heating & Cooling
2 Air Conditioner Problems
Whinny noise is probably motor which needs some motor machine oil (hardware store).
Freezing is probably caused by bad de-icing switch or poorly insulated de-icing switch.
If you want to further pursue, let me know.
Apr 30, 2009 | Heating & Cooling
Emerson Air Conditioner #10HW42K through wall
First off, my model # is Emerson Quiet Kool 10HW42K. No it is not yet solved, however I am reaching out to a number of sources. Was hoping to get a simple answer since it is not a "repair" problem, but rather a "replacement problem". I am looking for another AC that will fit the original sleeve.
Jul 07, 2008 | Emerson Quiet Kool 10NW16K Air Conditioner
Trru the Wall Oversized
Drop in a Frigidaire 25,000 btu, 230-volt Electronic Control Air Conditioner (Model #FAS256R2A). It is Way More Cooling than you need, but it is a very efficient unit and will provide quiet, nearly instantaneous room temprature reduction! Width 26-1/2... Height 18-5/8... Wall Sleeve Included... about $450.
Jun 23, 2008 | Frigidaire FAC124 wall/Window Air...
Jun 22, 2008 | Heating & Cooling
Is this the right unit? Can it be used with a sleeve?
If a sleeve came with it then it should be used unless you are replacing a unit and the existing sleeve is properly mounted. Then sleeve should have a slight backward angle so that condensation does not drain into the living space.
Jun 12, 2008 | Heating & Cooling
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Panasonic CW-C80YU Air Conditioner Logo
85 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
